Question about Zenith VR4257HF VCR
Possible Video swich failure?
During playback, my vcr's video signal fails to switch over thus continuing to display what is on my tuner. However, the audio DOES switch over like it's supposed to. Is this a common problem? The VCR is getting some age, but I hardly use it because I mostly deal with DVD's these days. I'm hoping that the circuitry responsible for playback video switching is in the form of a bad connection or easy-to-replace components and is not part of a static-sensetive and expensive IC. If simple, I see no reason to buy a new vcr being that no new machine can compare to this one. I'm also expecting to transfer any irreplacable must haves in my VHS collection to DVD/Blu-Ray within a couple years. And since I've hardly used this machine, a fix should buy me the time I need until I phase out my VHS. I'd appreciate it if someone can help me. J
  • VEE01 Mar 22, 2008
    I have my vcr connected to my TV and push play, it rewinds and cut off. I have my cable to vcr and vcr to tv, is that wrong
    V of NC
5 Suggested Answers
  • 579 Answers
SOURCE: Need help recording with my Zenith VR4206hf
Depends on what you have for digital cable, but assuming you have a connection for that, you don't need to worry about the other inputs, just find the on-screen menu page that selects the proper input.
Posted on Dec 29, 2007
Danmart
  • 291 Answers
SOURCE: dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
Posted on Aug 16, 2008
SOURCE: want to purchase a vcr/dvd recorder combo for our hdtv
decided not to buy one
Posted on Jan 19, 2009
  • 4 Answers
SOURCE: No video on VHS tapes playback. on a Zenith VR4257HF
Sounds like the video heads are worn and time to replace them. You can try Asti Magnetics. The part number you are looking for is "378". Sells for $55 plus shipping. A bit cheaper but quality parts. I've dealt with them in the past. You can decide if the VCR is worth it to repair.
Posted on May 04, 2009
Can I records from a LC195EMX TV
No you can't output the video signal from the LC195EMX's tuner to another device. It only has video inputs to obtain the signal from a DVD or Blu-ray player, for example. There are audio outputs to use with a sound system or headphones. Thus you could record the audio track, if you desired.
The manual for the LC195EMX is available from Emerson: http://www.emersonaudiovideo.com/support/download_tv.php?id=6 . You will need some sort of a set top box to record to a DVD/VCR recorder with either an analog tuner or no tuner. (OTA digital to analog converters connect easily to DVD recorders. For best signal, use a switch to feed the signal to the recorder, instead the TV. Splitters can be used to feed both at the same time. However, the signal loss could make either or both devices unwatchable with the digital OTA signal. Amplified splitters can reduce this issue; however, I've had the amplifier fail on several occasions. Then the amplifier blocks all of the signal or blocks select channel frequencies.)
I hope this helps.
Sep 27, 2013 | Emerson LC195EMX 19 in. TV
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
Tv is on when plugged in but doesnt respond to any button inputs.shows "snow" on the screen but nothing more. Model is 42wp48a toshiba 42 inch plasma.
This is a display device or monitor only. It lacks a tuner, so there is no way to connect an antenna and tune off air TV channels - and as such; fails the definition of a TV. A TV by very definition is a monitor AND a tuner. Without the optional "RTB421 RCA Terminal Board" installed in the monitor, it can only accept a PC Input signal (VGA).
If the RTB421 is installed, you will be able to choose from PC, Video, S-Video and RGB signals. The full details on this RTB421 Terminal Board and how to connect source video devices for playback is explained on pages 32 through 35 of the manual.
If the RTB421 is installed, and connected to a source video device (Cable TV converter, Satellite Tuner, Blu Ray player, DVD, VCR, etc.) as shown in the manual, you should be able to scroll through the inputs by pressing the Input button on the monitor or remote (make sure the batteries are fresh). Keep the lower left bezel of the monitor clear of obstructions that can block the infrared (IR) remote receiver window.
I hope this helps and good luck! Please rate my reply - thank you.
Feb 27, 2011 | Toshiba 42WP27 42 in. Plasma Television
When I record a movie on the vcr it plays back snowy.
Ur VCR signal recorded free air throught an DTV converter box?Yes,this cause is normal,because VCR player have no digital tuner on the VCR player by itself,on it circuitries design.If recorded throught pay cable signal.Yes,than ur VCR video head player is dirty needed to be clean.Tries websites like Amazon.com,Ebay.com to buy a VCR video head cleaner vdeo tape.Just play it as normal as a video tape,when the video head clean,VCR will display clean head eject tape now.
Aug 03, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My RCA 52in. has a blue screen... Will not show a picture?
  1. Check menu to make sure a signal is present. try video 1 with a external video source such as a VCR. If this produces a picture check for tuner signal by hooking the VCR to the antenna and tuning to channel 3 or 4. If their is no picture check antenna connector on back of set for looseness. If loose resolder antenna connector in tuner. If all these test fail the tuner may be defective and will require replacement.
Oct 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR with intermittant audio and video problems
you have to connect VCR output cable to your TV input, thats all, it will be in series, if u want to record any program then on your TV and on record switch of your VCR.
Dec 30, 2008 | Sony SLV-N55 VHS VCR
Sony SLV-640HF Problem
I would be inclined to say that there are only two likely problems that you may be encountering. Either you are getting a bad signal feed, or the connectors on the cable are getting old and need replaced. The connection to the cable can break down over time, especially if they have been connected and reconnected several times. I cannot rule out problems caused by the transition to DTV, but that doesnt seem likely if there are only a few channels affected. As far as "selective failure" of the VCR's built-in tuner, I would say that that is also a very unlikely source for the problem If the tuning components inside the tuner had gone out, I would expect to see a problem on all channels watched through the system. If you are having this problem on all channels of the sony, then the tuner could surely be the problem, but if you haven't used it much that would indicate a problem at manufacturing, however since at least one of the machines is working fine on some channels and not on all of them, I would suspect the connections or the signal from your cable company. Contact them first ands see if they are having signal issues, if not try replacing your connectors.
Dec 26, 2008 | Sony SLV-N55 VHS VCR
Poor playback
Because the cable signal is OK, this eliminates the tuner as your problem and leaves the power supply which is a common problem. It is a switch mode type which often have trouble maintaining control of its output voltages and produce trouble downstream in the video circuitry. Either the power supply is failing which can be wholesale replaced for about a $150, or something somewhere else is failing and loading down the supply causing it to overwork. Usually in this case, you can hear a whine noise if you listen close.
Dec 28, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
RCA audio/video receiver fallacies......
Sounds like overheating. Make sure it is clean and has good ventilation. Try putting it in a cold location and see if that makes a difference. Or get some cold spray and see if that helps it to turn back on quickly after it fails. If it works properly, but is just shutting off, possibly the output amps are starting to lose efficiency and if nothing is done will continue to degrade until you have a real failure, which will at least be easier to troubleshoot.
Dec 24, 2007 | Televison & Video
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
