Question about NEC AccuSync LCD71VM 17" LCD Monitor
Picture on monitor is distorted
The picture on my monitor is oval shaped and shortened on the sides. I was fooling around with the three buttons on the panel and I can't seem to restore the settings. My monitor picture was dimming periodically and I thought if I degaussed it, that would get rid of the dimming. Should I go back to the three buttons and try to adjust them again? I don't have directions from the manufacturer. Thank you.
  • s_shechter Nov 17, 2008
    Does dimming or flickering of the picture mean that magnetism has built up in the cathode tube, or is the cathode tube getting old or burnt out?
    Thanks!
I went to the panel buttons, and then punched the reset for each of the icons on the menu. That restored the display picture to its factory settings. The degaussing did not help the picture, and any stray magnetism is generally automatically degaussed when the computer starts up. As to the flickering of the picture, that is because of the refresh rate. I am using a relatively updated operating system, and the refresh rate has changed somewhat. I also believe the temperature of the computer affects the flickering. I hope this comment helps someone who has a similar problem.
Best regards,
Posted on Nov 18, 2008
Everything is distorted and elongated
You need to set the PC video resolution to the native resolution of this monitor, 1920 x 1080 @ 60Hz for best picture and correct aspect ratio.
You may have to load the driver if you cannot get the PC the let you select this resolution.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | Acer X233H 23" Monitor
The desktop and applications are stretched
right mouse click on the desktop and select properties. Then go to the settings tabe and change the resolution. A picture of the screen shape on that window should give you an indication of whether or not you have chosen a compatible resolution
Jan 06, 2010 | Acer P221W LCD Monitor
Rear projection - convex distortion / ghosting / expanding screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Producing distorted images when zoomed
Barrel ether missing guiding pin(s) or broken plastic guides. Parts are available only as a whole Zoom Block Assembly.
Mar 18, 2009 | Kodak EasyShare P850 Digital Camera
Picture problems
check for cold solder joints around the flyback transformer and a open pico type fuse very close to it. they are rectangle in shape and ususually the one in the middle of the three is the culprit. The problem is in the pincushion circuit
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Fuzzy picture, oval shaped, scrolling up slowly
I would start by checking the large filter capacitors in the power supply. I can't be sure since I'm not seeing the set, but it sounds like you're describing AC ripple. In a 20-year-old set, some of those electrolytics will be drying out. A few replacements may take care of the trouble for you.
Jan 01, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Oval shaped picture problem with Mitsubishi WS55807
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Nov 21, 2007 | Mitsubishi WS-55807 TV
Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Oct 24, 2007 | LG LRSC26980 25.2 cu.ft. TV Refrigerator...
NEC AccuSync LCD71VM 17" LCD Monitor Logo
208 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
