Question about Dryers
Dark grease stains on the cloths after drying
After drying the cloths there are dark grease stains on the cloths from the dryer. Checked the belt and that seems okay, no unusual noises. This just started and happened on 3 consecutive loads. The dryer is 3 years old.
    Scholar:
  • 68 Answers
Most likely a bearing failure, a seal that retains grease has given up and is spewing into the drum through a shaft opening of some kind.
If you are positive there is no grease in some of the clothes, or someone is putting it in the drum, then a seal has failed, and now that the grease is coming out, the bearing it is was supposed to lubricate is now low, and will fail prematurely, you need a service call and soon.
Will
Posted on Nov 17, 2008
My GE Model DDE 5300 Dryer leaves grease marks on my clean clothes. Is this any easy fix or is it time to buy a new dryer?
Probably dried grease that came out of a worn out bearing. With it's age it's time for a new one.
Feb 23, 2018 | GE Dryers
Oil/grease stains on clothing
Dryer is much more likely
Nov 28, 2011 | Washing Machines
Grease stains on dark clothing
this may due to softener,put spray and wash on stains and let it set all day,stop using softener use HE detergent and oxy clean powder wih soap in dispencer,also you may want to sanitize washer before you wash shirt also use the stain setting and extra rinse.thanks
Jul 29, 2010 | Kenmore Washing Machines
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Dark Grease stains on my Kenmore Front Loading washer
THE SEAL IN YOUR TRANSMISSION IS GONE. NEEDS TO BE REPLACED.
Dec 13, 2008 | Washing Machines
Dark stains on some clothes after drying
I had this same problem. I turned out to be the seal around the drum. You have to remove the drum and put in another seal. Not real hard to do. You can order the seal from sears and I think the glue came with it. Just have to remove the lint vent screws and then the top lifts off. then remove the screws to the front panel. Hold the drum because it will fall. Unhook the belt. Remember how it connects. Then take the drum off and remove the seal and as much leftover glue and fabric. Glue the new seal on and let dry. I did overnight. It should have directions. then replace everything. just make the seal is on the same way you took it off so look at everthing before you remove anything. Once the seal was replaced no more stains.
Nov 21, 2008 | Kenmore 65924 Electric Dryer
Hi dredhill1
i have some good news for you, its n greas. what it is, is built up detergen between the tubs. its common on front loads. its due to to much detergen. waht i recomend to all my customers is not to sue more then 4 table spoons of detergen for a wash. now how to get rid of it, take some POWDERED dishwaher detergent and run a HOT cycle do this about 3 time and that should fix the problem. hope this helped .
brent
Sep 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE dryer, black grease stain on cloth
I have the same problem, I haven't resolved it but it seems to be due to the drum of the dryer being able to move more than it's supposed to and things getting caught in between the drum and whatever it sits in, at the front of the dryer. I have found things caught in there before and when I've pulled them out they had a brown/yellow grease stain on them. Other times something in the dryer will have this same stain - although no longer caught it seems it must have been caught at some point then became free again, with the stain. I'm thinking something is loose or if the drum is supported at the back by a bearing of some sort, this bearing may be worn down and the drum isn't sitting right.
Dec 19, 2007 | Dryers
Dryers Logo
293 people viewed this question
Top Dryers Experts
Marvin
Marvin
