Question about BlueSocket WG-2100 (WG2100) Firewall
Problem Hotmail Hi,I make An Installation Of Internet With a 1721 Cisco Router and two Access Point Mikrotik With A blue Socket GateWay.all the web pages are accessibles but the only Hotmail.com couldn't be visible. i will ping to it in Prompt mode but in IE I can't. please If U have any solution contact me at felyouness@hotmail.com it's very urgent Thank's
    Scholar:
  • 27 Answers
I would download and install Mozilla Firefox. Then check to see if the problem still existed through Firefox. If it works through Firefox and not through IE, I would check my privacy and security setting in IE. Hotmail likes to send you cookies and you are posibly blocking them. If you try this and download FireFox DO NOT import setting from IE. Install Firefox with default settings. If it is cookie related, importing setting will only give you the same problem in Firefox.
Posted on Jan 29, 2007
  • elecadvisor Jan 29, 2007
    Additional comment:
    In my experience it is always a good practice to have and install multiple browsers in the event one fails. I always keep the installation files on the computer so that I can reinstall them as well. If IE is crippled, it might have to be reinstalled. Unless you are running Vista, I would not upgrade to IE 7. The interface is different and it still has a few bugs.
Unable to browse to cisco access point
'192.168.0.116' is the wrong range for the router. The Cisco manager allocates the ranges the router will use.
See this page on the setup.
Getting Started Guide Cisco 3700 Series Access Points
May 28, 2014 | Cisco Computers & Internet
Can get router to work
The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
This resetting process works through your internet browser.
Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
Enter your user and password information from the pop up menu.
Click on the "Setup" button from the summary status page.
Select the "Cisco Services" setup option and click on "Manage System Configuration."
Click on "Reset All System Factory Defaults" to reset the router.
The Cisco Aironet 1200 will be restored to factory defaults.
http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
Samsung BD 6300 blue ray player does not connect to wireless access point. Gateway ping seems to be the issue, current gateway is on the network. Using my landlords router with his permission. Suggestions...
I'm not sure if I'm reading this right but, Is the Access Point in your apt? Or are you trying to access his router directly with your 'Player?
If you are trying to connect to an actual Access Point, try connecting to the AP from your computer either wireless or via the Ethernet cable and set it up to access his router/internet. When you can surf the Web or access his network on the computer using the AP then unplug the cable if you used it and just go into the Samsung's network settings and try again.
The only other thing I can think of is make sure his router is set to MIX, b/g/n speeds.
Jan 04, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I'm trying to configure my Cisco WAP4410N Wireless-N Access Point and i cant access the login page to do it. My IP is already set to 192.168.1.# so i thought i would be fine but it still doesnt work
Network settings on your computer
right click on lan network and properties go to ipv4 properties and use the following.
IP address 192.168.1.2
255.255.255.0
router defaut in the default gateway settings (mine was 192.168.1.245)
enter that again in the dns primary (dont worry about the secondary)
plug an ethernet cable to your wireless router and type in the default gateway.
that will get you to your logon page.
hope that helps
Nov 03, 2010 | Linksys Cisco Small Business WAP4410N...
When i boot up my router the output is all mixed up characters
I recently had a similar issue with a wrt54g Linksys (by Cisco) router. It happened when I used Internet Explorer 7 or 8. When I used Firefox, there was no issue. So, I suggest using a different web browser.
Oct 28, 2010 | Cisco 1721 Router
Gateway not pinging from dwl 3200 ap . AP=192.168.4.250/24 in the same subnet, gateway=192.168.4.1 , gateway assign also on wireless adapter , wireless adapter address also in the same subnet with right...
Remove the cables from the gateway router to the switch to leave only the uplink cable or connection to your telephone socket.
Test connectivity by plugging your laptop or computer directly in to the gateway router and test web access using an Ethernet cable.
Your laptop /computer may need to be rebooted for new ip. If ok reattach the unmanaged switch a retry by attaching the Ethernet cable to one of the ports on the switch. If ok, this limits the problem to the access point.
The main problem is that you have two layer 3 devices connected together by a layer 2 switch.
The solution would be to retain the configuration on the gateway if all ok. Change the access point to a different sub net and SSID to the gateway router.
If you can shut down the broadcasting from the gateway as all WLAN will be done through the access point.
Ensure that DHCP and DNS is switched on, on the gateway router.
All computers should be configured to use the gateway router address as this will allow the gateway to provide routing across the network.
Jun 30, 2010 | D-Link Computers & Internet
Cisco 1721 Router IOS
I can help you with the IOS you need, but Cisco does not list 12.3.x XC, they only have YZ, YG, XR, XK, XG for this router. Email me at thrca@thrca.com for more help.
Aug 30, 2009 | Cisco (WIC-4ESW) 4-Port Ethernet Switch...
I cannot access Internet but i can ping my Gateway and DNS
Hi
before i suggest u any solution here is what i want u to test on ur pc
1. turn off all the anti-virus, firewall or any other security software.
2. try access the internet then. if it start working then any recent firewall update might have caused it.
3. if not try access the internet with any other browsers like firefox etc and one more thing are u able to access ur router firmware (router page) from this pc or not.
i need some other information as well
OS: windows xp or vista?
when was the last time it was working any recent changes like new software installation etc
Aug 21, 2009 | Computers & Internet
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Cisco 675 Router
CISCO 2800 router interface stop responding
What kind of cable do you have connected from the DLINK to the Router? Is it an ethernet cable 3,5e,6?
Sep 13, 2007 | 3Com OfficeConnect (3CRWE454G75)...
Computers & Internet Logo
116 people viewed this question
Top BlueSocket Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a BlueSocket Computer and Internet Expert? Answer questions, earn points and help others
