Question about HP Photosmart C5180 All-In-One InkJet Printer
Simple printing on a C5580 HP Photosmart all in one printer
I have set up this Photomart printer and can scan, print photos and print things from my Documents, etc. but I haven't found out how to simply put a page on the glass and Print. I found a place where I could do the simple print settings and I did that. But I can't find the button that allows me to do a simply copy machine process.
  • 1 more comment
  • frankmaitoza Nov 17, 2008
    I'm not quite that dense mentally. I saw the buttons and pushed them accordingly. They didn't work.
    After two hours on the phone with a technician from HP, tracing and redoing wires and plugs and practically standing on my head he finally decided the printer was a lemon and they will be sending me a new one.
    Just not clear communication on my part. When I said "I was trying to find the button," what I meant was that I coulding find it on my computer. On the HP solutions page one can begin a
    number of different procedures such as scannong and photo printing just by pointing to a "button" on that screen and clicking it on but there is no "button" on that computer screen that says "copy/print".
    That's what I was looking for. I found out, there is none. It is done either by scanning to documents and then printing or using the "button" on the printer which wasn't working for me.
    Sorry of the miscommunication. I will have a new printer and all is well.
  • Anonymous Jan 03, 2009
    I HAVE A HP PHOTOSMART C5580 ALL IN ONE I HAVE TRYED TO INSTALL THE DISK THAT CAME WITH IT BUT RIGHT AFTER THE MESSAGE ABOUT UNBLOCK FIRE WALLS MICROSOFT SENDS ERROR MESSAGE AND IT SHUTS IT DOWN HOW DO I INSTALL IT TO MY COMPUTER
    President:
  • 1,901 Answers
There are two buttons near the center of the control panel. One has a solid black square in the middle. (To the right of the redeye removal button.) This is the "Start Copy Black" button. The one to the right of it is the "Start Copy Color" button.
The control panel buttons are described on page 10 and 11 of the user guide. Making copies is described beginning on page 85.
For reference, here is a link to the User Guide: C5580 User Guide
If this is satisfactory, please rate it as a "Fixya". Thanks!
Posted on Nov 17, 2008
  • Wayne Mineard
    Wayne Mineard Nov 17, 2008
    Why didn't you say that to begin with instead of, "But I can't find the button that allows me to do a simply copy machine process."
Why Why is my hp photosmart C5580 All In One printer printing words backwards
May i know which application are you using to print from ?
I guess "Mirror printing" is enabled , hence you are getting its desired effect.
Open a Notepad and print, let me know if issue still persists.
Aug 22, 2012 | HEWLETT-PACKARD Photosmart C5580...
I unhooked my computer system to put laminate floor down. Then rehooked everything. Now the printer HP photosmart c5580, after a few minutes the power button and the print photo button and the close up...
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Good Luck!!!!!
Sep 13, 2011 | HP Photosmart C5580 All-In-One InkJet...
I need to make double sided copies of a document. Please tell me how to do it on a hp photosmart C5580 All-in-one. thanks
The HP Photosmart C5580 does not support Duplex (Double Sided) printing, So you will only be able to print on both sides of a page by manually fliping the page over and printing on the other side of it. If you need it to scan both sides the same problem applies, as the scanner can only scan one side of the paper at a time. Sorry and Hope This Helps!
Mar 14, 2011 | HP Photosmart C5580 All-In-One InkJet...
Printed photos have red tint
check the tri color cartridge, it is possible that you may have more genta ink remaining in the cartridge then say the blue or yellow
as well as check the applicatiion you are printing from... it may be a setting in the rgb color format that is over riding the windows settings
Mar 27, 2010 | HP Photosmart C5580 All-In-One InkJet...
Paper micmatch error
use the HP ImageZone ...
go to printer settings
then go to the paper/quality tab..
in the first box...."print task quick sets"
choose the option named "default print settings"
select ok and close the Image Zone.
Dec 19, 2009 | HP Photosmart C5580 All-In-One InkJet...
Why will my HP Photosmart C5580 Printer not print email .
Go to www.partsurfer.hp.com and look under support and drivers. That's a known problem and a download is available to correct it.
Nov 17, 2009 | HP Photosmart C5580 All-In-One InkJet...
HP photosmart C5580 How scan to computer?
scanning through bluetooth is not possible bluetooth module only pairs the computer and printer and has link only to the basic driver of the computer so you can only print from it
if you want to scan you should connect te usb cable or use a wireless upgrade kit
Aug 10, 2009 | HP Photosmart C5580 All-In-One InkJet...
Photosmart 5580. How do I turn off the annoying
Because it is a photo printer it knows that the print heads must be aligned for optimum reproduction. You get a new print head with each cart.
For the amount of ink a test page uses I can't see the reason for complaint. If you begrudge the miniscule amount of ink and are not bothered about the best possible printing then just ignore it.
Jul 30, 2009 | HP Photosmart C5580 All-In-One InkJet...
I just bought a new HP photosmart C5580 with bluetooth wireless
Your printer can print wirelessly through bluetooth only.
note that your computer must be bluetooth capable also.
here's an instruction. Bluetooth Setup of Hp C5580
Apr 07, 2009 | HP Photosmart C5580 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
208 people viewed this question
Ben Johnson
