Question about Fisher and Paykel GWL11 Top Load Washer
240 Volt Connector Order
Silly me forgot to write down how the 240 Volt power cord connectors and earthing connectors were orientated. Has anyone worked with the GW712 that could email me picture of how the connectors are placed back on or have a wiring diagram? I do have a JPG of the way I have currently connected but cannot see how to up load it. I do not know how to earth it correctly as I have a left over conector.
Thanks in advance,
Mark Street
  • mstreet Nov 17, 2008
    I know the user manaul calls for an authorised agent. I have serviced the machine myself and removed the power cord when I serviced it. I cannot remember where all the grounding wires are connected to. I do have a picture of what I am talking about but cannot see how to upload it. Can anyone provide me the electrical schamatics?
    Regards,
    Mark Street
    I do have the spare parts manual but it does not show you how to plug in the returns and ground.
    I have uploaded a JPG if anyone knows how to plug it back in it would be appreciated.
    Regards,
    Mark Street
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to here is the manual
http://www.casa.co.nz/Motors/Stepper/F&P/SmartDrive-Parts-MW511,MWC11,GW511,512,611-25p.pdf
Posted on Nov 17, 2008
  • 905 Answers
There is a little icon where you type your words in( its geen in color click it to browse for your picture to upload from your computer)
I can say that there will only be the two hots and a return but this is all I can find on your washer http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/WASHERS_DRYERS/517751%20Washers%20Ph%206%20Series%2011&12%20MW511,MWC11,GW511,512,611,6.pdf
example
  • jason Nov 17, 2008
    do you have a wire setup like this : red wire / hot , black wire / hot , green / ground ?
    the white connector has different connecting ends than the black one , but those plugs have the two wires coming out but they are the same line
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
If the Power Cord of your autowasher is damaged it must be ... (Refer to Fabric Softener page 23).
Click this Link
http://www.fisherpaykel.co.nz/admin/pdfs/pdf_usecares/420983_Smartdrive_UC_UD1.pdf
Thanks
Good Luck
Howw do you make a Samsung bd-F5700 blue ray player operate on a 240 volt power supply
You'll need to bring the voltage down to 110-120 volt. Travel converters do this cheap and effective. The player only uses 12 Watt according to the manual. You could use an old 3 prong extension cord to cut of the connector to connect to your power supply. Get the converter below and plug it into the adapter, who then will fit in the extension cord.
25361686-pcx3svhkvlazjixsdsr3jt1v-2-0.jpg New 220V to 110V Step Down Voltage Converter 50W Travel Power Transformer 25361686-pcx3svhkvlazjixsdsr3jt1v-2-3.jpg Generic Round Europe to USA Plug Adapter
Jan 09, 2015 | Samsung Televison & Video
Hi, in Antec 300watt power supply there is 3 cables or input or current 220volt. The cables are Black, Green and white. Which one is earth, which on is live(positive) and which one is negative?
For 120 volt operation use
black for the hot, White for the natural, Green for earth ground.
For 240 volt operation use;
Black and White for the 240 volt and Green for earth ground.
Black is generally designated as the "Hot" or "positive" .
You must make sure the switch on the power supply is set for the voltage you are using. ie: 120/240
Dec 15, 2014 | Antec Computers & Internet
Fault finding
Power is going to the motherboard, and you know this by assuming?
An assumption would be you see the Power Supply fan spin, LED lights light up, and maybe computer case fans spin.
Not an assumption, and you would have tested the 3 main voltage power rails, coming out of the Power Supply.
The Power Supply in your computer is an SMPS.
Switched-Mode Power Supply. (Also is known as the short abbreviation - PSU. Power Supply Unit)
http://en.wikipedia.org/wiki/Switched-mode_power_supply
The Power Supply in your computer is a Converter.
It converts HIGH AC voltage into 3 LOW DC voltages.
[Depending on country,
USA = 120 Volts AC. UK = 240 Volts AC. Japan is 100 Volts AC, but may depend on area. Australia = 240 Volts AC. India = 240 Volts AC. HOWEVER, do not write the above in stone. I may have made an error ]
The 3 low main DC Voltages coming out of the Power Supply is;
A) 3.3 Volts DC
B) 5 Volts DC
C) 12 Volts DC
Orange wires carry 3.3 Volts DC
Red wires carry 5 Volts DC
Yellow wires carry 12 Volts DC
ALL Black wires are Ground wires. They can also be called Negative wires.
This is a DC circuit now. There is a Positive, and a Negative.
Orange, Red, and Yellow wires are power wires, and also Positive wires.
The first part of your diagnosis will be to test those 3 main voltage power rails.
[Digressing;
Using an example;
There are many Red wires coming out of the Power Supply.
These are 5 Volt wires. They are Connected TO, the 5 Volt power rail in the Power Supply.
ALL 5 Volt wires end in one place, in the Power Supply.
The 5 Volt power rail.
When you test just ONE red wire, you are testing the entire 5 Volt power rail coming from the Power Supply.
This also goes for the Orange wires, and Yellow wires ]
With the Red 5 Volt wires, and Yellow 12 Volt wires, you could just use a 4-pin Peripheral power cable to check them,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Multimeter set to DC Voltage, the red (Positive) probe lead of the multimeter; touches the female metal terminal connector, for the Red wire.
http://www.mcmelectronics.com/product/28-9420&utm_medium=Affiliate&ref=cj&utm_campaign=CommissionJunction&utm_source=CommissionJunction?t=2&utm_expid=8634549-14
The black (Negative) probe lead of the multimeter, touches a female metal terminal connector, that goes to a Black wire.
