Question about Garden
Fly wheel the fly wheel wont engage most of the time when i try to start the mower
  • 50 Answers
I believe that the ratchet mechanism is defective or worn. It will need to be repaired.
Posted on Dec 07, 2008
Why would a 15.5hp Lawn Mower won't start ?
sounds like you hit something hard and sheared the Shear pin under the Flywheel. Now your Timing is off
Aug 06, 2014 | Garden
Mower won't start
Battery charged?,sitting on the seat?, starter or solinoid working? Take out the spark plugs and try turning the engine underneath by using the pulley. Is the oil fresh?
Apr 20, 2014 | Craftsman Garden
2000 olds alero cranks then makes a metal grinding sound and won't start
You need to have your flywheel: replaced.Your starter motor engages against the fly wheel at the back of the motor. Every time your motor stops it tends to be in the same few positions (just the way things work) so there is more stress on some parts of your fly wheel than others. Because of this the teeth wear out on the fly wheel which means the starter can correctly engage on the fly wheel which is the grinding noise.
Jan 18, 2013 | 2000 Oldsmobile Alero
Toro electric starter will not engage
Starter bushing is bad....
Sep 10, 2012 | Toro Garden
I have a 6 hp self propelled Craftsman mower with
Ok this may be a simple fix. it has a high chance that the fly wheel key has sheared, this will cuse the timing to advance and bite your hand with the rope.
remove the pull starter and the cup ontop of the fly wheel, if you look straight down at the fly wheel nut you can see a cut out in the crank and fly wheel they should be aligned up if not it has sheared. use a lever under the fly wheel and put some pressure on to to lever it up then hit the fly wheel oposite side of the lever AWAY from the the magnet. and the fly wheel should pop up. replace the key and of you go..Make sure you use the OEM brigbs and strat key it is made out of alloy. The cause of this is the blade hitting a kerb or somthing hard,
Jul 02, 2010 | Garden
97 Ford Power Stroke, starting problem.
Does the starter engage the drive gear with the action of a solenoid? It may not be pushing (pulling) the gear far enough. There may be a slipping ring gear on the flex-plate. If you pull the starter again, you can try to see if the ring moves in and out or appears to be slipping around on the flex-plate. The flex plate could be loose on the crankshaft. In any case, the engine or the transmission would have to come out. Check the starter engagement before removing the torus and flex-plate.
Sep 14, 2009 | 2001 Ford Super Duty F 450
Wont start and has no spark,have fitted new spark plug
take cover off fly wheel area and sand rust off from around fly wheel should take care of it
Jul 19, 2009 | Garden
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
