9 months ago I bought the asus motherboard and 3 things don't work... .1. the Ethernet adapter dosn't work (the computer can't find my modem even though it is all connected propally and both the speed and connection lights (on either side of the port itself) are on.
.2. I try and connect the case headphones attachments to there respective things on the motherboard and they don't work.
.3. the audio ports on the motherboard don't work (the ones coming out of the back of the case [not the sound card ones]).
Windows XP does'nt recognize my ethernet card on the motherboard
Best Solution
posted on Jan 25, 2007
Guest
Rank: Apprentice Rating: 0%, 0 votes
What it sounds like is that you didn't install the drivers. In order for sound and ethernet to work, you must first boot up the CD that came with the motherboard and install the Drivers.
Was this solution helpful? Show your Appreciation by rating it:
I am having the same problem with my ASUS P4P800 motherboard
I have just connected up with aol broadband I checked the device manager and found that my drivers for the ethernet card were not loaded unfortunately the cd disk that came with my motherboard and the manual have been inadvertently lost lol so I am now trying to download them from asus site in the mean time if that situation does not work I will have to buy an ethernet pci card and try that lol
Show your appreciation by commenting on ethernet adapter problem:
Solution #3
posted on Jan 31, 2008
Guest
I recently reformatted my brother's PC running this motherboard, and I have a similar issue with the nic. I get all connect lights to my router and from the card itself, and I'm online now on my computer on the same router. Have gone thru all the restarts and resets, have attempted to install drivers for it, several times, it won't take the drivers. I don't know why, I run the driver install (both from the mobo CD, and some I've downloaded from this machine and moved to the old one via a USB flash drive) when using ipcfg from cmd promt it still lists nothing, which tells me the stupid mobo just won't recognize any of the drivers I'm feeding it. Still working on a work around *sigh*
There is not enough information here to be able to identify to a great degree of accuracy what the true problems could be, but I will take a stab anyway.
Is it safe to assume that the current configuration has been working in all 3 aspects during the previous 9 months?
If this is the case, it is possible that your modem (if it is a cable modem) may need to be reset to acquire a new address. The activity and collision LEDs do not necessarily tell you that you are connected.
The headphones problem...possible that you inadvertently disconnected the motherboard connector and placed it on incorrectly while researching one of the other issues? This could also be the case for the audio connector. Double (and triple) check all cable connections to the motherboard to ensure they are in the correct orientation and location.
If the above is insufficient feel free to post more detail, such as did it previously work, did you previously install any new hardware and/or software, thunderstorms in the area recently, changes at your ISP? Good luck.
