Question about HP Photosmart 3210 All-In-One InkJet Printer
Scanner Failure - HP Photosmart 3210 All-in-One
My 3210 suddenly started displaying the following message:
"Scanner Failure - Unable to copy or scan"
I hooked up the 3210 to my computer and installed the drivers and other essential software that I downloaded via Internet. Unfortunately, this did not resolve the problem.
I suspect that the scanner bulb may be burned out, but nothing in the user manual addresses scanner failure or scanner bulb location. Any assistance you can provide is most appreciated. Thank you very much.
  • 2 more comments
  • DocEBrown Dec 12, 2008
    Mine does the same thing. Out of the blue one day when I went to scan it tells me "unable to scan or copy." I hear no noise from inside the unit and see no attempt at the light coming on. I power down and same thing. I unplugged the unit and it tries to cycle the scanner, but gives me the same error. I am out of warranty and if it doesn't work I need to buy a new one so I may as well open it up and see what's going on inside.
  • Anonymous Dec 19, 2008
    I cannot copy on the tray, the scanner makes zip noise then it prints out Scanner Failure, and you cant get it to do anything then. What causes this, I only had it a short time. Yet, I can print from the computer to the printer. At times it will after working a short time from the computer it will
    print stuff I put on the glass to copy but now it is stuck.
  • Anonymous Feb 12, 2009
    These things ****
  • flywheeler26 Apr 16, 2009
    Yep, got the same problem. Get the message Unable to copy or scan and no light in the scanner bed area.
computafixa
  • 317 Answers
SOURCE: "scanner failure"
see if you can access the internal workings of the scanner, and see if there is something blocking either the track the the light is moved by, or the rail that holds the whole thing together. Also see if there is something preventing the cables that are attached to the light from fully extending.
Posted on Feb 21, 2008
khanmohammad
  • 188 Answers
SOURCE: Ink system failure
Please click on the web link given below and perform the steps as provided in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&cc=us&lc=en&dlc=en&product=439488
Else please chat with HP online technical support.
The chat support is free of cost, where you can chat with HP online technician.
http://ipgweb.cce.hp.com/ipgna/caller/chat.asp?dd=aio&productName=HP+Photosmart+3210+All-in-One&productCategory=421635&SCOID=238445&PSOID=439599&aoid=null&lang=en&cc=us
Have a great day!
Posted on Mar 27, 2008
SOURCE: HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Posted on Jan 22, 2009
Roop1980
  • 228 Answers
SOURCE: Ink System Failure (Error 0xc05d1381)
To resolve the issue, use the following steps.
Step one: Remove the cartridges
Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
Open the product cover and remove the cartridges.
Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
Disconnect the power cord from the back of the product.
Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
Open the product cover and reinstall the cartridges.
Close the cover and print a calibration page, if prompted.
Print a self test report to make sure that the product can print.
Reconnect the USB cable between the product and the computer.
Try to print a document from an application on the computer.
If the issue has not been resolved, contact HP to review these troubleshooting steps and evaluate if the product needs to be serviced.
Posted on Apr 11, 2009
SOURCE: ink system failure
I, too, used the same solution of holding down "OK" "CXL" and "BLACK COLOR" at the same time. Printer will restart itself and everything is a-ok!
Posted on May 04, 2009
Printer HP Photosmart 3210 will not work
I put item to be copied on the copier glass. I press copy. On copy menu I press number of copies. I press OK I press color start button. The copier starts to work and then a message apprears on the copy screen ' UNABLE TO SCAN " and the command is aborted. I have tried checking drivers and they are okay.
Apr 13, 2011 | HP Photosmart 3210 All-In-One InkJet...
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
When attempting to scan document or copy a document on Photosmart all in one seriers I receive an error message "Scanner failure unable to scan or copy"
try to remove and re install driver, and look into device manager if scanner detected. if not restart you pc and when found new hardware popup browse driver manually.
Apr 10, 2010 | HP Photosmart 3310 Printer
Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
Sep 17, 2009 | HP Photosmart C5280 InkJet Printer
HP Photosmart 3210xi Scanning Issue
no scan options refer to device documentation to troubleshoot
Jul 12, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP 3210 failure code
Hi Pddunstan,
Have a great day!
Mar 09, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210 All-In-One InkJet Printer Logo
241 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
