Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washing machine will not start a cycle.
I have the Duet washer and dryer. Not sure of the age, were included in the sale of the house we purchased in June. They receive moderate useage,4 people in household. The washer has been fine. yesterday after completing a cycle, it would not start to begin another one. I dialed the cycle I needed, closed the door which clicked shut, add detergent & bleach, pressed the start button, and nothing happened, no error codes appeared. The red light next to the selected cycle blinks, all of the other red lights by the water temp, cycle speed, etc. are red,not blinking, there is no click sound when the water start to flow,the machine just fails to start.I had just completed a cycle, it performed as always, and this happened with the next cycle. My husband followed the troubleshooting page in the manual, made no difference, any suggestions.
  • Anonymous Mar 02, 2009
    Whirlpool Duet washing machine will not start a cycle light blinking
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Posted on Nov 17, 2008
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Age of Whirlpool Duet Serial Number CSP 2807389?
Age of whirlpool duet washer/dryer with sn csr2213663 model either ghw9250mt2 or gew9200lt1
Jan 31, 2014 | Whirlpool Washing Machines
My dryer says "control locked".
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Dryer that indicates the "Control [is] Locked. The problem somehow began while I was away over the weekend and it no longer allows me to start the dryer. (I have a total of...
Hello
Your whirlpool duet dryer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My dryer is not starting all the lights are on i am not getting an error,i pick the cycle but it does not start
more than likely its the thermal fuse located behind the access panel its a skinny white part right behind the blower housing
Jan 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
May 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Clothes not drying
is this a washer or dryer if its a dryer you need to check the air flow where the dryer vents outside the house make sure it is flowing good it may need to be cleaned out
Jan 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine won't start
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
Nov 16, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
598 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
