Question about Frigidare FGB24S5DC Gas Single Oven
Oven model FGF316ASA OVEN WILL NOT IGNITE
MY STOVE TOP LIGHTS AND IGNITOR WORKS
BUT WHEN YOU TURN THE OVEN ON THE IGNITOR GLOWS BUT THE OVEN DOES NOT IGNITE
  • tbugg30 Dec 11, 2008
    The top burners ignite, but the oven burner doesn't. The oven ignitor gets red hot, but the oven still doesn't light. Is there an adjustment?
  • michball101 Dec 31, 2008
    Mine is the same issue as described above . Any solutions?
    Sergeant:
  • 459 Answers
Change the igniter its just weak
cost around $65 for universal fit
takes 15min to change
Posted on Nov 20, 2013
My stove is about 43 years old and the round red igniter broke. I need a new onefor magic Chef Model#TZ-800C-3WP.Can I get a new one?
Hello Barbara,
Is the ignitor you need for the oven, stove top surface burners. If for the oven is it about a inch or so in round diameter and about 4-6 inches long with 2 wires to it and glows when oven is turned on?
the very old ignitors for the oven was a square/rectangle glow plug about a inch or so square
Which best describes the one you need?
Gene
Aug 09, 2011 | Magic Chef Ovens
Hoping someone can point me in the right direction. Oven won't light, but the stove top burners are fine. Don't smell any gas or any indication the oven is attempting to light....
next time send the brand name and model number so i can look up your machine,if it's a gas stove most likely it will be a bad ignitor,even if the ignitor glows it still could be bad,if the flame doesn't ignite and the ignitor is glowing change it out,if it isn't glowing pull out the ignitor and check it with a meter,common problem.
May 07, 2011 | Ovens
Igniter will heat up (glow), and oven may or may not light for 5 minutes (with igniter glowing). After heating, and stabilizing...once the oven starts to cool, igniter will glow again, and may or may not...
The stove should not take over 3 minutes to light. Even if the ignitor is glowing it is impossible to really tell if it is ok or not. When the ignitor heats up it's resistance drops, this allows for the amp draw to get to 3.2 amps or better and that opens the bi-metal inside the oven valve. The oven circuit consists of a control to regulate temp, a safety valve, a ignitor, and a burner. Any open component and the oven will not fire off. If all the components have continuity and the ignitor is glowing, but no joy, I would replace the ignitor. Usually the ignitor gets dim when it is weak and it takes a long time to light off and you might even have to bump the stove and get it to come on. Replace that ignitor.
Feb 02, 2010 | Ovens
My stove does not ignite even when glow light is on model 3127wtv
Turn off the gas supply to the range. Remove the oven racks,oven base pan,flame spreader.
Place a clamp on amp meter on one wire of the ignitor and turn the oven on to BAKE. When the ignitor glows it should read more than 3 amps. If it reads 3 amps or less replace the ignitor.
Jan 03, 2010 | Magic Chef Ovens
How do you light the pilot on a GE stove The top of the stove works
Hi, If this model has a standing pilot, use a lighter and put the flame to the back center next to the burner assembly. Most newer models have electric ignitors now. It is fastened to the burner assmbly on the laft side.
If this an electric ignitor, turn the oven on and see if the ignitor glows. These ignitors are a very common problem and will probavly need replaced.
Please let me know if I can assist youu further.
Vic
Jul 03, 2009 | GE JGRP17 Gas Single Oven
I have a Frigidaire stove, model fgf316asa, and the oven does not heat. The ignitor still glows but does not ignite the gas. I cannot hear the gas coming from the line. What's wrong?
Hi, You should change the ignitor. Even tho it glows, the ignitor is to weak to open the gas valve. UNPLUG the oven. Remove the floor panel in the oven and you sill be able to see the ignitor. This is very common with gas stoves.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | Ovens
Whirlpool super capacity 465 oven quit lighting
Check the burner ports near the ignitor for blockage. I had one of these units, and the ignitor was not mounted correctly, and caused a similar problem
May 02, 2009 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Gas stove
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Sep 04, 2008 | GE JGRP17 Gas Single Oven
Frigidare FGB24S5DC Gas Single Oven Logo
139 people viewed this question
Top Frigidare Ovens Experts
Dan Webster
Dan Webster
mburke3
Are you a Frigidare Oven Expert? Answer questions, earn points and help others
