Question about Viking 37 in. DGSU160-5B Dual (Electric & Gas) Cooktop
Electric ignition Ignition continues to click when burners are turned off.
    Novelist:
  • 222 Answers
Try to remove the control knob then cleaning by using vacium.tnxz
Posted on Nov 18, 2008
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
My cooktop has electric ignition that "clicks"
Take a q-tip and clean under where it clicks. Might have food or grease covering release hole.
Dec 06, 2017 | GE 36 in. JGP628 Gas Cooktop
Miele LP cooktop: we turned the power to the range off. when we turned on again it didn't ignite (it has power!)
Hello
Keep the air holes around the burners free of debris and grease by clearing out the holes with a thin piece of wire or a toothpick. Cleaning out the holes helps the ignitor light the cooktop
Listen for the clicking sound of the ignitor, then turn off the burner if you don't hear the clicking.
Turn the burner to the "Off" position, if you continue to hear the ignitor tick after you've lit the burner. Turn the burner back on to relight it. Ignitors normally make a brief series of electrical clicking sounds when you turn on the ignitors.
Let the ceramic igniter dry out if it has gotten wet and the burner won't ignite. If the igniter isn't wet, clear out the little holes in the burner by chipping out any blockage with a straightened paper clip.
Clean the electrodes if the burners still don't light. The electrode is in the burner base. Clean the metal part with a soft cloth. You can use emery board on the metal part but not the white ceramic part.
Nov 03, 2010 | Miele 30 in. KM443 Electric Cooktop
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 27, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
A spark that causes a snapping noise when a burner is turned on.
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
Feb 17, 2009 | Cooktops
Ignition stays constantly on, How to fix it or shut it off
its a gas cooktop it has to be plugged in somewhere op e the cabinet and unplug it. possible that the electrodes got wet and click from a false sense of continuity, after being unplugged overnight that will sometimes be enough. you also might have a bad start switch on one of hte burners causing the machine to click automatically. try unplugging over night first
Mar 11, 2008 | Maytag 30 in. CSG7000 Gas Cooktop
Viking 37 in. DGSU160-5B Dual (Electric & Gas) Cooktop Logo
100 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
