hi textmum,
Usually anomalies of this kind on the print output indicates that the printer is overdue for a maintenance cycle. This is due to the usual operating wear and tear the printer experiences during it's life cycle.
Seeing as how this could be an expensive operation, I suggest we first eliminate problem with the printer driver as the cause of the anomalous print output. To do this I need you to reinstall the printer on your PC using the latest drivers:
- Download the latest driver for your printer at
http://www.samsung.com/za/support/download/supportDown.do?model_nm=ML-1520&mType=DR&vType=L&disp_nm=ML-1520
(be sure to select the driver which corresponds to the operating system you are running on your PC)
- Delete the printer from your PC
- Install the printer using the newly downloaded driver
If reinstalling the printer using the latest print driver doesn't result in a solution to the print output problem, we can deduce that the problem is caused by a hardware component.
To solve the hardware related problem you will need to either perform the maintenance cycle yourself or take the printer to a computer repair shop so a IT technician can do it for you. This process involves buying a maintenance kit (which contain replacement components for the printer), and replacing the components according to the maintenance kit manual.
Hope you find this information helpful in solving your printer related problem
