Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Noisey. when pumping ?
Unit is 2 1/2 years old. Pump was replaced twice under warranty , in first year. Is there another vendor that supplies a better pump ? Or is their something else to look for ?
  • corbykasten Nov 18, 2008
    OK. The pump did not leak. The machine washes fine. The pump was replaced twice because of noise, no other problems. The service people that did the Warranty work said that the pump was a common problem ? After a pump is changed the noise is greatly reduced.
    Corby
    Scholar:
  • 68 Answers
Have you checked with [assuming] your State's Attorney General Office? The third repair usually invokes the lemon law and requires that the supplier replace the entire dishwasher under warranty.
If you have not checked into that I would do that now and next.
This noise, from the pump, was the reason for the first replacement, or did it leak?
I cannot imagine them replacing a pump for noise, as noise, like hot, or cold is up to the individual what the parameters of PAIN are.
So let's suppose you cannot get a new dishwasher, and you have checked out the lemon law wherever it is you live, I will give you some technical answers and direct answers to your questions.
First, yes there may be a better pump, but these are generally not universal, the OEM pump is probably the only one that will fit, and should be the best available, anything aftermarket is generally not as good as the OEM [original Equipment Manufacturer].
I need more information on why the pump was replaced. Was it just noise? And did they run it in your presence after replacement, and did you buy off on it at that point? Then it got noisey again?
Now, next, a couple things could have happened, there could be noise baffles missing from the get go, or the first repair they left it out.
The pump could be cavitating, meaning there is not enough liquid, in the pump and it is swirling air.
Is the water pressure to spec, does the washer work or clean OK other than the noise?
There are so many possible reasons for noise from lack of water pressure, to missing baffles, to a bad product period, to the leveling is not right, to a clamp on a hose left off and when the machine calls for water the hoses slap or bounce.
This is going to be tough to settle over the phone, or email.
I would go to the seller and ask the same question then report back here, but before arm yourself with any lemon law data, and you could end up with a new washer for no charge.
There really are not huge differences in two pumps like this that would create noise, if there are two choices or more.
A pump could be made cheaper, the seals could fail quicker, but the noise thing, I doubt is a quality issue, something else is going on.
Will
Posted on Nov 17, 2008
  • William Babbitt
    William Babbitt Nov 18, 2008
    So the pump when replaced removes the noise and then it becomes loud after a while again?
    Common pump, that is typical of service people to say something like that.
    I have no idea if this brand has an above common pump or below common pump, but they must wear out pretty quick, and with that, what about your lemon law in your area?
    Forget the service people and go to the supplier or manufacturer and tell a supervisor your story, it is not your problem to figure out why their pump gets loud, it is their problem, there are tons of pumps and configurations and if I knew of a gold plated pump, I would lead you to it, but this sounds like a design issue.
    I know your frustration here, I had a new dryer from Best Buy that took 6 service calls, and finally they replaced ALL THE PARTS, but the problem was a sensor I identified, [I did not tell them] the first time it quit.
    Be nice but demand a new appliance, this is bull, we could search pumps forever, and get no where, they owe you a decent machine that lasts, call them, explain, be nice, be forceful, and don't accept anymore excuses, you have the evidence.
    Whatever pump they use might be a pump that is just cheap but built for that unit, maybe there is another pump, but it would take so much research it is not worth it, and likely there is nothing that fits without modification.
    I know that is complicated to someone that just wants a quiet washer, but three strikes, and the thing is not fixed, they owe you, make them give you a new machine period, end of story.
    the only other solution is to get an independent repair person, that knows these machines, and they may have a super duty pump that fits, but then the chances of finding that outfit is slim.
    Go for the lemon law, go to a supervisor as high as you can get, bug them until they give you what you paid for.
    This is about quality not so much technical, it is not like ordering a car with better tires, it is what it is, they do not have grades of pumps, or they would have put one in.
    See what I mean, write me back and let me know, stand your ground!
    Will
My Pump is new and is so noisey we can hardly hear ourselves talk
take it back and get an exchange unit under warranty
it is possible that it is sucking air and not water so make sure that the new pump is properly primed first
Feb 22, 2016 | Flojet R3526144A Potable Water Supply...
