Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
LG Dishwasher Mode LDS5811
The LE light comes on about 5 minutes after I start the dishwasher and then it won't do anything.
  • 1 more comment
  • dsubarurx Nov 19, 2008
    I have the same error code LE , and I replaced the motor and still have the same error code . and I have called LG and they confirmed the open motor . I think I am going to change dishwashers . Has anybody called around and found a lot of people that will work on these appliances , I found one willing to work on it if I paid him directly and collected my money from the factory . Check for yourself see how many people are willing to work on LG products and those that will say you cant get parts .
  • ggoode Jan 09, 2009
    I don't really know what I'm doing...I just checked this website to see if I could find out what the LE code is. But I have to report the same problems...water standing at the base of the dishwasher and after about five minutes the LE light comes on...it shuts every function off. If this is a common problem, you would think that LG would have a solution for it.
  • rickm10 Mar 19, 2009
    I have the LE problem also.
    Online chat with LG said this:
    : It means the motor or a part near it is needing service.
    and gave me the numbers of 2 service centers here.
    Paid good money for something that only lasted less then 2 years!
    Problem Solver:
  • 5 Answers
Try checking the wiring in the door for breaks and repair by cutting and splicing with electrical tape. This site has the Service Manual: http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Posted on Apr 03, 2009
When the LG dishwasher come on it try to start then le flashes and it dost start what do i do
You have a water fill problem.
Make sure the water supply is turned on.
Could be a bad water valve,bad wire bad timer,etc.
Copy and paste this Factory Service manual to help in diagnosis.
It may not be specific to your model number,you did not post a model number.
It should help generically.
Sep 14, 2010 | LG Dishwashers
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
I use my diswasher in two year 10 times last night i put some dishes and 5 minutes latter i have LE code I read is a motor imposible i rare use the machine
all it means is that something is jammed inside the motor unit. could be a hard item like piece of bone or hard seed that missed the filter. Or could be a spoon or something jamming the impeller arm.
If you are confident in opening the base then check the service manual for details
Jan 21, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
LE error message
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
Good Luck!!
Dec 11, 2009 | LG Dishwashers
LE indicater
I have had that where the filters are dirty,
check and clean filters at base of dishwasher.
Chris
lg durban
031-7165444
Jan 22, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error code LE shown on a LG dishwasher model LDS5811ST and this code is not given on the standard error code list.
Hello JA12345,
Here is a link to the service manual for your dishwasher. Page 25 discusses the error code...
Hope that helps you resolve your problem..
Regards,
Rick
Dec 13, 2008 | LG Dishwashers
LG Model LDS5811ST error code LE
LE is a motor problem.. You can find details in the service manual at this website link... http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Page 25 discusses that error code and possible solutions
Hope this helps...
Sep 06, 2008 | Dishwashers
LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
Aug 20, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
Aug 09, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
325 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
