Question about Humidifiers
Appropriate water supply for a Carrier Bypass humidifier.
I am servicing a Carrier humidifier M/N: HUMCCSBP2017A. The solenoid valve is badly clogged with mineral deposits preventing water flow to the evaporator screen. The water supply to the solenoid valve is from a saddle valve mounted on the hot water outlet pipe of a nearby water heater. Is this water source appropriate or would a cold water pipe be a better supply source? Thanks for your help.
  • 232 Answers
SOURCE: in furnace auto flo humidifier
turn off the water to your house and replace the saddle valve. you should be able to ge from any hardware store
Posted on Sep 13, 2009
SOURCE: There is no water coming into the humidifier from
a professionsl fixed it
Posted on Jan 20, 2010
  • 415 Answers
SOURCE: What is the saddle valve?
Your humidifier will have either a copper or plastic tubing attached to it. This tubing is the water tubing. If you follow that line to where it "taps" into a water line (near the water heater or a water line under your house), there should be a water shut-off valve. The water shut-off valve could be any type of valve but is normally a saddle valve. You could skip the step of shutting off this valve; however, it is good practice to shut the valve off for two reasons: 1. in the event of a water leak, you will be able to easily locate the valve to shut off the water. 2. if the valve is not "excercised" from time to time, the seals will dry rot and the valve will not be capable of doing it's job when the need arises.
Here is a video showing you how to trace your water line to your saddle valve. There is additional information on the video that you might find helpful as well.
Posted on May 07, 2010
  • 182 Answers
SOURCE: There is no water reaching my AprilAire
Yes a new valve seems in order. and yes having the valve on the cold side would create less build up in the filter pad so long as your water dose not come in at 37 degrees. but, I think you have it right.
Posted on Dec 22, 2010
  • 1033 Answers
SOURCE: My humidifier is a Carrier
Hello, no the humidifier should be running only when the blower motor is running. Sounds like the solenoid valve is faulty if water keeps drainig from humidifier.
Posted on Sep 25, 2011
No water flow
if you hear the solenoid click then you may have a clogged orifice or prefilter. these are both located near the solenoid. the orifice is usually in the feed tube and the filter is in the inlet of the solenoid. Try the orifice first to see if it is clogged. If that is clear the try loosening the compression nut before the solenoid to see if you have water coming to the humidifier some times if a needle valve was used they get bad also. I would recommend changing the needle valve out and putting in a proper side stop valve. Most municipalities do not allow needle valves per there codes.
Oct 31, 2013 | Aprilaire 600 Humidifier
I have a HoneywelI Enviracare Elite whole house humidifier. I have no power to the thermostat. The wire goes into the furnace and is attached to a control board. The furnace is working. Humidifer is n
Most of the humidifiers are run by 24 volts AC. disconnect the power wire to stat on circuit board and check there with meter and connect to low voltage ground for 24 volts, I'm assuming the two wires that power the humidistat are red and white.typically red is used for power. most likely you have power if the red for the stat is connected to the W on the board and the heat works, but the humidifier only works while heat is on.the next thing in line is the humidistat , it's a switch so if there is only two wires going to it take them off the stat and connect together, if furnace is on heat and running and stat wires are connected it will send power to water solenoid, if its not working yet the problem lies in the water solenoid if you have 24 volts at the two wires at solenoid.check while disconnected, do not connect those two wires together or a 3 amp fuse will blow on the furnace board. if you have 24 volts there then the valve may be bad or the valve may be stuck or clogged, loosen water supply line to make sure water is getting to valve. I spent many years working in the HVAC industry.
Dec 31, 2011 | Honeywell Humidifiers
Humidifier doesn't work
Hello, if there is water to the solenoid valve but not passing through it than the solenoid valve is malfunctioning and must be replaced. However, if there is no water at the solenoid valve then either the saddle valve or supply line is clogged with sediment. A easy way to chek the solenoid valve is apply power directy to the solenoid valve from the transformer, if it does not open then replace it.
Nov 17, 2011 | General Filters 1099-LH Humidifier
Frequent knocking noise coming from General Aire 1042 LH humidifier
Hello, it depends where the sound is coming from,if it's in the supply water line it could be caused by water hamer or the inlet side of the solenoid valve might be clogged up with sediment. Water hammer is when the solenoid closes under high water pressure and a water hammer arresters should be installed. If the sound is coming directly from the solenoid valve and is more of a chattering sound then there is a loose low voltage wire or the solenoid is going bad. If you disconnect the power to the solenoid and the chattering stops then solenoid must be replaced as it is the cause of the noise.
Mar 17, 2011 | General Filters 1042-LH Humidifier
No water is flowing to the humidifier so I obviously have a problem with where the valve connects to the water supply. With no water, the fan nothing works on the humidifier. Is this normal? If I get...
Is the saddle valve open? if it is check for sediment build up in it, if it;s clear you will need a new saddle valve. If the fan is not running than most likely you are not getting power to the humidifier, check for 24 volts to the solenoid valve. By the way do you have a current sensing relay or sail switch hooked up to this humidifier?
Dec 28, 2010 | Honeywell 360B Humidifier
Humidifier will not turn on (no fan, no water flow)
A breakdown diagram of parts etc above.
Shows you the HE360A.
To me it sounds like it is wired incorrectly, the solenoid should NOT get too hot at all. The PDF above shows wiring data.
Apr 03, 2010 | Honeywell HE360A1027 Whole House...
We just bought a home with this humidifier installed on the furnace. There's no activity when the furnace is running. The water is connected but does not flow. Could this be a transformer problem? We guess...
Could be a couple of things. Transformer can be bad. Try connecting the two wires (usually wired red and white) from the transformer to terminal W and C on the circut board. Your bypassing the transformer and if installed a current sensing relay. The furnace transformer will/should handle the extra load. Turn on the furnace, if still not working, loosen the water supply line at the water solenoid on the humidifier, if water flows out then your supply valve isn't clogged, if no water then try screwing in the needle on the supply valve all the way in then back out. If still no water then the valve is clogged. If all is good then it looks like the water solenoid is bad or wiring to valve/humidifier control. Don't find the controls bad that often. Have fun!
Nov 28, 2009 | Honeywell HE260A1010 Whole House...
Solenoid on Aprilaire 600
solenoid valves dont just burn up just like that you have a recurring restriction due to bad water.Check the saddle valve at the water heater first then check for postive water flow at inlet to the solenoid valve,if you have water flow the valve is clogged with sediment.
Dec 13, 2008 | Aprilaire 600 Humidifier
Noisey humidifier
Not sure what type of humidifier you have but if is a power humidifier like the April 700 or 760 they do have a blower motor and it may be the fan blade is broken.But if you have a bypass humidifier is posible that your water solenoid may be making noise because of to much water pressure there is not much to a bypass humidifier, you may want to close the water supply valve a little at a time se if the noise goes away.
Nov 28, 2007 | Aprilaire 550 Humidifier
No Water when Humidifier Runs
I had the same problem and thought the solenoid valve was bad and was about to spend $80 for a new one. Until I took the short pipe (between the solenoid valve and humidifier) off and found that the orifice was plugged.  I used a sewing pin and cleared out the hole.  Problem solved.  I usually have to clean the orifice in the fall when I turn the heat on for the first time.
Nov 06, 2007 | Carrier LFP Humidifier
Humidifiers Logo
226 people viewed this question
Top Humidifiers Experts
Paul Carew
Are you a Humidifier Expert? Answer questions, earn points and help others
