Question about RCA 32V550T 32" TV
Vertical adjustment somebody can tell me how can i enter to menu for vertical adjustment on rca 32v550t.Any help welcome..thanks...
    Sergeant:
    Champion:
  • 375 Answers
Hold menu press power press volume up a p and d will appear use the volume up to change the value of v to 76 then you in but you require which setting to adjust i don't have them with me now but try this and see if you can get in first,.to exit press power button /
Posted on Aug 30, 2007
SOURCE:
Rca 21k8. Insufficoent height
Warning!!!!!!!!!!
Do not adjust anything else only Vertical amplitude .1.1. The way to enter P-Mode a) Method one A) Switch on the TV set. B) Press the "MENU" key on RC to show the "PICTURE" OSD menu. C) Move the cursor to "Contrast" item then press the "9", "7", "3", "5" key continuously on RC within 3 seconds then enter P-Mode. The "P" letter will appear on the left low corner of the screen when enter P-Mode. China TV 21F1 NX56E LA Service Manual
Nov 25, 2016 | RCA Televison & Video
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    32V550T On/Off problem
    i need help i dropped my RCA model# 32V550T chassis# ITC208GYV serial# F225CF0VC and i cracked the circuit board were everything plugs into and i can't find another were can i get a new one please if anyone can help my e-mail is aloushi711@aol.com if you can help me i would be very thankful thanks
    Nov 05, 2008 | RCA 32V550T 32" TV
    Adjusting vertical and horizontal
    There is no adjustments on this model if horz is off i suspect a bad capacitor in around the verticle ic.
    I fix a lot of these tv at my shop. cost is around 120.00 at our place.
    I hope this helps thanks DOCTOR VIDEO
    Apr 27, 2008 | RCA 32V550T 32" TV
    32'rca 32v434t
    Resetting the Password
    If you forget your password, you can reset it. Here is how to do it:
    1. Make sure the TV is off.
    2. Simultaneously press and hold VOL- on the TV’s front panel and CLEAR on
    the remote for approximately 5 seconds.
    3. Enter a new password the next time you access the PARENTAL CONTROL
    menu.
    Jan 23, 2008 | RCA 32V550T 32" TV
    RCA 32v550t problem
    PRESS AND HOLD MENU AND POWER ON THE SET
    Jan 15, 2008 | RCA 32V550T 32" TV
    Horizontal and vertical adjustments
    sorry there is no adjustment for this .you probably have a bad component in tv
    thanks Doctor video .
    Oct 17, 2007 | RCA 32V550T 32" TV
    Rca 32v434t
    went in the menu and blocked the panel buttons on accident
    Oct 13, 2007 | RCA 32V550T 32" TV
    RCA 32V550T 32" TV Logo
    115 people viewed this question
    Top RCA Televison & Video Experts
    Steve Allison
    Steve Allison
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
