Question about Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2
Nails won't shoot
Got a 18 gauge brad nailer. Hooked up to 100 psi compressor (my stanley staple nailer works fine). When I pull trigger, just a burst of air around trigger.
Is there anything I can do or replace?
thanks
    New Friend:
  • 3 Answers
My 18 gauge Bostich brad nailer would not fire, and air came out around the trigger. Even though the gun is advertised as oil less - this is what remedied my problem - a drop of oil. I put one drop of oil in the slot where the brads come out [realizing that is where the driver is located] and left the gun upright for some time. The next time I used the gun it worked just fine. A drop of oil can also be added into the gun where the air hose is hooked up. Do not over-do the oil process, but don't ignore it.
Posted on Mar 15, 2013
  • 5 Answers
I had same problem with my brad nailer. The piston inside the main housing seemed to be gummed up and sticking. There was a vent on the top of the cylinder for the exhaust. When I would blow through this vent it would push the piston down and the nailer would start working. This is definitely not a permanent fix but might get you through the current job before you open the cylinder and see why it is sticking.
Posted on Mar 31, 2009
    President:
  • Stanley Master
  • 1,388 Answers
18 guage nailer has a very thin driver and plastic cylinder which bends or breaks easily. Remove the head noting all the parts in the head and remove the piston which should be at the top of the cylinder. Check for broken or bent shaft. Most likely broken and jammed in cylinder. Parts are not expensive. Check WWW.toolpartsdirect.com for diagram and parts
Posted on Nov 25, 2008
Nailer is shooting air out of trigger, is not releasing brad
Sounds like the head valve. Remove the head cap take out the head valve, clean, re-fit and give it a few drops of air line oil. Then give it a try. Good luck.
Oct 19, 2014 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Brad nails crooked in bostitch
Have you inserted the correct Brad Nails? What is the code of brads you have inserted? Is the tool jammed?
Solent Products Air Nailing and Stapling Supplies
Mar 21, 2013 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
What kind ryobi p300 staples & brad nails
Nice little nailer Fred. Here are the details (sold at Lowes or other lumber centers).
Staple Size 3/8 in. Crown Width, 1/4, 5/16, 3/8, 1/2, 17/32, 9/16 in. length
Brad Size 18 gauge, 3/4, 1, 1-1/4 in. length
Magazine capacity 100 staple/brad Good luck with your projects
Oct 14, 2011 | Ryobi P300 One+ Stapler Brad Nailer
My brad nailer shoots staples without any problem but it jams on the second brad after being freed up from the previous jam. How to I rectify this problem. It is a fairly new stapler/nailer and has done...
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
Mar 26, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Not shooting
Trigger Valve needs replacing. Part Number is FA205BA1. The valve comes with instructions, its a pretty easy fix. Any BBostitch dealer should be able to get you one.
Mar 11, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
The gun will fire staples, nails do not set.
The business end should look like this:
Mar 07, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Shooting 2 nails at a time and then jams
make sure you are using 18 gauge brads in the gun. also if the brads have gotten wet or are old, the paper or wax coating on the becomes weak and it will release more than one nail at a time. try different brads in it.
Dec 15, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2 Logo
1,339 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
