Question about Maytag Kitchen Ranges
Model MGR57555QDS error code 5 ab - Maytag Kitchen Ranges
  • Maytag Master
  • 2,651 Answers
You ve put the unit into sabbath mode"SAB" accordingto the manual press and hold the clock button for 3 secs, then press and hold MORE or LESS button untill the 8:88 appears back in the dislpay. current time will appear in 4 secs
Posted on Nov 17, 2008
Check engine light is on and diagnatics show the error codes, P0722 and U2108
Definition of Diagnostic Trouble Code U2108 Buick: CAN Bus Error ABS Cadillac: CAN Bus Error ABS Chevrolet: CAN Bus Error ABS GMC: CAN Bus Error ABS Oldsmobile: CAN Bus Error ABS Pontiac: CAN Bus Error ABS Saturn: CAN Bus Error ABS
Definition of Diagnostic Trouble Code P0722 Category: Powertrain Definition: Output Speed Sensor Circuit No SignalNote: This definition of P0722 is applied to all manufacturers
Jun 27, 2015 | Cars & Trucks
What is the C0265 error code
The ABS EBCM anti-lock brake module is failing causing problems with the ABS pump running constantly, also will drain your battery.
  1. Remove the ABS fuse to prevent ABS motor burn out.
  2. You can still drive your vehicle with the module removed.
  3. We recommend covering the exposed surface of the hydraulic control unit with aluminum foil to keep out water and dirt.
Common Failures:
  • ABS Pump Always Running
  • Codes: C0265, C0267, C0268
  • Pump Motor Circuit trouble code
  • Power Relay trouble code
  • Valve Relay Trouble code
  • Dump Valves (solenoids) trouble codes
  • No Communication
  • Intermediate power loss
Nov 28, 2014 | 2001 GMC Sierra C3
Why won't abs light go off error code says pump
When a pump code comes on for the abs it is usually associated with the module connected to the pump. Most of the time either the relay controlling power to the pump loses it's continuity on the board or the connector builds corrosion and resistance in the terminals. Most of the time depending on the make and model an the exact code it can be remedied by purchasing a new or used abs module/ pump, repairing the old module/ pump, or just replacing with a new module/ abs pump(most expensive option). It is very common for abs relay/ pump codes to appear and end up relating to the power or ground circuit going to open( breaking continuity it frying a connection form resistance)
Jun 05, 2014 | Chrysler Voyager Cars & Trucks
Abs on vr commodore light stays on solutions
Error logs are a great thing. They will help you find intermittent problems and start you off in a general direction of where a problem could be. There is a great level of detail on the justcommodores site on checking error codes logged by the engine management system, but this does not detail anything about the abs system. The abs warning light is not as common as the check engine warning light. Reading through the posts, I haven't found any detail on checking error codes logged by the abs system.
So here it is. For those of you familiar with checking the engine error codes, this procedure is so simple its not funny.
Basically, to check the engine error log, you bridge the 5th (ground) and 6th pins in the ODB connector under the steering wheel.
To check the ABS error log, using the same trusty calibrated paper clip, you simply bridge pins 5 and 12 of the connector.
To find pins 5 and 12, start at the top left hand corner. That is pin one. Going to the right, you count pin 2,3,4 etc. Once you get to the end, jump back to the start of the bottom left level of pins and keep counting. Pin 5 is about halfway along the top row, pin 12 is a little left of the middle in the bottom row.
Reading the error codes is the same procedure (counting the flashes), except now, the ABS light flashes (as opposed to the engine light when checking the engine codes).
The ABS log also uses code 12 firstly, with any errors logged shown after that. If no errors are logged, the 12 will flash again.
Error codes for the ABS error log (VR/VS) are as follows:
12 Diagnostic system operational
21 Right hand front wheel speed sensor fault
23 Right hand front wheel speed sensor continuity fault
25 Left hand front wheel speed sensor fault
27 Left hand front wheel speed sensor continuity fault
28 Wheel speed sensor frequency error
31 Right hand rear wheel speed sensor fault
33 Right hand rear wheel speed sensor continuity fault
35 Left hand rear wheel speed sensor fault
37 Left hand rear wheel speed sensor continuity fault
41 Right hand front inlet solenoid valve circuit fault
42 Right hand front outlet solenoid valve circuit fault
45 Left hand front inlet solenoid valve circuit fault
46 Left hand front outlet solenoid valve circuit fault
55 Rear inlet solenoid valve circuit fault
56 Rear outlet solenoid valve circuit fault
61 Pump motor relay circuit fault
63 Valve relay circuit fault
71 ABS control module internal fault
The above guide has been verified on a VR/VS. Checking the error log on all models prior to VR/VS is the same for the engine log, and I would assume that the same can be said for the ABS log, would be happy if someone could verify this for me.
