Question about Saeco Incanto Classic Espresso Machine
Machine says insert dregdrawer
The machine says insert dregdrawer so we took it out and the put it back in but it still says the same thing.
    Sergeant:
  • Saeco Expert
  • 223 Answers
Looks like you have a faulty Dreg Draw Switch or Dump Box. Check the dump box and make sure that the tab that hits the switch is still there. If it has broken then you need a new dump box.
Cerini Coffee
Authorized Saeco Service Center
www.CeriniCoffee.com
Posted on Nov 18, 2008
Dregdrawer missing message won't go away
The dregdrawer is connected to a button/switch inside the machine.
- Switch broken.
- dregdrawer wrongly placed.
- dregdrawer is broken. (projection which goes into te machine is broken)
Sep 29, 2014 | Gaggia Titanium Espresso Machine
I have a red light and nothing is working no cofee and no milk nothing
I have a Saeco Easy. Maybe the solution for my machine will help you. You did not specify which light is red I will assume it is the "Alarm" light.
Alarm light (looks like an "!" exclamation point)
• permanently on: signals the machine is out of coffee, the water tank is
empty, the drip tray is full or the dregdrawer is full.
• slowly flashing: signals that the brew group is not inserted, the dregdrawer
is not inserted, the coffee bean hopper lid is not on, the service door is open
or the steam/hot water knob is not correctly turned to the desired position.
• quickly flashing: signals the need to prime the water circuit
Apr 19, 2011 | Saeco Talea Giro Espresso Machine
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
The brew group is automatically placed in the correct position.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
Can you you tell me why there is a flashing red light on the coffee machine
Descaling light:
• on and fl ashing: signals the need to perform a descaling cycle
Machine ready light:
• permanently on: signals that the machine is ready for use.
• on and fl ashing: signals that the machine is warming up.
Alarm light:
• permanently on : signals the machine is out of coffee, the water tank is
empty, the drip tray is full or the dregdrawer is full (in this case, also empty
the coffee grounds drawer in order to prevent failures).
• on and fl ashing slowly: signals that the brew group is not inserted, the
dregdrawer is not inserted the coffee bean hopper lid is not on, the service
door is open or the steam/hot water knob is not correctly turned to the
desired position.
• on and quickly fl ashing: signals the need to prime the water circuit.
Jan 13, 2011 | Saeco Odea Go
Dregdrawer Full
I read somewhere that there is a counter in the machine that when a certain amount of shots are done, the counter will reach its limit and tell you to empty the drawer, even if it's not full.
When I get the message I open the door, remove the drawer and it goes away once you replace it. Don't know why the machine would stop working though?
Apr 28, 2010 | Gaggia Titanium Espresso Machine
Dregdrawer. miss.
Make sure the machine is clean of coffee grinds. Mine has a nasty habit of dropping them behind the dregdrawer instead of in it. Remove the central unit and give it a good clean. The dregdrawer should then slide back fully into the microswitch.
If this doesn't work, you've probably got a dud microswitch.
Nov 20, 2008 | Saeco Royal Professional Espresso Machine
Gaggia syncrony compact digital - DREGDRAWER MISSING
the thing that dropped out was part of the micro switch for the dregs draw. Yes you can use the machine with the piece that you put in there, at some time you might consider just replacing the micro switch.
Sep 24, 2008 | Gaggia Titanium Espresso Machine
"dregdrawer" is full
You must have the dregs box out of the machine 5-10 sec and the machine have to be power on.
If it still not get to work then try this:
Make sure the pin on the side not is worn, the pin goes to a microswitch in the machine.
If it is worn then try to put a tape on it to see if help.
Best regards
/Mirran
Sep 11, 2008 | Saeco Royal Professional Espresso Machine
SEACO Vienna breakdown
If nothing is broken then this might be a easy fix.
first take out the dregdraw and the driptray.
Put one screwdriver on the sensor for the driptray/dregdraw at the botom left and one for the door up i the right corner .
This must be done when the machine is on.
It will then think the brewing unit is in position and move to the starting location.
Jun 21, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
258 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
