Question about Sharp AR-157E Copier
Blinking number and letter
The Copier continues to blink "4" and "H". What is the problem and how can I solve it?
  • 328 Answers
The fuser is not reaching the proper temperature. Try turning off the power and waiting a few minutes and turning on. If it still fails fuser or power supply needs replacing.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 01, 2007
Red spaner blinking plz help me?
When the key of the digital keys and the [CLEAR/STOP] button are pressed simulta-neously, an error code (consisting of a letter of the alphabet and numbers) appears on the LED display.
What is the error code?
If "C4x" error code, perform 08-400, reset the value to "0".
Jul 09, 2012 | Toshiba e-Studio163 Copier
AL 1631 Grayscale Copier: letter h is blinking in the display unit does not ...
all the codes with(H4,H3,.......)can be removed by simulation 14
May 16, 2010 | Sharp AL 1631 Copier
Blinking h4 always
Hi:
Try pressing these keys in this exact order quickly. # * CLR * Then key in 14 and press start. Then turn off the copier and turn it back on. See if this clears you H4 error..
Good Luck
Andrew
Jun 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
Letters and numbers appear in the display
L6 SHOWS LASER PROBLEM MOTOR MAY BI SENSOR.AND L4 DRIVE PROBLEM MAIN MOTOR OR MAY BI ANY GEAR IN DRIVE.CHECK ALL GEARS .DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Feb 19, 2009 | Sharp AR-5320 Black and White Copier
How to see the totla number of paper copied by the toner . Model Toshiba e studio163.
You can see a button on the panel on which, over the top it will we written 123 (not on the button). It will be after zero. (sorry yaar i just forget that is it star or hash). You press that button continuously for nearly to 5 seconds, on the display you can see some number blinking.
This is the first three or two or the first digit of the counter and after that then again it will be start to blink some three or two or one. if the copies are over 999 only you will be getting the second time blinking with some numbers. others wise you will be getting the same numbers blinking.
eg.: if " 3 " blink then 3 is the starting number
if " 31 " is blinking then 31 is the first two digits.
then in the second time if you seen some number like " 5" then 5 is the continuation of the numbers.
simple if first time 3 blink take the three as first number and second screen 325 blinks then take this set of numbers as the continuation of 3.
then your counter is 3325. ok
may be a big confusion, because i had given here a big statement for that simple statement. try this out.
Nov 16, 2008 | Toshiba e-Studio163 Copier
My copier/printer toshiba estudio 150
I had eStudio 161 with same problem. you can try this
COME TO PHOTO MODE
PRESS 'C'
PRESS 'PHOTO'
PRINT 'C' DISPLAY GOES BLANK
PRESS '1' , '4'
PRESS 'PRINT'
MAKE M/C 'OFF', MAKE 'ON'
Jul 28, 2008 | Office Equipment & Supplies
Xerox WorkCentre XD100 Digital Copier
L6:The Main PWB sensed a Polygon motor lock signal error.
That is related to the mirror motor within the laser.
The laser most likely needs to be replaced.
Mar 12, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
I really need to get my CD case out to make sure the code is the polygon motor, not a good sign, could need a new laser assbly.
Jan 23, 2008 | Sharp AR-M205 Copier
Blinking light
H4 is a fuser error, check the continuity of the fuser lamp.
Aug 27, 2007 | Sharp AL-1217 Copier
Sharp AR-157E Copier Logo
80 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
