Question about Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC D363 When Computer Completly Restarts when I Try to Pull any thing From Tape
Soon as i try to capture video with this camera using the USB cable my computer completly restarts!! Any idea? Something Major
I have the same problems. No fixs or any help at all on this issue. Seen a few other posts with the same problem but nobody seems to be able to figure it out and Samsung says it is your computer but I have formated a few times with differant versions of windows and still the same problems.
Posted on Mar 30, 2007
SOURCE:
I have a 1 GB/Kingston SD card in my Samsung SC-D363 NTSC Camcorder, and I need to know a Free Download Photo Software that can Pull up my videos to my computer.
Try this link @ http://www.samsung.com/us/support/downloads/SC-D363
Alternatively,
If your SD memory card is removable you can remove your SD card and use a USB card reader to transfer your files to your desired folder location to your PC.
Hope it helps.
Feb 20, 2011 | Computers & Internet
I need capture cam to computer
If what you want is to transfer it to the computer, then just transfer it after capturing the video using an usb chord.
If what you want is to use this as a digital cam, then you have to install a certain software.
Dec 03, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
Hi i have a samsung digital video camcorder vp
try this link.
http://www.celartem.com/en/download/select_lang.asp
May 11, 2009 | Samsung SC-D363 Mini DV Digital Camcorder
My samsung sc-d363 wont upload
you have to use a firewire cable to upload to computer! I had the same problem! Good luck
Jan 09, 2009 | Samsung SC-D363 Mini DV Digital Camcorder
I want to copy video footage from the tape to the sd card.
Hi!
You cannot transfer the video from Mini-DV to SD card within your camera as your camcorder does not have this feature. If your purpose for finding this function is to transfer your footage to your computer, you may try using the firewire port in your camera to connect it to your pc.
If you need help with the firewire connection, feel free to post a follow up.
Hope this helps!
Nov 11, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
System restarts when I try to capture video
i had a similar problem (other camcorder) and the problem was a software that i had installed before (video coders, and some programing libraries that got missinstaled )... (it worked many times before that).
U can try to change u're capture software, or try a OS reinstall ....
Jan 24, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Software does not pass windows xp logo test
spider1976,
A FireWire connection would definitely help you out here, as they are designed to be much faster and of better quality than a standard Universal Serial Bus (USB) connection. Whoever told you USB is faster is definitely misinformed, or have unusual software issues with FireWire
Jan 03, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Don't have cds for SC-D363 to use with PC
I have a Sc-D365, which as I understand it, the same as the SC-D363 but has a couple more bells and whistles. You need to download the drivers and other software so it will talk to your computer. Go to : http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=SCD363&dType=D&vType=L&mType=&model_cd=&menu=&language= to download the stuff you need. The page will have a tab for each of: "Manual", "Drivers", "Software" and you ll have to select each tab to get the files you need in each category. You will also need to buy a Firewire cable (IEEE 1394) with a small male connector on one end (camera side) and a regular sized connector male on the other (computer side). If you don't already have a Firewire interface on your computer, you will need to get one. That's the only way you can get the video from the TAPE. You will also need to get a USB cable with standard USB male on one end (computer side) and mini on the other (camera side). Once you download the User's Manual, it lists the part numbers of the USB cable and the analog cable to connect it to the TV. The USB cable is used to transfere photos and video files stored on the Memory Stick PRo memory module (user-supplied) and to stream live video to your computer. I use my SC-D365 for webcam applications in video conferencing, it works rather well for that, too. Good luck!
Sep 08, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Fire wire and video driver problems
Horizontal bars on the LCD display is ONE indicator of a dirty playback head on the camcorder. Purchase a head cleaning tape (Bestbuy, Target, etc., for about $20) and try cleaning the playback head. I had to do that on my SC-D365 yesterday (9/7/07) and it cleared up the problem. Good luck!
Aug 09, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D363 won't load to my computer
If you are trying to move video that is stored on TAPE, you need to get a Firewire cable. Using the USB cable, you can only transfer photos and video that is stored on the Memory Stick Pro memory card (user-supplied). The Firewire cable has a standard IEEE-1394 male connector on the computer end and a mini IEEE-1394 male connector on the camera end. If you don't have a Firewire interface on your computer, you will need to get one. Good luck.
Nov 21, 2006 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D363 Mini DV Digital Camcorder Logo
62 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
