Question about Astoria Argenta SAE-2 Espresso Machine
Hot water no steam low psi
Astoria SAE 2 6000watt
heads and boiler are clean
the proper temp is ?
  • Keith
    Keith Nov 18, 2008
    this is commercial machine setup for home use (overkill but fun)
    how do i up the temp? it's about 185 with thermometer.
    when idle top needle is in the green 1.25 bottom needle shows 7 and never more than 8.5 psi
  • 22 Answers
Boiler pressure gauge should be showing in the green zone which should get you 195+ degrees.
Posted on Nov 18, 2008
  • Alex Torello
    Alex Torello Nov 18, 2008
    Top needle is your boiler pressure, bottom is water pressure. To adjust boiler pressure (with MACHINE OFF, of course):
    Remove large top grate on machine.
    From a birds eye view, towards the back left of the machine you'll see a silver box w/black cover (pressure stat). Remove the flat head screw on top and remove cover.
    There is an adjustment screw left of center with - & + adjustment. Turn one full revolution at a time. Turn machine on each time and check to see where the needle stabilizes.
    <--KEEP AWAY FROM PRESSURE STAT WHEN MACHINE IS TURNED ON.-->
    Be very careful this is 220 volts of electricty you are working with!!
    Regarding bottom needle (water dispensing pressure) this should read around 4 when not in use. When dispensing (pump on) this should be in the green around 8.5 to 9.
    President:
  • 1,618 Answers
If you have hot water then the steam wands are blocked, either at the nozzle on the end of the steam wand or in the steam valve. The steam reading on the gauge should be at 1.2 bar, and the water pressure at about 3 bar until you run the group then that should read about 9.5 bars. You have 2 groupheads if you set the pressure to 9.5 when you run both at the same time it will drop to about 9 bar.
Posted on May 24, 2009
Why is water leaking from pressure release valve?
there can be two reasons I can think of that water drips from that valve :
1: thermostat for boiler is defective and not keeping boiler at proper temperature
2: minerals in water deposited inside valve and keep it from sealing off well
Dec 01, 2015 | Astoria Argenta SAE-2 Espresso Machine
Astoria Divina SAE/2N 2 heads. What would make the spout in between the heads be only cold water and the water level gauge shows all the way at the top of the glass?
If by spout you mean tea valve, it could be that the economizer mixing solenoid valve is set to deliver more cold water when mixing. As for the level the silver probe on boiler.
Oct 08, 2015 | Astoria Coffee Makers & Espresso Machines
Why does the pressure rise to over 3bar when the central heating is in operation ?
3 Bar = 43.5 PSI When you heat water it always expands increasing pressure.
In a closed vessel volume can increase by 2-3%. Either expansion tanks allow for this and PSI is maintain or without an expansion outlet the PSI will increase in proportion to heat supplied.
Is this a low temp hydronic boiler operating at or <140F, a hi temp hydronic boiler @ >180F or steam boiler?
Oct 18, 2014 | Water Heaters
I have a leak somewhere around the glass water level and it cnstant leaks
You might need to replace the gaskets on the water level or it could be from the connection to the steam valve from the boiler.
Jan 05, 2014 | Astoria Argenta SAE-2 Espresso Machine
Boiler pressure (steamer pressure) is at 0. Usually, when it goes down it comes back up in few minutes but not today. Also, the water coming out for our espresso shots is not as hot as it should be and our...
Problem is either the element, the pressure stat or the reset thermostat on the boiler left side if the model is equipped with one, has tripped, possibly because the machine is low on water in the boiler or the contacts for the pressure stat are damaged or dirty. First I would check the water level in the boiler then remove the left side panel and check the reset switch and press it in, then turn on machine to see if it heats up. If you do not have a reset switch on the machine then check the element and pressure stat to make sure they are working properly, do a resistance test.
May 28, 2011 | Astoria Argenta SAE-2 Espresso Machine
I have boiler pressure and steam coming threw the wands but no water flowing through the brew heads. What could be the problem?
Either the solenoids are damaged or blocked, or the metering jet on the top of the group is blocked, or the blockage is at the flowmeters. Do you get a reading on the pump pressure gauge when the buttons are pressed?
May 27, 2011 | Astoria Argenta SAE-3 Espresso Machine
Steam smells odd and affects milk taste.
The boiler is contaminated with milk and needs to be descaled and cleaned.
Jul 31, 2010 | Astoria Argenta SAE-2 Espresso Machine
I have bought a used Astoria sae Espresso Machine and I need to know how to clean it - can you help?
You'll want to back flush the machine with espresso machine cleaning powder:
http://www.kaldi.com/cafe_supplies.htm and regenerate the water softener regularly.
May 21, 2010 | Astoria Argenta SAE-2 Espresso Machine
Overflowing from valve on top of boiler on astoria sae junior also one button on control panel working intermitantly
On the top of the boiler is also the boiler water lever which might be dirty or full of scale. you nee to remove it clean it with a brush. the button migh iit becoming wet from water from above problem so ceaning the lever you can solve both. The button might already damge if you have work the machine for along time with button wet.
Nov 19, 2009 | Astoria Argenta SAE-2 "Big Gulp"
Astoria SAE 1 trickle of water from hot water faucet
Some models have an economiser valve, which mixes hot water from boiler with cold from inlet line, that could be closed or obstructed. The line from the boiler to the solenoid or the pipe inside the boiler could be blocked.
Mar 20, 2009 | Astoria Argenta SAE-2 Espresso Machine
Astoria Argenta SAE-2 Espresso Machine Logo
565 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
obsteiner
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
