Computer won't wake up
Running XP. Computer won't come out of sleep mode. When I hit the space bar to bring it up, the fan and hard drive light kick on for a second and then back off. I shut the thing down using the power button and same thing when I try to turn it back on - fan and hard drive start to work and then turn off. If I continue to hit the power button, eventually the thing stays on but is not sending a signal to the monitor. The fan continues to run but the hard drive light goes out...
What to do?
Thanks in advance!
  • 4 more comments
  • cuphoto Nov 17, 2008
    No signal to screen at all
    I'll give it a go...
    No Such luck...Anything else I can try?
    On the front of the machine is says I have a nVIDIA GeForce 6100, PCI Express Slot available. I see two cards installed - one has phone jacks and the other TV and AM, FM cable jacks. So I assume I have on board graphics...?
  • Anonymous Dec 30, 2008
    Computer was left logged off, but now no amount of shaking the mouse, hitting esc, spacebar, or any of the keys wake the computer
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    do you get a post screen at all?
  • 4,806 Answers
Ok, there could have been a graphics issue in the bios caused by the windows graphics drivers, heres what you could try........... remove the power cord from the back of the machine, remove the side panel to allow access to the motherboard, you will see a battery! take it out for 10 mins and push the on/off button a couple of times, this will drain any remaing power from the motherboard, after 10 mins the CMOS should have cleared so you can replace the battery, plug in the power and turn the machine on hopefully you'll get a signal
good luck
Posted on Nov 17, 2008
  • Lee Hodgson
    Lee Hodgson Nov 17, 2008
    are you using on board graphics or a graphics card?
  • Lee Hodgson
    no, what you are describing is a TV card and your PCI express graphics card have a look where the ethernet cable plugs in to see if you can see a "VGA" slot or D-plug, if there is one there, then you do have on board graphics, try ro remove the Nvidia card and plug the monitor on to the on board D-plug, see what happends
    regards
Monitor slow to wake up
A computer uses sleep mode to save power and save certain key functions so that users can resume work quickly without waiting for the computer to completely restart.
There are usually at least two types of sleep modes: an ordinary mode in which the current state of the computer is kept operational, and a deeper hibernation in which current settings are saved to the hard drive.
When a computer does not leave the sleep mode, there is most likely a problem with power settings.
Power Button Use
Some sleep modes, especially the hibernation modes, remove the ability for the computer to sense outside movement.
If the user puts the computer into hibernation, then typing on the keyboard or moving the mouse will not wake it, even if these actions work in a light sleep mode.
The only way to wake the computer up is to press the power button.
Power Settings
Computers have power settings that tell them when to perform certain actions, including powering down and going into sleep mode.
Normally, computers will do this automatically when they have low battery power, but if the settings are changed it is possible the computer will only exit sleep mode when connected to a power adapter.
Users can change power settings themselves to more appropriate levels, if necessary.
BIOS Settings In BIOS (basic input/output system) mode, a PC shows not only the last actions that triggered the computer to go into sleep mode, but also what wakes the computer up from sleep mode.
Typically several devices, including keyboard and mouse movement, are listed.
However, if the computer is not programmed to wake up from sleep mode when these devices are used, it will stay unchanged. Users can add or remove devices from the BIOS system itself.
Vista Problems
Microsoft Vista has been known to develop several errors associated with the ability of the computer to wake up once it has gone into sleep mode.
If the user has Vista, it is possible an internal error, possibly connected with the USB ports, has caused the computer to remain in sleep mode.
Users can fix these malfunctions by downloading "hotfixes" from Microsoft's website.
Video Card or Screen Problems
If the monitor refuses to wake up from sleep mode but all settings appear applicable, then the problem could be with the video card or the screen itself.
In this case, the computer is resuming activity but the monitor cannot show it, so it looks like it is still asleep.
The user should make sure the monitor is working properly and make sure the video card is not malfunctioning.
You should also check ram Hard Drive & vga lead
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
Restart your computer then reinstall it this should activate found new hardware wizard
Check the vga lead for secure dust free connection or try another vga lead.
Aug 11, 2013 | HP Computers & Internet
Windows sleep mode problems
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Dec 21, 2012 | Computers & Internet
I just added a LCD monitor to my eMachines ET1331G desktop computer. Everything worked fine until I left it on for a day. The computer went into sleep mode and now I can't get it to wake up. I've trie
You should be able to just press the main system unit power button to wake up your 'sleeping' computer which will then resume your Windows desktop and bring you back to the Login panel if you have a password set for your account.
Dec 29, 2011 | eMachines D Computers & Internet
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
My hp vs19d power button blinks on and off slowly. what does it mean? if i let the computer sit for say 3 hours the monitor will stay blank. even after moving the mouse to wake things up
the monitor is in sleep mode ... have you tried hitting the keyboard Space bar?
if you disconnect the video cable from the pc does it display ( video disconnected) ? if it does it then is probably the sleep issue
Oct 06, 2009 | Computers & Internet
Can't wake up....gone into sleep mode...how do you wake it up
press and hold the power button down for about 5 secs. The computer will shut down. Restart it and right click on the desktop, go to properties then look for screensaver tab , then choose power options, click on hibernation tab at the top and uncheck enable hibernation. Or choose stanby options and choose a longer time before the computer goes to sleep.
Mar 21, 2009 | IBM ThinkPad T23 2647 Notebook
I have a Dell Inspiron 530
I have a Dell Inspiron 530S, and it exhibited the same symptoms as rguggemos's & Wilburollie's.
I can put it to sleep, but when I try to wake it, it won't. The screen will stay black. I can hear the drives spin up, and the fans go on FULL blast, and the blue power LED stays flashing, but the computer will stay like that - no picture or anything. Then I'd have to press & hold the power button to force it off, then power back on. Not ideal.
The solution that worked for me?! On boot, at the "DELL" logo, hit F2 to enter the BIOS setup, go to Power Management, and change the standby mode from S3 to S1. The difference? S3 is a "deeper" sleep, w/ more components powered off, which is better, energy-wise, but it is more difficult to wake from. S1 is a "light" sleep. Give it a shot! Maybe it'll work!
- Mike
Stolen from another forum:
S0 (Working) is lit. The CPU functions in entirety; the conservation of power is on a basis of by-device.
S1 (Sleep). The CPU is stopped; The RAM is regenerated; the system functions in reduced power.
S2 (Sleep 2) The CPU does not have any power; The RAM is regenerated; the system is in lower mode of the S1.
S3 (Standby) The CPU does not have any power; The RAM regenerates at minimum; the power supply unit is in mode of reduced power. This mode is also called “Save to RAM”.
S4 (Hibernate). All is powered off, but the memory was saved like temporary file on the hard drive. This mode is called “Save to disk”.
S5 (Off) Everything is shutdown. Means you need a full reboot.
Dec 11, 2008 | HP Media Center m7060n PC Desktop
Monitor goes to sleep and computer will not boot
If your monitor goes to sleep, how do you know it got to window xp screen ?
Sound like your stuck in a loop (bad boot sector). You might have to reinstall windows again.
May 06, 2008 | Computers & Internet
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Waking up after going to sleep
I have had similar problem. I found, by trial and error, that using Windows hibernate mode actually works every time! Windows makes a "System screen shot" and stores it on hard drive and then powers off. Just be aware that you must ensure enough hard drive space for this. I am using this mode every day now.
Jun 21, 2007 | ASUS W7J Notebook
Computers & Internet Logo
311 people viewed this question
David Payne
David Payne
