Hi, My canon pixma mp780 has been printing in colour but faces are green--all of the cartridges are in place--the yellow, pink, blue and black. I cannot figure out what the problem is. Hope you can give me some advice SUSAN ROSENFELD SUEROSE@ROGERS.COM
    Novelist:
    Scholar:
  • 125 Answers
Hi Susan,
I have 3 MP780 printers and I've never had that problem. I'll try guessing, green color is a combination of Yellow and Cyan (what you call Blue). Do you have all 3 of the Cyan(Blue), Magenta (Pink) and Yellow cartridges in the correct position? This is the simplest possibility that I can think of. If they are and the cartridges where never in the wront position, then let me know if you want to continue further. Because it means someone has to clean the printhead and that takes a little bit of mechanical aptitute and dexterity. Not a lot really actually some basic common sense. The only other possiblity is that you may be using compatible cartridges. Sometimes their inks are really different colors. Hope this helps.
Posted on Nov 17, 2008
Colour printing has a blue tone. Colours are not
This is problem may be one of the cartridges is dry or there is low level of ink .you did all the possibilities check only thing is pending the you can replace the cartridge and see the result.
Have a nice day and do not forget to rate please...!
Feb 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
MP 160 IS PRINTING ONLY BLACK AND PINK COLLORS
Maintenance your cartridge with head clean or deep clean. If you don't get full colour, then change the colour cartridge.
Sep 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Replaced cartridges
Hi there :
on mine i had to use some rubbing alcohol and clean the new cartridge and the contact area on the p[rinter then reinstalled the cartridges and kept running the cleaner program and then about 15 sheets of paper later it finally cleared up and the color returned to normal and i had no more prohblems
Mar 07, 2009 | Canon PIXMA iP2000 InkJet Printer
Printhead problems Canon PIXMA MP780
that definitly sounds like it needs to be replace, have you tried using the printhead cleaning utility?
Dec 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Cannon Pixma MP 780
your MCY (color) cartridge is damaged, or either needs cleaning, try to remove this and clean the head with a soft cloth and re-install once again, if it doest work then replace the cartridge
Dec 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
No Yellow will print
If you haven't used it for a long time the ink may have dried up. You can try taking out the cartridge and letting it sit on an hot wet rag for a while to unclog the print heads. Try not to touch the copper contacts on the cartridge. If that doesn't work you may be out of yellow ink.
Apr 23, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon iP6700D printer
Browns printing pink suggest the blue/yellow jets are clogged or not functioning. If the uses head in cartridge type[that is with a sheet of contacts on the front of the cartridge- then take then out ,damp a tissue in some warm water an place on a plate or similar - then stand the cartriges in the damp tissue until the tissue turns colour - then replace the cartrdge. If it is head in the printer Then take a look here www,fixyourownprinter.com
May 24, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Some colours not printing
I bet you are using non genuine ink, the MP780 will not put up with that ink, you will need a new printhead and maybe a purge unit. Take the machine to your ink supplier and get him to fix it as he supplied the ink
Jan 29, 2007 | Canon PIXMA MP780 All-In-One InkJet...
134 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
