I get error 35 when attempting to open program
Error calling external object function driveinit at line 302 in open event of
object bookkeeper.
    Novelist:
  • 148 Answers
Greetings my name is Mark and I will be glad to assist you. Your issue is a result of a corrupted system file in your operating system or what is called a registry data coruption. This sometimes can be rectified by a registry cleaner if not you will need to install windows with a recovery disk. if you do this let me know and I can walk you through the recovery process it is simple.
Be mucho blessed,
mark
Posted on Nov 17, 2008
Connection to update server failed, error code 12152 for Bookkeeper updates
A lot of people seem to have had major problems trying to upgrade for this software. Some have spent many hours waiting on the phone, and decided to move to different software.
"Dog Lover" offers this guidance:
If you are updating your software follow carefully (1) first back up your database and email to yourself (2) wipe bookkeeper completely off your computer (3) download the newer software and install the tax tables (4) finish updating (because it downloads to a newer software version within 2011) the program. When everything is updated, (5) save your database to your desktop (6) open bookkeeper and restore your database. Then make another update with the upgraded database.
Lets hope it is still true for 2013/14
Jan 21, 2014 | Avanquest Bookkeeper 2009 Full Version for...
Error message after installing BOOKKEEPER 2008
Error 3010 is a type of system error with multiple potential software or hardware causes. it could probably cause by the software you recently installed, download a registry cleaner or registry fix software and run through all your programs, you might need to uninstall and install your bookkeper once again.
Jul 25, 2008 | Computers & Internet
I have just installed BOOKKEEPER 2008. An error window keeps coming up Error # 3010 I need to get this fixed as quickly as possible. Thanks, Deb
It looks like a file has been corrupted during the installation process.
Download and install CCleaner from www.ccleaner.com
Uninstall BookKeeper and then use the registry cleaning tool in CCleaner to clean up the registry of your computer.
Re-install BookKeeper and make sure no other programs are running on your computer during the installation.
Kodak easyhare software won't download invalid calling object
just click the red button "share" on your camera, then disable sharing, if you have the device connected to a computer, automatically it will open the content of your camera as if were a pendrive or an external hdd, problem solved.No need of kodak addon software.
Jun 14, 2013 | Cameras
Bookkeeper software old version
Please go directly to Avanquest technical service:
http://www.avanquest.com/USA/aq-you/support/
Jan 22, 2013 | Avanquest Software Bookkeeper 2009
Error no. 302?
Control Panel / Administrative Tools / Event Manager
Windows 10 in startup apps go to Administrative Tools / Event Manager
Right Click start menu click event Viewer
once there look to left and expand WIndows Logs Click on Applications and wait for them to load See my pictures i found an error then I clicked on it and it told me what app.
If you don't have event viewer turned on you won't get anything. Then just google turn on event viewer your OS = (winodws 10, Windows 8 etc. turn it on reboot once the error occurs it is recorded go to event viewer and see results.
Dec 30, 2017 | Toshiba Satellite M45-S331 Notebook
Code 35 for the fx540
Error Message in Windows 7. Your computer's system firmware ... manufacturer to obtain a firmware or BIOS update. (Code 35 ... also needs a BIOS update to be compatible with the FX540.
im not familiar with this type of error you might just try the to troubleshoot the problem until you no exactly what has caused the problem you cant fix
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 28, 2011 | Nvidia Computers & Internet
Why main function is made static in java
Its very easy dear. In java everything is object oriented. You will call a function through an object. Now we are calling the main method without any object as we do not create any object of the class that contains a main method. So call the main method we need to declare main as static methos so its not a part of an object but a class so that mian method can be called without having creating any object of the class.
Regards, polysandy
Jun 27, 2010 | Sun Java Programming Language (cdj-275)
Webpage error details
100% working IDM fake key block problem
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
Mar 16, 2010 | Microsoft Internet Explorer 8
HP 15C calculator display showed ''Error 4'' when using inverse function (1/x). How do I fix it? Thanks.
When you get the error press any key to suppress the error message. Put the calculator into PROGRAM mode and you will see the line where the error occurred.
Here is what the manual says for ERROR 4 (free translation)
The line number called is not used or does not exist (larger than 448); attempt to load a program line (instruction) where there is not enough space; line label inexistant.
My hunch is that you are attempting to divide by 0: The quantity of which you are taking the reciprocal (inverse function has another meaning) may have a 0 value.
Do not forget to check the input values.
Hope that will help you debug your program
Oct 14, 2009 | HP Office Equipment & Supplies
Computers & Internet Logo
461 people viewed this question
David Payne
David Payne
