Question about Goodman GDS80904BNA Open Flame Heater
Goodman GDS8 Furnace Won't Cycle
We have a Goodman GDS8 down flow furnace. It's 3 years old. We get three flashes on thecircuit board when a call for heat comes from the thermostat. Ifollowed the troubleshooting per the instruction manual. I replaced thepressure switch with a brand new one. The induction motor works fineand spins up when a call for heat comes from the thermostat. And I checkedthe flue and it is clear from obstructions, there were none.
There is a group of wires on the left side of the circuit board and ifI grab that group of wires with my fingertips and barely lift it, thecircuit board LED goes solid and 70% of the time the furnace will cyclecorrectly and start and work until it reaches the temperature set on the thermostat, after which it will not cycle the next time. The other 30% of the time it starts the sequencebut then gives the three flashes on the LED again. Also, when I liftthat bunch of wires I can hear a clicking sound and the LED is affected when I hear the clicks.
I can't figure out the problem, let alone fix it. Any suggestions.
  • mjthe2ofus Feb 06, 2009
    I have a problem with my goodman furnace. for some reason it can be set to 69 and not turn on and go down to like 55 in my home. at other times my furnace will turn on. but when it runs it constantly shuts on and off on and off. and sometimes it will make a clicking noise like a relay is clicking. I have checked everything that i was told to check and nothing. what is wrong with my furnace
  • marcopolo79 Mar 11, 2009
    I think I have the same problem as mjthe2ofus, although I am not sure of the model because I am not at home right now.
    The heat does work however it seems like once it reaches 69 it struggles (although I have seen my temperature over 69 a few times).
I had the same issue as zippygaloo with the harness plug. By lifting up the connector, the furnace would go out of it's current fail mode and start operating normal again. I have temporarily resolved my issue, by tying up the wires (looped under them with tie raps) and secured them to the vented furnace housing directly above, thus alleviating any stress pulling down on the connector plug by the weight of the wires. Since doing this my furnace has been running flawlessly and stays right at the temp on the Tstat. No more fault modes with blinking lights! Hope this helps you guys. I don't know if it's related to bad design flaw, or there is a weak connection on the board, but it worked for me.
Posted on Mar 01, 2009
  • Melbe Jan 06, 2015
    Yes, before relieving stress on molex connecter with wire ties, check the back of circuit board for hairline cracks on solder joints. This being caused by vibration and stress on the connecter (component side). Don't forget to mark all connections, before disconnecting!
  • Melbe Feb 21, 2015
    Yes the solder connections on the back of the connecter are weak, with little solder to hold and should be re-soldered. Look for cracks in the solder joints.
    Problem Solver:
  • 17 Answers
Sounds like you are on the right track with the plug. Pull the plug apart and check to make sure all the prongs (male and female are correctly snapped into position ...usually its a conductor prong that has been pushed out of place when the plug was put together. I have also seen this problem and could not find a solution, just changed the board and the problem was resolved ( thought it was perhaps a crack in the printed circuit).
I have also seen problems with the connection for the pressure hose on the induction fan clogging up ...pull the hose off and push a very small wire into the hole (with the furnace off of course) and see if it fixes the problem. The fan I ran into the problem with had the connection located low on the housing.
Posted on Nov 18, 2008
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
The red light won't stay solid and blinks. the furnace won't cycle more than once or twice before it just won't go and it is not warming up to what the thermostat is set on. we have to flip the actual...
if it is three blinks then it should be the pressure switch, you can blow through the tube(both ways) and it should work. here is a thread I found:
http://en.allexperts.com/q/Heating-Air-Conditioning-696/furnace-working-3.htm
here is a best site:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
hopefully this will help you out, Good Luck Tim
Jan 16, 2011 | Goodman GDS80904BNA Open Flame Heater
My 95% Goodman is only four years old. I attempted to turn it on this fall and got a continuous flash which indicates reverse 115 volts. How could this be since no one has touch the furnace all summer?
Hello my name is Heath it will be my pleasure to assist you. You can try reversing the wires in the furnace but this is usually a good indication that the circuit board is bad.
Oct 03, 2010 | Goodman GMS90703BXA Heater
Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Jan 15, 2010 | Goodman Heating & Cooling
I'm considering installing a Goodman LP Gas Furnace:sizing? Ops?
Gerge, if you go to website www.energycodes.gov
you can do a heat load calc yourself. Basically, you figure out the sizes of walls, total area of glass. total doors to outside, ceiling area and types of building materials used. It is pretty easy and then you will know for sure. The contractor should be suppling you with one but if not use this, it is free!
Nov 03, 2009 | Goodman GMS90703BXA Heater
I have a 15 year old Goodman GMP075-3. The unit will not remain on more than 10 seconds. The igniter is new, the flame sensor has been cleaned with steel wool, I checked and re-seeded all wire...
since your getting ignition it sounds like it is shutting off due to airflow
you may want to drop the fan and check the coils above it
and the coils in the pelum with out proer air flow these units shut down at 180 degrees will cycle when cooled again
since your getting ignition your inducer seems to be fine
Oct 07, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
639 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
