Question about Cameras
My canon EOS 40D camera will not format the CF card
  • 48 Answers
Could be a number of things causing this, is it just one card or any memory card that it will not format.
If only the one card, I would suggest it is the memory card at fault or that it has been formated as FAT32 on a computer, cameras do not like this setting so you could try formating in the FAT format and then re try formating in the camera.
If it is any card that it will not format then you may have bent CF pins in the camera, try taking the card out and looking down the slot with a bright light, you will see all of the gold pins pointing at you, if you see any bent over then that is your problem, you could try rebending them yourself if you are handy, but normally pays to get a tech to replace the pin set, which luckly on the canons is on a seperate board so is relatively cheap to replace.
Posted on Nov 17, 2008
My canon 40D won't read the CF card anymore and says "CF CARD FULL"
check for bent CF pins. make sure there is room on the CF card.
busy is normal
Jun 02, 2012 | Canon EOS 40D Digital Camera
I bought a new memory stick for my canon eos 40d and took it out to download pictures and now the camera won't work, it says format card to camera
You need to format the card in-camera. This is done via the camera menu. The camera needs to format it to it's own file system, you shouldn't format the card in a computer.
Dec 15, 2010 | Canon EOS 40D Digital Camera
My Canon 40d keeps saying' CF card not formatted Format card with this camera'. I tried to do that but it says ' Cannot format Change the CF card. I have 6 cards and I've tried them all with the same...
My 40d keep saying the cf card is not formatted. I used three different cards and it says the same thing. Is it anything I can do to fix this problem.
Nov 29, 2010 | Canon EOS 40D Digital Camera
Unable to format CF card
Try formatting it on your computer...make sure you are formatting "that" drive and not your C drive.
Mar 19, 2010 | Canon EOS 40D Digital Camera
Canon 40D and 64Gb CF Card
What i find is that the larger the card the slower the write recovery in taking pictures. If you are an action photographer this is a pain as things happen fast . To have the camera take so long to recover from a write leaves you open to losing some excellent shots. So my rule of thumb is use smaller value cards. If you are just a happy shots photographer then this probably doesn't really matter.
Thanks for using Fixya
Sep 15, 2009 | Canon EOS 40D Body Only Digital Camera
CF Card is not formatting. When I try to format it, the camera says. "Cannot format. Change the CF card." - but it can not read any card
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see the following:
Jul 19, 2009 | Canon EOS 40D Digital Camera
Eos 40d error 99
Error 99 can mean many things. Have you installed the latest firmware for the camera (version 1.1.1)? If you don't have, download it here (for equipment purchased in USA or Puerto Rico):
If you have the latest firmware, try this:
  1. Switch off the camera and remove the CF card and battery
  2. Keep the camera idle for 30 min
  3. Clean all the contacts of the camera (battery contacts, lens contacts etc) with an eraser. Do this keeping the camera facing down so that no debris fall into the camera.
  4. Attach the lens and insert the battery.
  5. Switch on the camera
  6. Insert the CF card
  7. If the error persists, format the card again
  8. If this does not work, try using another CF card.
Feb 06, 2009 | Canon EOS 40D Digital Camera
Can not play back image. Box with yellow ? (question mark)
Possibly corruption of the card - if you are sure the images are backed up, then format the card.
May 17, 2017 | Canon EOS 40D Digital Camera
Cameras Logo
180 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
