Question about Inland 58016 Wavetable PCI Sound Card
I don't think it's a zipping problem
I doubt I'm trying to install zipped files. I found an "extract" option for the zipped folder and did that. I also downloaded Winzip and used its 'extract and install' option. It extracts just fine, but when it goes to install I get that same "Setup has caused an error in SETUP.EXE. Setup will now close." message and the files are never installed. Since I don't believe I'm trying to install zipped files I'm not going to remove the soundcard then. I certainly don't know how to "disable the onboard sound on my motherboard in the bios". I can't imagine that anyone who does would need help with this. Do you really think I have the wrong .dll or ini installation file? Wouldn't that mean I was sent to the wrong url for the download in the firstplace?
    Top Expert:
  • Inland Master
  • 12,962 Answers
Create a folder and put the zipped file in thre and extract to same folder. Then turn off computer, install the peripheral, and reboot. When computer detects presence of new hardware it will ask for driver. Then direct the computer to the folder where you have all of the extracted files and the OS will find the necessary driver and take care of business for you.
Posted on Mar 22, 2017
2 Suggested Answers
El Duderino
  • 47 Answers
SOURCE: Actually I already tried that
Ok Joe, Just to make sure we're on the same page here, are you using winzip to unzip the files? If so when you double click setup.exe do you get a dialog saying "Winzip will extract all files to a temp folder and run the setup.exe program"? If not I want you to try opening the .zip and hitting the "Install" button. If that does not work we could try an end around on the setup. First unzip those files into a new folder that you know where the folder is, we're going to need it later. Go into device manager (it's been a while since i've used ME but it should be under Control Panel, System, Device Manager tab) Find your sound card, right click on it and click "uninstall". Now reboot. Windows should see the card again and try to reinstall it. When it does hit "Have Disk" and hit "Browse" then goto the folder you created when you unzipped the files. Hit "Ok" That way will not install all of the "extras" you might get from running the setup.exe but it _should_ allow windows to use the sound card. Lemme know how it goes, Dude
Posted on Nov 16, 2006
How to Use WinRAR?
The WinRAR application will compress the files and save in the same folder or location as the original files. The WinRAR program can also extract compressed files with a RAR or ZIP format. Select the files that require extraction using the pointer. Right click on the selected file to display a drop down menu.
Materials Needed:- PC
- winrar archiver program
- file to compress
- compressed files
Step 1
Ensure that the computer you are going to use for compressing files has WinRAR program installed before proceeding with the compression of file.
Step 2
Select all the files to you want to compress by using the mouse and the CTRL button or the SHIFT button. The CTRL button is for selecting several files in the same folder or location. The SHIFT button is for selecting blocks of files.
Step 3
Right click on the selected files to display a drop down menu. Select the 'Add to Archive' option from the drop down list. This will display a WinRAR window menu.
Step 4
Input a name for the compressed files in the Archive name section in the General tab. Ensure that the name is not similar to any other compressed files in the save location.
Step 5
Select the file format of the compressed file after the deciding on the name. File formats can either be RAR or ZIP. There are also other options such as deleting of the original file after the compression, putting authenticity verifications, and putting a recovery record.
Step 6
Click the 'OK' button after completing all the required fields in the menu. The WinRAR application will compress the files and save in the same folder or location as the original files.
Step 7
Step 8
Right click on the selected file to display a drop down menu. Select the 'Extract files' option from the menu. This will display a window from the WinRAR program.
Step 9
Specify where the extracted files will be located in the 'Destination path' option of the General tab. Do not replace the destination path if the extracted files will also be placed in the same location as the compressed file.
Step 10
Click the 'OK' button after filling the required fields in the window. This will start the extraction process of the RAR or ZIP file.
Oct 19, 2016 | Computers & Internet
Blue screen, says Bootloader USB Init at bottom, won't restart with power key
1.go to http://www.modmymobile.com
2.download p2ktools zip file
3.extract zip file
4.down firmware for motorola razr v3 zip file
5.extract razr v3 zip file
6.open p2ktools extracted folder open p2ktools exe file
7.read help how to flash your motorola razr v3
Aug 24, 2011 | Motorola Mobility RAZR V3
Hi i want to install the chinese,japanese and korean language!! but i dont have a xp cd... what should i do??
  1. Download the files needed to install the East Asian Languages here: http://www.4shared.com/file/HZ2CQc0I/east_asian_language.html
  2. Extract the I386 folder from the Zip file to a folder on your hard drive. Remember the location of this folder.
  3. Click on the Start menu, open Control Panel, then open Regional and Language Options.
  4. Select the Languages tab and under the Supplemental language support frame, check the the box next to "install support for East Asian languages".
