Question about NetGear DG834G 54 Mbps 802.11g Wireless ADSL Firewall Router w/4-port 10/100Mbps Switch (NTWRNGDG834G)
No wireless connection
Hello, I am a subscriber to AOL Broadband and have purchased a wireless router, sadly I cannot connect wirelessly, however, I can connect via ethernet cable. I contacted Netgear as AOL seemed very reluctant to help and told me to ask them. I was on the phone for 58 minutes (premium time) they obviously could read what was happening over the internet, ping IP adress, ping Yahoo.com ping here ping there. Complete waste of nearly an hour. I really need someone to give constructive options in the hope that I might resolve this problem. All I wanted was to go on line without cables lying all over the lounge. I am using a new Toshiba Satellite M50 laptop and have Centrino Mobile Technology so adaptor is built in. O.S Windows XP. Configuring seems to be the problem. Sorry but I am no expert, just a basic user. Thanks for any help that comes my way.
  • lfc2606 Jan 21, 2008
    Was this ever solved - I have exactly the same problem and it does not appear to be an issue with the PC and Modem link - this is to do with the link between the modem and AOL. All works fine when wireless is disabled but as soon as wireless is enabled on the modem (through it's settings page), the internet connection dies.
Also try turning off ALL firewalls you have enabled, i had the same problem, on phone to netgear for over an hour and it was that simple!
Posted on Aug 14, 2008
Some netgears require you to upgrade firmware before they will work wireless, use the disk to set this up, it is the easiest way. Also make sure your laptop wireless is switched to on, I see them turned off all the time.
Posted on Nov 18, 2007
    President:
  • 2,961 Answers
The problem maybe that, you need to set up the router first via an RJ45 cable and enable wireless connections, as you already have said, but probably left the cable connected. You need to then unplug your RJ45 cable from the laptop and router as you cannot connect both wirelessly and wired at the same time, as the router is trying to give the same IP address to two different connections. Your laptop should be wireless enabled(check in the device manager, as it maybe dissabled, as some manufacturers do by default.) Do not have your router WEP or WPA encrypted until you have set it up. Your laptop should also find your connection and probably others in your neighbourhood as it should auto find other connections. Right click on wireless connections in your connections folder and see if it has found your connection then click on connect. Hope this helps
Posted on Dec 01, 2006
  • andrew pester
    andrew pester Dec 01, 2006
    Can i just add that you may need to enable DHCP in your router, so as the router can give your laptop an automatic IP address, so just double check.
    Your laptop should also be set at 'Obtain IP Address Automatically' in your wireless card properties.
  • andrew pester
    I should also say when i said you cannot connect wired and wirelessly at the same time I meant through the same PC, you can connect via both as long as it is via different PC's.
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Nov 02, 2010 | NetGear WGR614 54Mbps Wireless Router...
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
The wireless light does not light up at all. and I cannot connect to wireless.
It may not be compatible with your broadband provider. AOL customers can only use Netgear Router's as no others work with it.
Dec 12, 2009 | Belkin (F5D5231-4) Router
Compacq Presario CQ60-419WM, can't connect to AOL.
Its true that you need broadband to use the router and then need the router for wireless networking.
Nov 03, 2009 | Computers & Internet
New laptop want to connect but forgot key
what you want exactly?password for what? username and password for internet in subscriber? or just WEP for wireless key password?
if you forgot the password for username and password for subscriber....theres an option,i dont know what kind of subscriber do you have in your country...if you forgot the username and passowrd you can ask in the subscriber.
regarding in the WEP password for wireless,it doesnt matter,try this..
type 192.168.1.1 in the internet toolbar
username:admin
password:admin
and you can see the configuration,check the wireless settings for WEP...
Jan 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
How do i get connection using belkin wireless g plus mimo notebook card i have only the card is there still a way i can connect only having the card that goes to my laptop. or do i need a router or can i...
1. If your laptop has a built-in wireless adapter, then you don't need a belkin wireless g plus adapter.
2. You can connect to the Internet using your adapter provided that the location where you at offers wi-fi or wireless connection
3. If you want wireless connectivity at home, then you need to have a wireless router and subscribed for DSL/Cable broadband connections
Nov 07, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Edimax wireless-g broadband router
please confirm if the router is a 6104K, or a KP or Wg or another model as the K and KP are not wireless, a "W" will denote wireless capability...
Not all manuals are available for download from the Edimax website but heres a start...
Connect the router to your PC with a cable... leave the modem disconnected to start with
open internet explorer and type in enter the default IP address 192.168.2.1 (broadband router’s IP address) into your PC’s web browser and press <enter>
This should bring up a user/password dialog box. By default the user name is "admin" and the password is "1234".
Confirm you are getting this far and we'll go the next steps
Jul 06, 2008 | Edimax BR-6104K Router (br6104k)
Wireless Connection
Follow trhis posting as I'm working a pretty much the same prolem
Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
trying to get a laptop on aol
Hi We are trying to connect to Aol by laptop.... More...
Jeff
Feb 08, 2008 | Computers & Internet
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Computers & Internet Logo
112 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
