Question about Compaq Presario 700 470024-192 Notebook
I have a Compaq C700 and the touchpad and keyboard are not responding. What should I do?
  • sivanaidu_14 Dec 26, 2008
    i have c700 laptop touch pad but not responding properly
  • Jack Esquivel Oct 14, 2012
    update your bios to latest one, and update to windows 7 that fixes all the problem except the overheating
Update your bios first off second upgrade from what ever windows you have (xp , vista ) to windows 7 that will fix those problems but it still over heats
Posted on Oct 14, 2012
  • Compaq Master
  • 4,806 Answers
Sometimes holding down Fn and pressing F7 works on some models, this is not guarranteed to work
have a look in the bois to see it there is an option to activate it, if not then you can always use a usb keyboard and mouse until you resolve the problem, make sure the USB controllers are all enabled in the bios
regards
Posted on Nov 17, 2008
    Sergeant:
  • 237 Answers
First of all, what are the circumstances that led to this event? If you can please describe it for me.
What you can do in the mean if you have an external mouse,
Try this:
Assuming you have Windows XP, go to My Computers icon, Properties, Device Manager, Go to the Keyboard and click on the plus. Check and see if there is anything there. (Example, if there is a red X, that means the device is disabled) Enable the device, and do the same for the touchpad.
If these are enabled, go to Compaq's website and download the drivers for the touchpad and the keyboard.
  • 93 Answers
Check if the touchpad be disabled from BIOS;
See if it still same if you use USB keyboard and mouse?
Try update BIOS from HP web.
Compaq 730us touch pad not responding
Hi
To fix an unresponsive touchpad on your laptop/desktop XP Home, XPPro:
Reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
Please take time to rate me
Sep 06, 2011 | HP Compaq Presario 730US Notebook
My compaq laptop touchpad is not working properly
i have compaq c700 with win 7 the touch pad not work
Sep 02, 2010 | Compaq (153515-001) Touch Pad
I'm looking for the driver of compaq presario c700
What driver - graphics / audio / touchpad - you must be specific
Jun 16, 2010 | Compaq Presario 700 470024-192 Notebook
How to enable synaptics touchpad scrolling in compaq presario c700? I have installed latest Synaptics Touchpad drivers.
Just make sure your synaptics touchpad runs when during your PC start up.
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Mar 30, 2010 | HP Compaq Presario C700T
My laptop is c700 compaq presario. Its touchpad is working but click is not falling. I'm using windows XP. Pls help
try to install the driver for touchpad, if the same check the hardware.. or try return to vista if working properly it means some problem for os xp.. because you downgrade the system...
hp company advice all user to do not downgrade but we can we use xp. the problem only not compatible some drivers
thanls
Sep 05, 2009 | Compaq Presario C700T Notebook
Touchpad is not responding and keyboard
Try shutting down the device and taking out the battery for 10ish seconds. Reinsert it, and power up your laptop. Sometimes this method takes 2 tries, but usually corrects the power/allotment conflicts keyboards and touchpads have with HP motherboards.
Aug 20, 2009 | HP Compaq nc6220 Notebook
Compaq Presario CQ60 touchpad problem.
The touchpad on my Compaq Presario CQ60 has stopped responding
Aug 17, 2009 | Compaq Presario CQ60-220US PC Laptop
Unlocking Numbers on keyboard of a Compaq Pressario c700 on Vista
you can use numlock button together with "Fn" button that is usually blue and locating keyboard down/left corner.
Dec 09, 2008 | Compaq Presario 700 470024-192 Notebook
Touchpad doesn't respond
MY SOLUTION - Hello, I have Compaq Presario V2000 Laptop and at once my touchpad stopped working.
So i rebooted it several times but it still didn't work.
Then i detached the battery from the laptop and let it like that for 5 min. I attached the battery again and the touchpad was working again.
So, try the simplest solutions first before you start messing with complicating solutions.
Good luck !
Nov 11, 2007 | Acer Aspire 5610-4648 Notebook
Compaq Presario 700 470024-192 Notebook Logo
233 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
