Projection TV MITSUBISHI- VS6055 PROJECTION TV. Just suddenly dead power off. Try to turn it on again but only hear a clicking sound at the rear. Please let me know what's wrong .. Thank you Sergie
  • TonyPeardon May 05, 2009
    Mitsubishi VS5061c clicks from the rear when turned on. On-screen menus still work, but screen stays black.
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Initially, the clicking sound is the relay inside that is engaging. In some instances, this symptom could indicate that the relay contacts have corroded or burned and are no longer providing electrical contacts. Normal course of repair would be replacing, but some have known to work with even just cleaning/scrapping.
That above was the easy probable fault. At other other times, the relay clicking indicates the the Mitsubishi is triggering off, meaning its built-in protection has kicked in. This is indicative of a hardware fault. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hopethis be of initial help/idea. Pls post back how things turned up orshould you need additional information. Good luck and kind regards.Thank you for using FixYa.
Posted on Nov 17, 2008
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a Toshiba #50HP16. The picture just went out without any warning, could still hear the sound. Turned it off and now it will not come back on, not even the sound. You can hear licking like it is...
U hear alots of clickings,when power turn on?Yes,the tv projection lamp might be dead also,require replacing?But the board call the Ballast board is 100% dead.This Ballast board job,it to help to ignite the tv projection lamp.Tries websites like Partstore.com,Ebay.com to buy parts like projection lamps and Ballast boards for DLP projection tvs brands.
Oct 19, 2010 | Toshiba 57H81 57" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
Heard clicking sound then pictures suddenly disappear and the tv keeps turning off and on by itself
The tv have a board call the Ballast board,that help to ignite the projection lamp.Tv power on hear alot clicking.That mean the Ballast board is dead,must be replaced.
Jul 13, 2010 | Samsung HLP5085W 50" Rear Projection...
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
Jun 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Mitsubishi Medallion rear projection lost signal from all devices
Have you fixed this problem yet?. I seem to have the same issue.
Sep 07, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Smoking tv!!!
Good Day, gongora326;
It sounds like the TV has some type of short in the power or high voltage circuits.
I would recommend that you call a factory authorized service company to come to your home and give you an estimate.
I hope you take my advice, good luck, big IRISH.
Jul 08, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Just plain dead
unplug keybord and try to turn on with remote.
Sep 23, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Open Questions:
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
