Question about Amana Refrigerators
My wife is cleaning the freezer of our side by side and she noticed the lower part of the cooling coil is red hot
    President:
  • Amana Master
  • 2,651 Answers
Thats ok it was in a self defrosting mode, totally normal to do that.
Posted on Nov 17, 2008
Kenmore Elite fridge cools but we noticed the compressor and fan never turn off. Compressor is very hot to touch. Do we need to replace compressor or a relay switch or ...? Thoughts/suggestions?
Newer refrig. Run almost continuous but you could try cleaning the condenser coils, located on back with vacuum and brush also place thermometers in freezer and mid level refrigerator, freezer should run 0 to -8 F and refrigerator 34-37 F. If much lower adj. thermostat up.
Sep 16, 2017 | Kenmore Refrigerators
Freezer and referigerator only cool, no cold
Sounds like the freon is low. Needs a repair man with a tester to check the pressure. when he is there check for small leaks in the lines as well. It's tryng to work but no pressure to work wityh.
Feb 22, 2014 | Refrigerators
The strip between freezer and refrig become hot then cools off. It's like it is going thru a cycle. We cleaned the coils underneath, but it is still getting hot and then in about 15 minutes, it's...
When you cleaned the coil underneath did ya notice that their was air being blown out their by a fan,having clened the coil was a good start but if the fan by the compressor isn't running that divider between the ref/freezer will be hotter than normal( its normally warm and thats ok),so check that the condenser fan is running and that it seems to running at a good speed.
GENE
Sep 23, 2011 | Whirlpool GC5SHEXNS Side by Side...
I lost power for 4 days after hurricane Irene. I removed the lower drawer from freezer (just to clean) and haven't replaced it . After our power came back on everything seemed to be fine, but this a.m....
I have the feeling that you were seeing you defrost heaters that keeps ice from building up in the freezer section. This is normal operation as long as it doesn't stay on continuously. Your defrost system is made up of a defrost heater, defrost thermostat and defrost timer.
Sep 04, 2011 | Kitchen Ranges
Ice collecting in bottom of Kenmore Coldspot freezer side and then melting and ending up on the floor. It was first discovered by a puddle on the floor. This model--"59282990"--has...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 09, 2011 | Refrigerators
Where would I find the model number for my Amana side by side refrigerator.The problem I have is that the freezer section is keeping solids frozen,but not ice cream and concentrated juices.I noticed the...
Most of the time when the strip is hot it is due to the condenser coils being clogged. If you pull the kick plate off under the door, you should find some coils with dust, hair, and other various debris that has to be cleaned off the coils. These coils can become insullated with dust bunnies and not allow the freon to release enough of the heat as it flows through the coils. The coils actually run through the cabinet where the metal strip is getting hot. Break out a vacuum and clean off the coils and then give it a day and the unit should begin operating properly again. If you can't find the coils underneath remove the back access panel and they should be located to the right of your fan. Also make sure the fan itself is running. The fan is what moves the air flow under the fridge to cool the coils, if it is not running it can cause the same issue.
May 25, 2011 | Amana Refrigerators
My frig is not cooling the temp is currently 68 but the freezer is fine any ideas
The refrigerator compartment is cooled by the cold air from the freezer. This air is blown in through a vent between the freezer and refrigerator compartment by the evaporator coil fan in the freezer. If the vent is blocked or the fan is not working would be the reason that the freezer is cooling but the refrigerator is hot.
To troubleshoot, you must remove the panel that covers the evaporator coil in the freezer. You will need to remove the contents of the lower section of the freezer to get access to the panel near the bottom of the freezer. Once the panel is removed, you should be able to confirm whether the fan is spining. If it does not turn and it is plugged in and the refrigerator is not in defrost mode, then the problem is with the fan motor.
If the fan is spinning but you notice ice buildup on the coil, the problem is with the defrost circuit. Typically the failures are with the defrost timer not functioning or that the defrost heater has failed. Hope this helps you.
Jul 22, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Compressor not running
you can try to repalce the "overload relay", with the model numberlook up the correct part. i would also check with oyour manual perhaps you have an extended warr. on your compressor assembly( comes with a new overload relay)..
Mar 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Door heater around freezer very hot all the time
Stever, this is usually an indication of a condensor fan not operating correctly. Pull the refer out and remove the back panel by the compressor. See if the fan is blocked or not running. It should run anytime the compressor is running. Catriver.
Sep 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
65 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
