Question about GE DBXR463GB Gas Dryer
Dryer won't stay hot....
I have a GE DBXR463GD1WW that is about 4-1/2 years old. I have never had a problem until now. When the dryer first starts up it gets hot for about 2-4 minutes. After that it cools down and does not heat up again unless you restart it. Any ideas or help will be much appreciated!!
  • Anonymous Dec 09, 2008
    my gas dryer starts and works for about 4min then the gas go off
    Sergeant:
    Champion:
  • 324 Answers
Change your coils at the burner.
check the vent for blockage.
Posted on Nov 19, 2008
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Ge dbxr463gd1ww
The igniter heats the thermocouple which, in turn, opens the gas valve. The igniter could be on its way to failure because it is not staying energized long enough to heat the thermocouple. The thermocouple could be defective as well.
Nov 26, 2013 | Dryers
I have a GE front loading dryer model # DBVH512EF0WW. It's about 1 1/2 to 2 years old. It has worked perfectly up until this point. When we push the start button, it just beeps twice, but does not...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 13, 2011 | GE DCVH515GF Gas Dryer
I have a GE gas dryer model DBXR463GD1WW, the problem is that it star the flame but dont heat enough for dry the cloth I change the sensor in the flame but it still have the same problem
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 03, 2010 | GE DBXR463GB Gas Dryer
While running the dryer periodically makes a loud rumbling noise. GE DBXR463GD1WW
That rumbling could be worn or bad glides. 7efc7d5.jpgd3f6bc6.jpgb034ff0.jpgGo inthere and clean it up.ec417ea.jpg1e87790.jpegd4df180.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 22, 2010 | GE DBXR463GD Gas Dryer
My dryer stays hot
Hello, I'm going to assume this is a Electric dryer since you did not mention :) Ok your problem is with your heating coil. Basically what has happend is the coil has broken and the end that is wired strait to the electric supply is touching the chassis of where the heater is located, You should replace the heating coil and this will solve your problem :) You have a nice day and if there is anything else i can help you with please feel free to comment again. Thanks for using Fixya!! Mike
Jul 23, 2009 | GE DPSR610GGWT Dryer
Ge dryer staying hot even when it's off
This could be a stuck main timer control or thermostat. I recommend you un-plug the dryer until the problem is located. You don't want to start a fire or do more damage.
Mar 28, 2009 | GE DRSR483ED Electric Dryer
GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Dec 21, 2008 | GE DPSR610GGWT Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
GE DBXR463GB Gas Dryer Logo
362 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
