Says unusable signal when trying to hookup my Nintendo 64.
I am trying to play my nintendo 64 so i hooked it up using the antenna/cable port. The game will flip on the screen for about 1 sec and then the screen is blue and it says unusable signal at the bottom of the screen. It says the same thing when i first hook up my PS3 but it always starts working. Also the Nintendo 64 works on all the other tvs in our house.
    Scholar:
  • 146 Answers
Here are a couple of things to try. Go into the menu and make sure that you have the "ANTENNA" selected instead of "CABLE". Also make sure that the channel that you are using (3 or 4) is programmed into the memory of the tv. If not, use "auto program" in the menu to program the channels.
These newer tv's are not the same as older tv's. If none of that works, put a antenna amp on the output of the nintendo and then plug it into the tv. This should fix it.
Posted on Nov 17, 2008
My n 64 has audio but no video
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 25, 2012 | Nintendo 64 Console
Cant seem to get my nintendo 64 console hooked up..need to hook it up through the vcr
Just follow these steps and you will be playing your Nintendo 64 in no time at all.
  1. Set your Nintendo 64 in it's desired location
  2. Plug the power cord into the back of your console
  3. Plug the other end of the power cord into an electrical outlet
  4. Plug the AV cable into the back of your Nintendo 64 system
  5. On the back of your VCR find 3 cable sockets colored red white and yellow
  6. Plug the the red plug of the AV cable into the red socket
  7. Plug the the white plug of the AV cable into the white socket
  8. Plug the the yellow plug of the AV cable into the yellow socket
  9. Plug your Nintendo 64 controller into the front of your console
  10. Place your game into the game cartage slot
  11. Turn on the Nintendo 64
If you encounter any problems at all feel free to comment on this solution so that I can further assist you.
Jun 13, 2011 | Nintendo Video Game Consoles & Games
We have no manual - need instructions on how to hook it to the TV.
Nintendo 64 Hookups
Quick Tip! If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
The Stereo Audio/Video Cable that is included with the Nintendo 64 will allow you to connect the Control Deck to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have Audio/Video inputs . Though your TV may not have them, almost all VCRs do.
If you DO have AV inputs, choose where you want to connect to:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
If you do NOT have AV inputs, you will need to use an RF Switch and RF Modulator for your hookup. The RF Switch and Modulator are sold separately. (Where to buy):
Connecting the RF Switch to a TV
Connecting the RF Switch to a VCR
Other Hookups
Feb 24, 2011 | Nintendo 64 Console
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
Turn the power on.
Feb 10, 2011 | Nintendo 64 Console
N64 has old tv style cable but when plugged directly into new dtv it doesnt see any signal. any help here?
Find an unused channel, and try manually tuning it into the Nintendo signal. I think it might be in the VLF/VHF range.
Hope that helped.
Cheers from NZ
Dec 08, 2010 | Nintendo 64 Console
Nintendo 64 to jvc hdtv
Check all of your plugs, make sure they are clean. Make sure the game that you have inside the system is clean and free of dust as well as the game connector port on the system. Make sure you are on your A/V channel. If all else fails, you ma have to gt a new A/V plug. When I got my Nintendo 64, I tried to plug it in to my TV using the plug that came with it, but it did not work. I soon found that the Playstation 2 A/V cable that I have also has two additional cables to it, and one of them works in the N64 system. So, I tried to play the system with that cable plugged in, and it worked, so I would suggest buying a new A/V cable that works in the N64 system.
Hope this helps!!!!!
Please Rate
Jun 28, 2009 | Nintendo 64 Console
My nintendo 64 wont come on, ON the tv.
You need a switch (transformer) to connect it to the incoming signal antenna screws. You will probably need to adapt it to a cable tv plug. The wires you connected are for the sound.
Mar 17, 2009 | Nintendo 64 Console
Nintendo 64 HDTV
I am not an HDTV expert but I believe they are all backwards compatible so the fact it is HD should not be a problem. Have you tried a vcr or dvd player on the same hook ups? It is possible you are trying to use a video input that is already in use? I know on my TV I have the DVD hooked up with an S-video cable to "Video 2". Right next to the S-video hookup are the red, yellow, white RCA jacks. On my TV these can't be used when the S-video is in use so I have to have the games hooked up to the front panel "Video 3". I would disconnect everything and try hooking the N64 up in each input to see if you can find one that works.
Mar 02, 2008 | Nintendo 64 Console
Televison & Video Logo
1,128 people viewed this question
Top Televison & Video Experts
