Question about Kenmore 62602 Electric Dryer
Dryer not heating
Blows plenty of air but will not heat.I recently pulled the dryer out to get behind it and when I might have crimped the the hose in the backand blocked the air from coming out the back.Would this trip something in the dryer if it got to hot?If so can you tell me how to get to it.Thank you
  • robscarpet23 Nov 19, 2008
    I found the problem,I had bumped into the 220 plug and it came out just enough so that the heater coil wasn't working.When I pushed it in it started to heat.I did not know the dryer would still run but not heat if the plug was not the whole way in
    Problem Solver:
  • 14 Answers
Don't think so. My issue with the no hot air on the dryer was the relay switch. There is also a heat switch and thermostat that could be a problem.
Posted on Nov 17, 2008
Dryer lost heat
This may be a heating element issue.
If you want to do a few things before calling someone, you would want to start by making sure all of your dryer settings are set correctly. Some dryers have "air" settings or "delicates" settings. These settings are going to be very low heat so the clothes are not ruined.
Also make sure that the lint screen has been cleaned each and every time you have started a new load. If not, you can UNPLUG the dryer, pull the dryer out and with some simple tools, take the back off and vacuum what you can get to. If it's very dirty you'll want to call a professional. You'll need it cleaned and your problem diagnosed. If cleaning the lint screen is not something you have done on a regular basis, then please start. This could be a fire hazard if it is not cleaned regularly.
Another thing to check is your vent or vent hose. Depending on how your set up is, if your hose is crimped behind the dryer and the heat can't escape, the clothes will not be able to dry. This would only be something if you have some heat but clothes are not drying. Also, sometimes due to the age of the hose, previous use, not cleaning the lint screen, etc, the venting from the house to the outside could be clogged. Again, there will be some heat, but the clothes will seem to take forever to dry.
Good luck.
Feb 24, 2015 | Dryers
I have a gas dryer that when cycle begins it heats but after a while it stops heating and it takes too long for clothes to dry...Why is this happening?
I would check the the vent hose first. It might be clogged with lint or stopped up some other way or even crimped where the air won't flow. Turn on the dryer and go outside and be sure there is a good flow of air coming out of the vent. If there's not much air flow dis connect the hose and clean it out
Dec 13, 2014 | Whirlpool WGD4800XQ Whirpool 29" Gas Dryer...
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Does not heat enough to dry the clothes the first time. Must dry twice.
check the vent hose sounds like it is plugged, might be a birds nest in the outside vent, when the vent is blocked the dryer can not pull any air into the dryer and can't push out the moster leadden air, make sure you check the in tire exhaust hose even right behind the dryer were the hose atches to the unit......GOOD LUCK
Dec 01, 2010 | Whirlpool LER4634J Electric Dryer
Dryer is on but wont dry cloths no water in tray
More info is needed, but I'll take a shot at this.
First thing I'd want to know is if the heating element is putting out. If it is, I'd first check for a good air flow out the dryer vent. Sometimes an obstruction (such as a critter nest) will deny air flow and not allow the dryer to do its job. Also, the dryer hose could be pinched or crimped.
If the dryer is not heating at all, you will probably be needing a new heating element.
I hope this helps and is a quick fix for you...
Sep 03, 2009 | Dryers
Dryer heats for 10 minutes and turns off
Turn the dryer on, go out to the where the vent exits the house. Feel the air coming out, and it should blow very strong, and for the total diameter of the discharge. If it doesn't, the vent pipe is plugged, or the connection hose from wall to dryer is crimped/collapsed when pushed back to the wall.
Also make sure lint filter is clean, and the grill inside the dryer where hot air enters is clear.
Reply back your findings and I can help you more.
Jan 29, 2009 | Dryers
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
DEIX2 not heating Fisher & Paykel
when you moved it back you crimped the vent hose / pull dryer back out from wall and make sure it is curled with no kinks as you slide it back into place and it will be fine.
Larry
Nov 25, 2008 | Dryers
My Whirlpool AWZ7303 Condensor dryer wont dry the clothes. It heats up, and you can see the steam on the clothes. I think that its not extracting the moisture properly. The water collector does get full...
Your vent hose is crimped or clogged. Take hose off and see if air is coming out. Bet your dryer has been push against the wall and crimped the hose. This is the problem 8 out 10 time but if it isnt let me know. There is more tricks.
Oct 23, 2008 | Whirlpool Dryers
DRYER RUNS BUT, NO HEAT
They normally have a thermal cut out on the rear, behind a small cover or rubber area. Reset this by pushing it in. You have probably let it get too hot at some point by not keeping the filter cleaned often enough, or the outlet hose getting blocked. If there is not a reset, or it doesn't resolve the problem, it may be a fault with the hetaer element. These are not normally difficult to replace, just normally difficult to get to!
Jan 22, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
79 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
