Question about Fujitronic Automatic Dispensing Hot Water Pot FP-30A Electric Kettle
I need a magnetic power cord for a hot water dispenser
Fujitronic FP-40A
2 Suggested Answers
  • 78 Answers
SOURCE: i need a replacemant cord
go to an electronic repair shop you should find one
Posted on Jan 21, 2011
Fugitronic automatic dispensoing hot water pot won't heat
The partial answer to your stated problem is that after 3-4 years of use it is possible that the heating element has worn out
Mar 08, 2013 | Fujitronic Automatic Dispensing Hot Water...
Water does not pump
plug it in? or the motor has fried itself could be a defect item
May 03, 2011 | Fujitronic Automatic Dispensing Hot Water...
The water wont start filling up - it beeps and then has the code "ddo" on the screen.
The meaning for ddo error means "Dispenser Drawer Open"
To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
May 25, 2010 | Frigidaire ATF6000ES Front Load Washer
No Cooling
The water pump or the float valve is not working.
Aug 02, 2009 | Fujitronic FH-797 Portable Air Conditioner
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Instant hot water dispenser does not heat water.
I had the exact same problem. I even replaced the first unit with a second unit...because I was sure I hooked everything up correctly. Then I called their support line and and felt very stupid. They asked one question "are you plugging in the Quick&Hot into the same electrical outlet as the garbage disposal"?. I said yes..and the garbage disposal works fine (thinking that this indicates a good electrical outlet). She then said "That outlet works off of a switch so no electricity is getting to the Quick&Hot until the disposal is turned on). Gosh darn it...that made total sense. I then tested this out by plugging an extension cord into a different outlet and it worked fine. Boy...do I feel stupid. Hope this helps.
Jan 17, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Not filling with water
Answer: The magnet goes on the back of the dispenser door. Pull entire dispenser out per instructions elsewhere in manual as if you were going to clean it. Turn it around so that you are looking at it from the back end. The magnet goes vertically on the very left edge (as you're looking at it, right edge when dispenser is in machine) of the back of the white outer cover of the dispenser about halfway down. If you run your finger along the left edge (the edge of the back of the dispenser) you will find a "cut out" area. The magnet goes immediately to the right of it between the edge and the portion of the dispenser that sticks further out toward you. There is a small clip to hold it in place.
I found instructions somewhere on the web similar to these that helped me locate it , but can't find it now to link or give credit. I have added some photos I took to help schematically challenged folks like myself.
PS If you need bifocals remove the front cover from the dispenser, take your glasses off and look at the far middle left of the back of the dispenser cover. It's really hard to see.
a4fbef54-7dc5-4c60-815f-e92937ca670b.jpg 6bc37cd8-9f56-4605-b13e-03c400a840ab.png
Jul 31, 2008 | Kenmore 43142 Front Load Washer
Fujitronic Automatic Dispensing Hot Water Pot FP-30A Electric Kettle Logo
59 people viewed this question
Top Fujitronic Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Fujitronic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
