Question about Indesit W 123 Front Load Washer
Washing machine not spinning
I have a 6 year old wg834txc indesit front load washer it work perfectly but it would not spin what could be the cause. The last time it gave me thesame trouble was from that electronic component at the back of the mwasher. One of the contacts has corroded and it was cut and i soldered it and it worked again but this time it is not corroded and i doubt if it is thesame cause of the spinning porblem. Can you please tell me the technical name of that electronic part in the washer. Thanking you in anticipation Francis Buhagiar
  • 30 Answers
Check your brushes in the motor. Have a good torch with you. You will see the brush holders and the brush sticking out. With a small screw driver lift the brushes back up into the holder to see if you have any travel.? A front loader can cut out a set off brushes about every five years.
Posted on Jan 05, 2007
Does not drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Indesit W 123 Front Load Washer
Washing machine is washing but not draining or spinning
heatman101
Apr 26, 2011 | Indesit W 123 Front Load Washer
Indesit WDL 126 dryer - at end of cycle not draining or spining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 11, 2011 | Indesit WA 125 Front Load Washer
Neptune mah4000aww spin cycle
BELT IS LOOSING TENSION CAUSING IT TO SMOKE REPLACE BELT
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Aug 11, 2007 | Indesit W 123 Front Load Washer
Will not spin
When your water does not drain or spin, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked. There is a small door on the front, below which is the place you have to clean out first.
Dec 05, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
132 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