I have a Carrier Weathermaker model #38tdb060300 A/C system. How many tons is that? It is 11 yrs old, capacitor exploded and compressor is blown. Needing to replace.
Looks like a 5 ton unit. However, you might be better off finding a R-22 condensing unit to replace the entire outside unit. Reason being, if you just replace the compressor, you get a one year warranty. If you replace the whole outside unit, you get a 5 year warranty. You can replace the outside unit with any manufacturer, as long as it is the same tonnage and type (heat pump/air conditioner/single stage/ 2 stage ...).
Oct 13, 2014 | Heating & Cooling
I have a Hayward Super Pool pump for my inground pool. Was running the pump, heard a noise, by the time I got over to the pump to check it it shut off. It has been off for over 2 hours. It is not hot....
Get another brand. Hayward is junk. I had the same exact thing happen. Of course warranty is only one year. I paid out of pocket to replace the motor. Guess what happened 2 years later?
May 08, 2014 | Hayward Pool Products Hayward Northstar...
Franklin Executive 56 Hot Tub Spa Pump
less hassle whole pump replace
Nov 05, 2017 | Franklin Pool & Spa
I replaced the water pump on WTW6400SW2 cabrio washer twice already within the last two years. This unit is only three years old. Do you have a solution to the problem?
What was the reason. Pump Motor electrical coil failure ? or water impeller failed. If motor problem, you have to check the associated small capacitor also.Hope no water finds way to the motor.
Mar 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a 3-year old SP-500 that failed and my basement flooded. (Lots of damage). The float switch appears to have failed. Is this a manufacture warranty item?
Not after three years. Some pumps are warranted that long but floats are pretty easily damaged, jammed, or put into compromising positions so that they fail to activate the pump when they should. Rigid, on the other hand are very strong in their warranties. Some tools have a lifetime warranty. It is worth a check, but even if they replace the pump don't expect compensation for the dammages you suffered from the flooding.
Nov 01, 2009 | Ridgid 85937 SP-500 1/2 HP Submersible...
I need a motor for flotec shallow well pump unit #FP7100-08.The motor #S48D02AO3.WHERE CAN I FIND ONE AND HOW MUCH.Thank you Greg
Save yourself time and effort, replace the entire unit. I speak as a guy who has lived with a well for more than 35 years.
If you put a new motor on a old pump what do you have? A new $300.00 motor on a $worthless old pump. Spend the $350.00 and replace it.
Oct 27, 2009 | Flotec Corrosion Resistant Shallow Well...
My pump is making a loud humming noise and when I turned it on would not come on , just hummed. Tried again later and eventually came on but still making noise. Do I need a new pump. It is about 5 years...
My Sunterra pump made that noise and I had a problem getting it to come back on after unpluggin to clean pre-filter each time. It was not long after that the plastic impeller sheared in pieces (the pump was only 1 year old and thankfully under warranty) My guess is that this is fixing to happen to yours as well. You are lucky to get 5 years. There was no reason for mine to come aparts. Uunterra sent me a replacement pump which had been slightly re-designed of the same 2000 gl size and the new one jsut did the same thing (only 2 1/2 months old) I called them again which in the meantime will mean my pond going witout filtration once again. I am getting very upset about this and will be looking for a good deal on a different brand pump.
Oct 05, 2009 | Sta Rite Dyna Glass 1.5 H.P. 115/230 Pump
Ptac
You need a new control board. The relays go out on these. If your unit is less than a year old then you should still be under warranty. Unless you did not send in the warranty card, then the company only warrants the unit for 1 year after the mfg. date. You will need to provide the serial and part number to find out from Amana. The new control boards are much better by the way, and worse come to worse, they are only $130. Please let me know if this has helped in any way.
Dec 27, 2008 | Amana PTH123B25AJ Heat Pump Air...
Aquascape 3000 Pond Pump
I have had similiar experiances with these. My most durable pumps are 1. Atlantic water Garden Tidal wave 2 pumps. - ( 1 pump repaired in the last few years out of hundreds sold) 2. Pondmaster - most models. The pondmaster (Danner Mfg. customer service is fantastic- no hassle problem resolution). The pumps get better every year and THREE year warranty.
Nov 08, 2008 | Garden
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
158 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
