Question about Fusion FEW12PK Car Subwoofer
Amplifier problem i installed a fusion sub and amp in my car the other week and it came on how it should for about 5 minutes then went back off again and i couldnt get it to go back on. a couple of days later i re-wired it to make sure everything was how it should be and it came back on, this time it was on for longer and i thought i had sorted it but sure enough a couple of hours later off it went again.anyone got any ideas? cheers cerin
Chceck if its not over heating. If its very hot move it to the different place or install a fan
Posted on Aug 23, 2007
  • 62 Answers
Check your grounds, and all of your wiring. Does it just shut off or does it blink and go into protection mode?
Posted on Mar 25, 2007
Power pyramid subs smoking i think the jl 1000/1 is tuned wrong..
If the sub is new, they need to be broken in.
All sub woofers need a break in period of about 5 to 6 hours at medium volume.
The reason is because the glue needs to be cured. This is done by the heat from working.
If you are giving it too much volume too soon, you are burning the glue.
Back off the subs and only play them at medium volume for about a week.
Nov 22, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Amp fuses blowing and amp overheat
Does the amp heat up if you power it up with no speaker wires connected to the amplifier's speaker terminals?
Jul 17, 2009 | Rockford Fosgate Punch P5002 Car Audio...
I have a 2channell FE-402 fusion amp,with a fusion sub,and a set of vibe k-series 69's that have a max power of 525 watts. I tryed wiring the sub with the speakers and the speakers sound fine but the sub...
Hello jackstephens,
It's an either/or situation. The FE-402 can be set up to drive normal speakers in stereo, OR drive a sub when both channels are bridged. When the LP filter is on, it benefits the sub at the expense of the normal speakers. And with the filter off, the subs get the full range of frequencies and try as best they can to reproduce them. You might try running it with the LP on, in stereo with the 6X9's paralleled to one channel (2ohm load), and the sub connected to the other channel (?ohm load).
But my recommendation would be to use the Fusion amp the drive the 6X9's and get a dedicated monoblock for the sub.
Hope this helps.
Jun 06, 2009 | Kicker KX500.2 Car Audio Amplifier
Memphis PR300.2 Amp protect light on
If it is not turning on your problem is it is not getting power. Check your fuses. The reason an amp goes into protect mode is usually because the subs are not wired up right. Make sure your fuses are good, you have a good ground, and make sure your amp turn on wire didn't come loose when you were putting the deck back in. As for the amp going into protect you probably wired the subs down to too few ohms and the amp you have can't handle it. Try hooking the subs up straight w/o bridgeing them and turn it up to see if it works. If you don't have problems with it then you wired your subs wrong.
Mar 22, 2009 | Car Audio & Video
Fusion car amp problem
The amplifier likely has shorted output transistors. Going to a higher rated could easily have caused more significant damage.
Let me know if you have any other questions.
Jul 27, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Car amp ( fusion fp-1002 powerplant ) is fried
blown capacitors. take to a friend or electronics repair that can replace with better capacitors. had same problem with an old comp 1200 amp. friend of mine replaced with better capacitors and wooohh mamma!
Feb 25, 2008 | Car Audio & Video
Subwoofer Wont Work
If the connections are correct...?
then it doesn't sound like theres a problem with the amp.
make sure the amp is not to powerful for the sub?
eg: 1000w amp, 500w sub.
Sounds stupid but it happens.
make sure the gain / volume is not too high!
if your BMW has a totally sealed, metal boot area this doesn't help.
Dec 11, 2007 | Sony XM-2150GSX Car Audio Amplifier
P3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Fusion FEW12PK Car Subwoofer Logo
133 people viewed this question
Top Fusion Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
matthew walsh
Level 1 Expert
Steve Sweetleaf
Steve Sweetleaf
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
