Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Ice maker not making ice
Had my fridge fixed this weekend. it wasn't cooling. service came out and fixed the problem, but the ice maker isn't making ice. And yes... I do have the lever in the correct position. Any ideas?
    President:
  • Kenmore Master
  • 2,651 Answers
A few things, was the ice maker working before repair?? generally the ice maker need to "cool" before making ice, usually give 24 hrs to start producing ice. next perhaps the tech shut off water supply never turned back on??? bottom freezer, perhaps he had to remove the ice maker to remove the back wall of freezer and never reconnected wire harness to the back wall.
Posted on Nov 17, 2008
Fridge isn't cooling
Its defrost issue.The defrost assembly parts are not functioning right causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Side by Side Refrigerator
Jcb 2059 ges Jen air fridge part not cooling freezer o.k.
If freezer cooling but fridge not cooling,then its a defrost issue.First freezer cools,then cool air from freezer gets to fridge and fridge gets cool.But if freezer defrost cycle not taking place then its faulty defrost assembly parts.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Jenn-Air JCB2059G Bottom Freezer...
Deawoo fridge freezer FDF-358 freezer is cold, fridge is not getting cold
The freezer section is working,but fridge is not because defrost door is blocked.Its a defrost cycle issue.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Chefmate mini fridge does not work after power outage
May be its board or board components got shorted.
These will help.
Thanks,.
Dec 22, 2012 | Koolatron Mini Fridge Compact Refrigerator
I have FBW600S omega fridge/freezer side by side. Ice maker still makes ice but when ice cube tray motor turns to empty cubes ice still stuck in tray
there's a heater on the ice maker,if the ice isn't coming out i'd have to say you have a bad ice maker
Nov 08, 2011 | Refrigerators
I have a Samsung bottom freezer top fridge RB215LASH. Water leaks from the inside back panel down under the crisper. The drain is not clogged. Their is no problem with the evaporator coils freezing...
OK, first there is only two ways water can be entering the fridge under any circumstances, one is through the Ice Maker feed line coming from your wall to the back of the fridge and into the ice maker. The other is from the ice trays themselves leaking or overflowing or the filter itself is leaking. Look at the side walls of your refrigerator, are there water streaks running down the side? Have you reset the ice maker since you did your repairs? Have you replaced the filter lately?
Usual Causes
If the water pressure is too high, the ice tray can over fill or water can splash out. You can turn the supply shutoff valve to reduce the water flow. See the diagram below. If the ice cube tray has residual pieces of ice in the bottom, remove the pieces by pressing the reset button. You may have to do this several times to clear all the ice out of the tray.
Get back to me and I know you provided a lot of information, but this is a inline water issue relating to the ice maker and not really thinking it could be anything else. So if you can give me more information about the form in which this happens, such as you find the water after the trays are filled or if this is a constant but minimal flow, large flow, we can concentrate our plan towards this are of the repairs and diagnosis. Look forward to hearing from you soon.
Aug 04, 2011 | Refrigerators
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | General Refrigerators
My fridge (a Frigidaire) had been running for the past weekend. Everything was melting in the freezer and the fridge side was warm and had no cold air. We called in for service and it turned out to be a...
sir before changing the said spares you had to check the compressor and the refrigrant of the refrigrator.if you have not checked the compressor please do it.
Sep 11, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
351 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