You should be reading 5 Volts DC.
Same thing for the Yellow 12 Volt wire.
With an Orange 3.3 Volt wire, this changes.
A straightened out paperclip is inserted, down into the BACK of the ATX main power cable's connector; AND into a socket hole with an Orange wire in it.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The straightened out paperclip, slides down into the socket hole, with the Orange wire in it.
Slides down into the socket hole, RIGHT NEXT TO the orange insulation of the wire, and MUST go down far enough; to Touch that female metal terminal connector.
EVERY wire going down into the ATX main power cable's connector, ends in a female metal terminal connector.
Same thing is down with a socket hole that has a Black wire in it.
ALL Black wires are Ground wires. (Negative)
You can choose ANY socket hole that has a Black wire in it.
Now touch the two probe leads of the multimeter, to their respective straightened out paperclips.
Red (Positive) probe lead of multimeter, to straightened out paperclip in Orange wire socket hole.
Black (Negative) probe lead of multimeter, to straightened out paperclip in Back wire socket hole.
You should be reading 3.3 Volts DC.
(Or if your multimeter kit has special probe lead, that would take the place of a straightened out paperclip, of course use it instead)
Know this;
A) If ALL of the LED's ('lights') were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical CPU (Processor) can use 51 to 130 Watts of power.
Just depends on what Processor (CPU) it is.
This is why a Power Supply with a weak voltage power rail, will not have enough power to turn the Processor ON, but will have enough power to light those simpy LED's, and spin fans.
[LED - Light Emitting Diode ]
Regards,
joecoolvette
May 11, 2013 | Dell Computers & Internet
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
Apr 18, 2017 | Televison & Video
Someone cut the power cord on my subwoofer RCA model rt2760 can i replace it with a standard plug?
if its a standard 120/ 240 volt cord with three cores live /nuetral/ earth yes
Aug 02, 2011 | RCA RT2760 System
Three year old Dometic RM 2555, 3 way Frig/freezer has failed on 240VAC however works on Gas. I suspect the PCB is faulty
My rm2555 has just failed on 240 volt. But not 12 volt.
It turned out to be the 240 volt element .
Fairly easy to replace. If you have a multimeter test the resistance, mine was open circuit.
Does yours work on 12volt?
The two heater elements (ie 12v and 240v ) are on the right when viewed from behind with four large wires coming out, plus an earth wire. There are labels on some of the wires. The 12 volt conects into a terminal connector, where as the 240 volt is fitted with spade connectors and is attached to the printed circuit board, under the white plastic cover. The elements are "L" shaped and are just pushed down in down next to each other. The cover seems to unclip fairly easily to enable removal.
Hope this helps.
Mark
Dec 26, 2010 | Dometic Refrigerators
I am trying to hook up a 3 prong cord into the dryer but I dont know how you hook up the ground wire.
What voltage does the dryer require? There should be a 'nameplate' somewhere on the machine that has the voltage and Gas requirements. (if it isn't a gas dryer then it'll probably be 240 volt. If it is a gas dryer then a standard 120 volt cord should work). Be sure you are attaching the proper cord... The ground wire should be crimped into a ring terminal connector or a spade terminal connector (can be picked up at any hardware store) and screwed onto any metal surface of the machine(there may be a green screw designated for the ground wire connector)
Mar 06, 2010 | Dryers
How do you convert the (2) 240 volt outlets to one twist lock connector on a coleman powermate maxa 5000 er genset
Make an Umbilical recepticle adapter. Buy the recepticle install the recepticle in a 4" electrical BOX on a plate with two manufactured 3 prong power cords plugging into the 2 outlets and terminating at the new Box twist lock recepticle you made.
Feb 09, 2010 | Coleman Powermate Powermate 5000W...
Mains wire at back of fridge has come out how do i re-wire it
Hi, are you saying that the main power cord has been pulled loose from all connections? Has any componants come along with it? Wiring a power cord is fairly an easy task if you are familar some what with wire colors for a 120 volt power cord. You should be able to take a good look at where it has come apart and reconnect the cord with wire connectors, as Hot would be black to black, and white is nuetral, so white to white and green for ground to the appliance. Now, If you have accidently pulled out the wiring from the compressor terminals, as the start, run, and common terminal, I need to no this to quide you through this, as there is also a overload relay that is wired through the common terminal to protect the compressor against an overload. Please get back to me if this has happened.
Sincerely,
Shastalaker7
Jan 13, 2010 | Refrigerators
My laptop will not charge!! the charger works, but it just wont charge my laptop!
most likely either a bad connector on the power cord or you've broken the motherboard connector. check the power cord with a volt meeter. if it comes up fine the i would recommend either contacting the manufacture or taking it to a reputable tech. if you are comfortable with doing it you can take the laptop apart and look at the connector with the laptop apart plug it in (CAREFULL IT COULD KILL YOU) and test the voltage after the connector wit the volt meeter. if it has power then most likely *********** board is dead. if it doesn't have power then you need to repair/replace the power connector.
Jul 07, 2008 | Computers & Internet
Fisher and Paykel GWL11 Top Load Washer Logo
134 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
