Monitor wont come on
When i plug it in the power light flashes so it see,s to get power
but it wont come on at all
  • BGG1 Apr 10, 2009
    Siva2008,
    Do you happen to have a schematic for this board? I think I know which Cap you are speaking of, but I am not sure where IRF 630 is located? Thanks
    New Friend:
  • 62 Answers
1. first cheak the horizontal transistor.& IRF 630 , Output diodes
2. Change the LOT, Solder the dry points in neck board.
Posted on Nov 22, 2008
My computer monitor wont start up
try pulling out the power plug to the monitor and then plug back in and turn on monitor.
I am assuming you plugged the DVI cable back in to the correct port on the monitor and Mac Pro.
May 03, 2016 | Computers & Internet
Marshall sd monitor wont power up
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your Monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | Marshall Electronics V R84DP SD 84 144...
Why is the power light on my Acer monitor flashing?
See this.. http://www.techsupportforum.com/forums/f25/acer-monitor-is-blank-and-power-light-flashing-green-318760.html
Also, here's some tricks I would try...
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Acer Computers & Internet
Monitor is slow coming on then when on website clicking out of second tab flashes black
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Acer AL1716 17" LCD Monitor
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
Touch screen wont turn on power light keeps flashing green, rapidly, worked right up till we moved it to a new computer. what do i do?
It may be that the cord you have plugged into the tower either a.) doesn't like the plug in or b.) your going to need to adjust power and voltage settings to the monitor
Oct 30, 2010 | Elotouch 17" LCD Monitor
The monitor wont work
plug back to vga and setup multy screan c
Jun 25, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
NO PICTURE
Bad power supply. The light is green when it is not plugged into the monitor because there is no load on the power supply. When you plug it in the monitor tries to draw current, nothing the PSU can handle now, so the light blinks. The PSU can not provide the amps that the monitor needs.
Get a new power supply, you can find them on ebay. Just make sure the voltage and amps match. It is ok to buy a power supply with a higher amp rating, the monitor will only take what it needs. Also make sure the power plug that plugs into your monitor matches.
Nov 16, 2007 | Neovo SX-19A (Black) 19" LCD Monitor
Computers & Internet Logo
866 people viewed this question
David Payne
David Payne