Sep 21, 2013 | 2005 Mazda Tribute
your abs light is on because the abs module has detected an error in its system. Found out what codes are in the abs module. This will help narrow down the many possibilities. Once you get the codes, figure out what is wrong, and make a repair you can then clear the codes which will turn off the light.
Posting a year, make, model, and engine size will help make things more specific for you problem!
Feb 10, 2012 | Cars & Trucks
Will dot 3 brake fluid create an ABS error code?
if your car uses dot 4 brake fluid it is compatable with dot 3 fluid.if it requires dot 5 then the fluid will have to be changed and possibly flushed as dot 5 is not compatable with dot 3 or4 any rate it will not cause the abs light to come on if its not dot 5,as the wrong fluid mix can cause seal swell in the system which could cause the abs light to come on.
Dec 03, 2011 | 2001 Volvo V70
VW passat 2001 lat model.... Error codes 1411 , 1423 and 1649
when the abs light or any other light flashes it means that theres a problem in that particuler system normaly on the abs system you will not feel no differance because the anti lock brake system works only if the hit the brake hard it would not allow the brake system to lock up any of the wheels thata why the name says it all ANTI LOCK BRAKE but you should get it check by a mechanic with a scanner he will tell you were is the fault good luck
Jul 12, 2009 | 2003 Volkswagen Passat
Trac Off and ABS Lights came on, won't go off
trac control & abs light staying on in dash on pt cruiser 2001 limited
well had same problem with my pt cruiser 2001, firstly there is no need to plug in computer under the dash for pulling abs error codes,
because the problem can be the cracked abs ring on the drive shaft/cv joint,
turn your steering all the way to left and ask your colleague to see if behind the tyre the abs ring is broken or cracked,
it is circular like a bracelete with grooves, then turn the steering to the right and repeat the inpesction,
if the abs ring is cracked then look on ebay or web for pt cruiser abs ring or kia abs ring, should cost about £5-£10 each
and a garage could heat it up with gas and hammer it into the drive shaft/cv joint for you for about £20-£30,
takes about 30min to 45mins, make sure the garage dont heat the cv booth kit rubber next to the abs ring when heating it up.
i heard you can only buy abs ring for front wheels and its not available separately for rear wheels,
so for rear you may need to buy the whole part it comes on
the front abs rings are easily visible when you turn the wheel to one side, the rear ones may not be visible as i have not seen them
so if the abs ring are good then it wil probably be one of the wheel sensors, in this case you you may look for a garage who will hook up
the computer and pull the code for you, be carefull if the say there are no abs error codes it means the sensors are ok and most of it
there is no need to buy abs sensor for any wheel when there are no error codes
on pt cruiser you can pull engine error codes yourself without a computer, just do the key dance on the ignition,
turn key until dash lights come on then switch off and then again turn key until dash lights come on then swithch off,
then turn key for third time again until dash lights come on , you will see engine error codes displayed then says done,
if there are no error codes it will say done, howevere these are engine error codes only not abs error codes,
abs error codes are pulled using abs diagnostic tool
incase its a faulty wheel sensor, will cost £45 at dealer or £20 from scrap, then a garage can removed the tyre and plug out the old sensor cable
and replace it with a new one, one end is easy to plug in but the other end has to be pushed in at an angle,
its about 30min job and garage can charge £20 or so
my pt cruiser is back on the road with just one abs ring replaced and it all cost me £30 alltogether
Apr 11, 2009 | 2002 Chrysler PT Cruiser
Error code 55 on 2007 subaru outback
car threw a CEL at me with ER 55 and blinking cruse. the error code went away after a 5-6 restarts,dont worry it´s not a serious proplem.
Jan 01, 2009 | 2007 Subaru Impreza Outback Sport Wagon
Kitchen Ranges Logo
172 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
