Question about Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
Water won't get cold
Hot water works, but we can't get the cold water cold
  • 3 Answers
Next to the compresssor check for a solid copper obese tube, filter drier, touch this with your bare hands, and see if it is warm,if not the gas is not enough it being leaked from somewhere.
Recharge the system with freon gas.
Posted on Nov 17, 2008
I have an Estate 8cycle 2speed washer that won't fill unless the temperature selector is set to Hot/Cold. Any ideas on what I need to check first?
I bet If you switch the water hose around it will fill on cold and not hot. Reason I think so is that hot fills and doesn't use the cold line. So either you got a bad cold valve or a blocked screen. Also Try to run the hoses into a bucket and see if they run well to eliminate the water source.
Jul 29, 2013 | Washing Machines
Frigeadare stack washer n dryer
their may be a plug in the cold side inlet of washer that needs to be removed or the cold side water valve may be reversed.
May 28, 2013 | Washing Machines
Lg wf 801 won't fill
Yes , It can be related to the control board, but first of all please make sure that there is good water flows in both the inlets, check the flow after the valve , ensure that the inlet filters are not clogged and check all the connections from the harness to the valve and panel
Jan 19, 2013 | LG WM Washing Machines
My washing machine won't fill with water, water is going into the powder drawer but won't fill up the clothes barrel, I have checked the filter at the front and have done this many times so there...
Although you say that there is enough water for the dispenser it is well worth carrying out the following, especially because of the 'clicking' ;-0)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 18, 2011 | Washing Machines
Hot water works fine , but cold water does not get cold . model #WD31EC
Hi Deb,
The cold water is only the ambient temperature of the water on the inlet, it won't make it colder.
Hope this answers your question
Joe
Sep 07, 2011 | Washing Machines
Washer don't get the cold water only the hot cold water won't enter and the hot enter extremelly hot
(this covers both hot and cold but please read for cold! Your hot water supply provides the extremely hot water and is normally mixed with cold in the washer for the correct temperature.)
John C
Aug 27, 2011 | Frigidaire FWS833A Top Load Washer
Hot water won't run into washer
G'day. The hoses from your laundry taps hook up to your machine onto what are called solenoids. These are like electrical taps. The machine decides when to turn these on and off and in what order via the timer and depending on what modes are selected. Generally there is a hot and cold solenoid. If you have both hot and cold hooked up to your machine, you can simply swap these hoses around (put the hot tape on the cold solenoid and vis-versa) Then when you select cold, you'll actually be getting hot. Some new machines heat water internally like dishwashers, and they only have one solenoid. Again if you put the hot tape only on, you will get hot water with cold selected. In both solutions you are losing the option for cold or hot cycles with a click of a button - now you must swop hoses...
Aug 17, 2011 | Maytag Legacy MAV208DAWW Top Load Washer
Can we operate our WFS1273BD washing machine on cold water only? We are on instant gas hot water and have gone through a 45kg bottle in 3 weeks. We have lived in this house before and the washer is the...
ABSOLUTELY! Purchase a 'Y' adapter from your local hardware store and attach the hot and cold lines on the washer to the 'Y' attached to the cold faucet. You won't be able to wash in warm or hot without changing the hoses, though.
Aug 17, 2011 | Washing Machines
Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
443 people viewed this question
Top Whynter Water Filters & Coolers Experts
Tom Chichester
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
