Question about HP Office Equipment & Supplies
I can't get my Office Jet J5750 A-I-o printer to accept 150 Lb paper. It hangs up. I tried to load the 150 pound paper with and witout other paper. No help' And The printe continually asks for relignment. I tried two cartridges with the same result, which suggersts a sensor problem' The test page looks great. I was careful to remove the protedction tape before installation.
  • 300 Answers
According to page 266 of the manual found here, the printer will only accept a maximum of 145lb 4x6 photo paper.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 17, 2008
Paper keeps jamming in my fs2100 kyocera
One possibility regarding paper jamming is the weight of the paper you're using. For example some printers have difficulty feeding 20 lb. paper. I suggest that you first try loading your printer with a lighter weight paper, starting with 12 lb. paper. If that works, then move up to 16 lb. paper. If that fails, then consider cleaning the rubber rollers that control the paper feed.
Nov 02, 2017 | Kyocera Office Equipment & Supplies
I want to get a fax confirmation sheet to print on my HP office jet J5750
my HP Deskjet D2360 what is the promblem when i print are not the same the color pictures
Mar 04, 2013 | HP Office Equipment & Supplies
When i give print command the paper was jammed in printer.
The following sections describe how to load media into the different input trays. CAUTION: If you try to print on media that is wrinkled, folded, or damaged in any way, a jam might occur. Priority feed slot The priority feed slot holds one sheet of media up to 163 g/m2 (43 lb) or one envelope, transparency, or cardstock. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side media guides before feeding the media. Back to top 150-sheet main input tray The input tray holds up to 150 pages of 75 g/m2 (20 lb) paper or fewer pages of heavier media of 25 mm (0.9 inches) or less stack height. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side and front media guides. NOTE: When you add new media, make sure that you remove all of the media from the input tray and straighten the stack of new media. This helps prevent multiple sheets of media from feeding through the printer at one time, reducing media jams.
Also go to this link to do a Printer Cleaning
Dec 03, 2010 | HP LaserJet 1020 Printer
NI have a HP Design Jet 110plus nr after put the roll hi start to take the paper roll and take out the all roll witout control. Im chaged the OOPS sensor but is same problem can you help me to solve this...
Im chaged the OOPS sensor but is same problem can you help me to solve this problem
Oct 05, 2009 | HP Designjet 110plus nr InkJet Printer
What is the heaviest weight paper I can feed through my Office Pro 7680?
Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
Plain paper, 20 to 24 lb (75 to 90 gsm)
Legal size paper, 20 to 24 lb (75 to 90 gsm)
Card stock, up to a maximum of 110 lb (200 gsm)
Envelopes, 20 to 24 lb (75 to 90 gsm)
Photo paper, 145 lb (236 gsm)
Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
Aug 09, 2009 | Office Equipment & Supplies
Paper thickness allowed
Type Paper weight Input tray capacity Plain paper 70 to 90 gsm (20 to 24 lb) 100 Cards 200 gsm (110 lb) 20 Envelopes 75 to 90 gsm (20 to 24 lb) 10 Transparency film N/A 20 Labels N/A 20 10 x 15 cm (4 x 6 inches) Photo 236 gsm (145 lb) 20
Dec 27, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
Continuous paper jam when i try to print
Hi ,
Follow the steps below -
1. check the media / paper compatibility. It sould be as per hp :
Paper tray capacity Type Weight Capacity Input tray Capacity Output tray Plain paper 60 to 90 gsm (16 to 24 lb) 150 50 (20 lb paper) Legal paper 75 to 90 gsm (20 to 24 lb) 150 50 (20 lb paper) Cards 200 gsm (110 lb index max 30 30 Envelopes 75 to 90 gsm (20 to 24 lb) 20 10 Transparency film N/A 25 25 or fewer Labels N/A 30 30 4 x 6 inch (10 x 279 mm) Photo paper 236 gsm (145 lb) 30 30 8.5 x 11 inch (216 x 279 mm) Photo paper N/A 20 20 Paper sizes Type Size Paper Letter: 216 x 279 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm
A5 148 x 210 mm
Executive: 184.2 x 266.7 mm (7.25 x 10.5 inches) Envelopes U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches) Transparency films Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Photo 102 x 279 mm (4 x 6 inches)
127 x 178 mm (5 by 7 inches)
Letter: 216 x279 mm (8.5 by 11 inches)
A4: 210 x 297 mm (8.27 by 11.7 inches) Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Custom 76 x 127 mm up to 216 x 356 mm (3 x 5 inches up to 8.5 x 14 inches) Print margin specifications Paper size Top Bottom US Letter
US Legal 1.8 mm (0.07 inch) 3 mm (0.12 inch) ISO A4
ISO A5
JIS B5 1.8 mm (0.07 inch) 6.0 mm (0.2 inch) Envelopes 1.8 mm (0.07 inches) 14.3 mm (0.5 inches) Cards 1.8 mm (0.07 inch) 6.7 mm (0.3 inches) 2. paper should be placed to the right of the tray and a little inside with a min distance within the papers of .1 mm
3. open the rear access door of the printer (with grids) on the back and reval the rollers. Take a slight moist cloth ( not cotton ) and clean the rollers with it by moving them 4 times upwards.
4.open the cartridge door ad observe the thin plastic strio on top of the steel rod on which the carriage moves. Take a small piece of paper and hold the strip with it ands swipe it once witout applying much pressure as it could come out in any direction and as much as you can
5. make sure you replace the cartridge if its refilled. It could provide obstruction.
move the carriage 4-5 times continuously with as much speed and make sure there is no obstruction in the carriage movement.
6. press set up button on the printer panel - go to print reports - ok / enter - self test report - see if the paper jams. If not good.. If yes take a look into the next step.
7. pull out the power cable directly from the printer. Press and hold # and 6 button on the printer and insert the power cable and do not release the buttons till you see te display glowing blank or some processing happening. Release the #6. If the printer turns off then press on the power button to turn it on. Continue with country and language settins as apprpriate. Choose your country during this reset. Complete the alignmet then. Take a printout to see if the paper jams again.If yes - the printer definitely needs servicing.
Apr 08, 2008 | HP Officejet 7210 All-In-One InkJet...
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
