Question about Amana ACF3355 Gas Kitchen Range
Amana gas oven will not stay lit
The oven will turn on at first but will not stay lit. The broiler is doing the same thing. the burners up top work fine.
I'm having the same thing happen to me however the broiler works fine.
Posted on Jan 15, 2010
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Manual
When the range top burners and the oven are both not lighting, I recommend you check if the manual shut-off valve to the range has been turned off. With most of my gas ranges, you have to remove the drawer to reach the shut-off valve. (so If you have propane, make sure that your tank isn't low.
Make sure that your home is well ventilated; open the windows and check the range in a while. I live in an area where we had to add a whole house ventilator. We had days where the house would seem stuffy and none of the burners would light. (Appliances with pilot lights went out.) This was due to excess carbon dioxide shifting from nearby coal and natural gas deposits.
It is possible for the igniters to fail if there is power to the range, but usually not the oven, the broiler and all of the top burners at once. You can test the top burners carefully with a long handled butane lighter or a long match. Turn on the hood fan and set a burner to the Lite position. Carefully, light the lighter near the burner or bring the lit match to the burner. If the gas is flowing properly and there is sufficient oxygen, it should light. Then remove the lighter or match and put it out. Then adjust the burner temperature.
The manual for the ARGS7650SS is available from Amana. The direct link is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/31810401.PDF . Many newer Amana product manuals are available here: http://shop.amana.com/product_literature/search.jsp .
I hope this helps.
(note: you should also make sure that the regulator cap is correctly set for your type of gas (LP or NG). The gas flow rates are different enough to make the regulator fail. Most ranges are shipped for with the cap set for NG. Turn off the gas and unplug the electrical cord before working on the regulator cap. The burner orifices need to be changed as well as some other adjustments to convert from NG to LP. See pages 9-11 of the manual for details.)
Jun 26, 2013 | Amana ARGS7650SS Gas Kitchen Range
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    WHIRLPOOL Sup Cap 465 oven turns on for 3 sec, then shuts off
    The flame sensor is dirty or bad.
    When the unit does not sense flame after ignition, the gas valve shuts down the system.
    They can become corroded or dirty, but usually just need to be replaced.
    Contact whirlpool for warranty info. If the unit is under warranty, they should send you the parts for free. If not, they can direct you in how to order the part.
    http://www.whirlpool.com/custserv/email_form.jsp
    Sep 26, 2009 | Amana AGDS902 Gas Kitchen Range
    Amana gas oven not working
    SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
    Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
    The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
    Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
    Amana broiler problem
    Each burner manifold in the oven has its own igniter. If the igniter is defective, the burner assembly will not light. The igniter has to be functioning properly in order for the gas safety valve to open. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. This reduces the risk of explosions.
    There should be a flame spreader metal plate covering the access over the broiler. You will need to access the broiler so you can view the broiler manifold and igniter. Turn the oven setting to broil and make sure the igniter begins to glow. If the igniter fails to glow, replace it. If the igniter does glow, but you still do not have ignition after 90 seconds, the igniter may be weak and still require replacement. The following link explains oven igniter types, their current potential, and how to replace them:
    http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
    If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
    Jan 29, 2009 | Amana RanARG7302 Gas Kitchen Range
    Spark module clicks and gas will not stay lit, flame comes on but goes out
    hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
    Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
    Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
    Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
    Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
    thank u.................
    Sep 11, 2008 | Ovens
    Broiler glow bar stays on
    the glow bar stays on in gas ranges the whole time the cycle is running if it didn't the safety valve couldn't open its normal
    Jan 20, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
    Amana ACF3355 Gas Kitchen Range Logo
    439 people viewed this question
    Top Amana Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Sal De GO PATS
    Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
