Question about Kenmore Elite 45986 Front Load Washer
Washer was disconnected, after reconnect, will not work.
Kenmore Elite frontload washer was re-connected to run a load of clothes. The lites are on like normal and momentarily there is a sound of water but the washer never starts it's cycle instead a reading flashes indicating F15 or F20. The soaps or water never reaches the clothes.
    Scholar:
  • 68 Answers
Why was it disconnected in the first place, and what is disconnected, from the plug, breaker, where?
Easy fix can be to simply remover the power cord from the outlet for 20 minutes, make sure the water valves are on, both hot and cold, see if removing the power will reset the machine.
If not write back and we go from there.
Will
Posted on Nov 17, 2008
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
Kenmore Elite Washer wont start
Plug off the wall socket. Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. This normally works.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Jun 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Frontload Washer not working
If you already changed the door lock the only other thing that controls that is the control board... It might be faulty.
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Frontloader door keeps breaking
Call your retailer directly to make you whole.
Video tape the events and send an email to Kenmore.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore 44102 Front Load Washer
Kenmore Elite F02 code even after changing to a new pump.
remove compartment cover under the front load door. There is a drain there that will catch large items left in your clothes, ie pens paper etc
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Torn seaL ON KENMORE ELITE WASHER
i have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
Mar 22, 2009 | Kenmore Elite 45986 Front Load Washer
Power out when running. showed code F 71 now not working.
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite F25?>
F25 = DRIVE MOTOR TACHOMETER ERROR
mostly likely need to replace speed control board
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
