Question about Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor
Compressor will not shut off
My Emglo AM78 will not turn off even when I move the lever to the off position. What could be the problem.
Thanks
Tom
My emglo electric air compressor will not shut off when it reaches 90psi that I set it for and it keeps going so I have to shut it off manually because I am afraid it will blow up if I don't shut it off . The switch works manually,;what is stoping it from working automatically to the pressure I set it at? Model # AM78HC4V
Posted on Jan 01, 2009
    Scholar:
  • 65 Answers
The switch is bad, replace it, this should solve the problem.
Posted on Nov 17, 2008
I have a dewlt dw55168 type 2.the compessor doesn't seem to keep up like it use to. does this need a new valve assembly.(I did check for leaks at the tank and pressure switch.)
Posted on Jun 02, 2010
Can i substitute common motor oil for the proprietary oil sold for my AM78 Emglo 2-tank air compressor?
Dewalt claims that motor oil will cause carbon deposits to form on piston/cylinder head and on the inside of the discharge tube. I see carbon deposits on most all compressors that come in for repair. The carbon is not reason for repair. Usually forgot to add any oil causing rod failure. I believe that most compressor oils are just mineral oil. If the climate in your area is moderate, and you do not use the unit for 8 hours a day, motor oil will work just fine. The crank is steel and the piston rod is made of aluminum (no bearing shell). What makes the unit last longer is change the oil more often (holds very little oil). Good luck
Aug 11, 2011 | Dewalt d55151 factory reconditioned emglo...
Emglo air compressor too much pneumatic fluid, how to determine correct amount?
What are you putting the oil in? The compressor takes regular non-detergent oil, and it should have a dipstick or a site glass. The guns on the other hand, take the pneumatic oil, and most of them now days, don't even take oil. Only the older ones. I haven't changed or touched the oil in my compressor in 20 years. Any of them. Check it out.
Aug 07, 2010 | Dewalt d55151 factory reconditioned emglo...
Hi I have a Dewalt d55141 emglo contiues to run
Open the shut off switch box and adjust the cut out pressure.
Nov 17, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
Owner's Manual for AM78-HC4V
Hope this helps:
http://www.jennyproductsinc.com/manuals/JennyCompressorManual.pdf
http://www.jennyproductsinc.com/manuals/AM780-HC2.pdf
Jun 17, 2009 | Jenny Products Inc AM780-HC2 1.5 Gallon...
Emglo compressor starts but stalls quickly after
Its not getting fuel. There is a low oil shut off switch as well that go bad. most just bypass this unit. its connected to the on off switch as a 3rd leg. try that
if not check your fuel delivery. either the fuel line pet **** is closed/ clogged or a stuck needle in the carb is causing no fuel
Mar 01, 2009 | Dewalt d55151 factory reconditioned emglo...
Manual for Emglo Air Mate Compressor
Manual for the similar dewalt model is at www.dewalt.com, click on parts & service icon, then enter D55151. Or try clicking here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/5135175-01,D55152,Elec.pdf This Dewalt compressor is one of many versions of the Old Emglo AM78 compressor. There are several other brands built with the exact same design such as the Senco line. For parts list of actual Am78hc4v go to mastertoolrepair.com. If you have questions or problems with this compressor please email, Good luck
Jan 28, 2009 | Dewalt d55151 factory reconditioned emglo...
Air compressor does not regulate pressure to set point.
Emglo airmate compressors are set from the factory to shut off at around 125psi. There is an adjustment (remove cover to pressure switch) that will controll the cut-off pressure but it is not recommended changing the factory setting. There is also a safety valve installed that will open at about 160psi. It is a small brass device with a pull ring. When things go wrong with the pressure switch (rectangular box with power cord coming out of one side) the safety will pop open. There is a pressure regulator with round knob on panel that will lower the pressure to the tool, however this regulator does not control the pressure switch. Let you compressor run untill it shuts off and verify pressure to be about 125, if it is then all as well. Good Luck
Jan 03, 2009 | Dewalt d55151 factory reconditioned emglo...
Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor Logo
710 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