  5. Click on Ok or Apply, then you'll receive a dialog box which says that "The following file ' - ' is missing.." and it also allows you to specify a directory where it should be found. Click on Browse and select the "I386" folder you extracted from the downloaded Zip file.
  6. After the files are installed, you must restart your computer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 26, 2011 | Computers & Internet
Would You be so kind to send URL, how to convert in Mobile Sony-Ericsson F100i ZIP-file to JAR-file?! Thanks.
Hello and welcome to Fixya!
Actually there is no need to convert zip file to jar, jar is also an unextracted archive.
You can simply double click the zip file, and can extract the jar file in it.
The other way is to Open your Control panel goto Folder Options, in view tab UNCHECK "Hide extensions for known file types". When done you will see a".zip" written in the end of your file. Rename the .zip part to .jar and send it to your Phone.
If both the methods aren't working do tell me, I'll guide you further.
If you think I was of help, your token of appreciation in the form of Rating will be esteemed.
Concerned, Nooh
Jul 18, 2010 | Sony Ericsson Cell Phones
When i try to install a critical update it was denied access by 7 zip. even after uninstalling 7 zip and installing winzip i still get the same response when trying to install updates 7 zip access denied....
Install Winrar, Here is the link
http://www.rarlab.com/rar/wrar391.exe
if you double click the file,the files will be extracted in the temp folder,so after installing winrar,right click on the file and select extract here. and try to install the update now,
Sometime when you extract files and it contains Malware or Trojan,Anti-Virus which support real time scan just block the files and the access denied message is displayed.
Scan the extracted files before installing so that you know it's Virus free.
Sometimes,even if you have administrator right,sometimes due to malware infection, you are denied access to some system hidden giles like folder under Local settings.
Dec 30, 2009 | Compaq Computers & Internet
I need drive for transcend d33193 usbdrive
I think this is a Windows 98 forum. If so, I may have a solution.
Download and install this free (Generic Storage USB Device) driver named "wtgenusb-zip" from DriverGuide.com. Register with DriverGuide.com for free membership. Use their search tools using keywords like "Window 98", "USB", "Storage" and look for "wtgenusb-zip".
It's a rediculously small file to download, only 11Kb. The "zip" file must be extracted which can be done on any computer running Windows XP, then copy the files over on a floppy disk. However extracting it on a computer running Windows 98 will require a seperate program like "Winzip" or "Pkunzip" (for DOS).
Copy the extracted files to any folder of your choice on your Win98 machine. Use the "Install Hardware Wizard" to navigate to that folder to install the driver to enable your USB storage device.
WTGENUSB worked great for me, permitting my Win98 to access my USB Flash drives, 250Gb Portable hard drive, and Digital Camera card reader. Good luck.
Jan 23, 2009 | Microsoft Windows 98 for PC
Unzip
Goto my computer at top you will tools > left click on it > folder options > goto 'view' tab >UNCHECK HIDE EXTENSION FOR KNOWN FILE TYPES.
Now see the extension for your zip files..It will be either filename.zip or filename.rar..
let me know the extension it have so that experts from fixya can fix the issue for you.........
Nov 14, 2008 | Compaq Presario 5000 PC Desktop
Easy cam
OK, people! I know u had problems with this cam, and somehow, don't ask me how I came in posession of certain drivers for this webcam that actually work. So, just on the safe side, these are drivers for ChiconyTwinkle Cam DC-2110. I took liberty of uploading drivers online just for you ppl, and in return i expect you to help those who need these drivers. Link for these drivers is here:
Chicony.USB.CIF.Webcam.driver-dc2110.zip
So, for those that have problems with installing this webcam, download the zip file above, extract it to some folder, then plug your webcam in USB, when window pops out sayint that there is some new hardware found, (skip the online search option and select "not at this time") select the folder named "Driver" in folder you extracted zip file to and press next. Thats it, your webcam should work now.
Btw, i seriously doubt that the file on official Chicony website works, it may be corrupt or just outdated.
Take care ppl, luv ya all!
Oct 30, 2008 | GE EasyCam Webcam
I am unable to unzip the necessary files once I download the software. It asks for a password to extract the launch and autorun files.
Is the file in Zip or Rar format?
Download the Zipreader as it is freeware and very easy to use and make zip files. http://www.pkware.com/index.php?option=com_content&task=view&id=384&Itemid=331&forms08=true
Also try Winzip http://www.winzip.com/index.htm
If you are running XP or Vista then it is not so difficult to extract out the files from a zip folder.
Let me know if you need further assistance.
Puneet
Oct 15, 2008 | Computers & Internet
Inland 58016 Wavetable PCI Sound Card Logo
Top Inland Computers & Internet Experts
Jeff richtman
Jeff richtman
David Payne
David Payne
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an Inland Computer and Internet Expert? Answer questions, earn points and help others
