Question about Dell Computers & Internet
Intervlan switching not working on multihome server
Have a Dell PowerConnect 6248 layer 3 with 4 VLANs configured for IP routing.  InterVLAN switching works correctly between hosts except in the following case.
VLAN Configuration
-IP Routing enabled for all VLANs
-VLAN routing IP address is the  assigned to the VLAN access
VLAN 21
IP Subnet: 10.0.1.0/26
VLAN routing IP Address: 10.0.1.1
VLAN 22
IP Subnet: 10.0.2.0/26
VLAN routing IP address: 10.0.2.1
VLAN 24
IP Subnet 10.0.4.0/26
VLAN routing IP address: 10.0.4.1
VLAN 35
IP subnet 10.0.15.0/26
VLAN routing IP address: 10.0.35.1
Host A  has 2 NICs.
NIC 1 is configured with an ip address of 10.0.15.5 and no default gateway.  This LAN for internal server interconnects.
NIC 2 is configured with IP address 10.0.1.5 and default gateway of 10.0.1.1 (The VLAN IP address).
Host B has 2 NICs
NIC 1 is configured with IP address 10.0.15.10 and no default gateway.
NIC 2 is configured with IP address 10.0.2.10 and default gateway of 10.0.2.1 (again the VLAN IP address).
Pings from Host A to 10.0.15.10 on Host B work as expected - Layer 2 switching on same subnet LAN.
Pings from Host A to 10.0.2.10 on Host B fail.  A tracert shows the 10.0.1.1 VLAN IP as the first entry and then failures on rest of hops (there should be only 2 or 3 at most - see below.)
From my perspective it appears that VLAN 21 10.0.1.1 is directly switching the echo request packets to Host B at 10.0.2.10. Then host B sends the echo reply packets to VLAN 22 10.0.2.1 which switches directly to Host A 10.0.1.5.  I think this is the problem.  Host A is listening for and expecting the echo reply to come from the 10.0.1.1 interface. Instead the echo reply is coming from the 10.0.2.1 interface and so the reply is not properly forwarded to the correct listen process.
I think this is improper handling of the layer 3 switch on the part of the Dell 6248.  I think it should be Host A to VLAN 21 gateway IP address (i.e. 10.0.1.1) then from VLAN 21 gateway to  VLAN 22 gateway (i.e. IP 10.0.2.1) then to host B.  The reverse should happen for the reply from Host B to Host A.  This way Host A correctly sees the reply on the 10.0.1.0 subnet.
I have this same configuration on a Cisco 2848g Layer 3 switch and there is no problem with pings between the multihome servers.  Some how the Cisco layer 3 switching  knows to keep the subnets correct and still do layer 3 switching.
Is there some special (e.g. binding MAC to IP, static IP and MAC) that I need to add on the Dell switch to fix this problem?  Seems to me the layer 3 switching should be transparent to a multihome server just like it is on the Cisco switch.
Thanks in advance for any advice to fix this problem
2 Suggested Answers
SteveRand
  • 210 Answers
SOURCE: Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
Posted on Feb 05, 2009
How to configure VLANS and Tagging
https://m.youtube.com/watch?v=krE16IRIHw4
Watch this video for switch port access . You will need to be in global config interface mode.
Jun 05, 2016 | HP ProCurve Computers & Internet
Sir I have 4200 series 26 ports Switch i want to Configure intra VLAN But I am Getting a problem to Configure that switch . After Cnfigure VLAN on Consol prompt. I am not accessing to my Server & WAN...
If you are creating only Layer 2 VLANs on the switch , you wont be able to ping the servers and Routers as they are in default VLAN1.
you can do the below steps
1. Create sub interfaces on the router LAN interface
2. Provide a new ip range to the new sub interface
3. Make the switch port connecting router as trunk, so that it will carry both the VLAN info
4. on your Labtop/PC give the IP address in the newly defined range
5. Make your switch port to be in the new VLAN
This will work , if you wont be able to configure the above settings, let me know i will give you the detailed config
Nov 01, 2010 | 3Com 4500 24-Port Ethernet Switch
Problem Dell PowerConnect 6248
go to the web interface and disble storm control and flow control
Dec 08, 2009 | Computers & Internet
Inter-vlan routing
Unfortunately, the 5224 is a Layer 2 switch. In order to route between VLANs, you need a Layer 3 device somewhere else on your network. In other words, either a true router, or a multi-homed PC acting as a router, or a true Layer 3 switch. The 5224 is incapable of routing within itself. Sorry!!
Nov 09, 2009 | Computers & Internet
3 vlans, data,1; data 2,;voip,5. Ports carry voice tagged, and data. currently Windows 2000 DHCP server lives on Vlan 1 (AND WORKS). Need to upgrade. When we test the new servers we are unable to make both...
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Aug 06, 2009 | HP ProCurve 4104gl Networking Switch
Static ip address to dell powerconnect switchport for backbone
try for 195.9.200.00 - 195.9.200.32 series hope it will works
Mar 23, 2009 | Dell PowerConnect 6024F (p624fnp)...
IP Addressing by dhcp for vlans
tell each vlan about DHCP server using
ip helper <DHCP servers ip adddress>.
in config mode.
Mar 03, 2009 | Cisco Catalyst 2950 24x10/100 Mbps...
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
Feb 01, 2009 | Cisco Catalyst 3750E-48PD
Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
Oct 28, 2008 | 3Com 4500 24-Port Ethernet Switch
Inter Vlan routing
Just For InterVLAN routing, Mark (enable) administration Access for ALL VLAN :P
Sep 18, 2007 | Computers & Internet
Computers & Internet Logo
398 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
