Question about RCA D52W19 52" Rear Projection Television
D52W19 RCA 46 inch t.v.
Hi, the RCA 46 inch t.v. was working last night. This morning when we got up to watch it, it won't even turn on. I pushed the power button and the only thing that will come on says "hit clear or menu to program the channel" but it won't stay on long enough to even allow us to select, either or....And, I can only get that if I push really ******* the power button. So, it's just stopped working. Can anyone help?
My RCA D52W19 52" rear projection TV will not power up ( turn on )
Posted on Nov 22, 2008
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
D52w19 rca hdtv.will not tourn on. when u push the
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | RCA D52W19 52" Rear Projection Television
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
Working fine, then shut off.. won't come on, no power
A clogged air vent will cause the unit to overheat and not turn on.
Apr 16, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w19 push power flashes 3 times and makes buzz each time
Check capacitors cp150,cp114,cp120 if any of the capacitors are puffed up on top replace all 3 of them 2200uf 16v and (2) 220uf 35v
Feb 14, 2009 | RCA D52W19 52" Rear Projection Television
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
Heads Cut Off
Is it in zoom 4:3 or zoom 16:9? Use the left/right arrows to change it.
May 06, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
207 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
