Can't figure off how to get kr 595 ou8t of standby mode? Help
Where is the button?
  • mblainewhitt Nov 17, 2008
    Can't figure out how to get my Kenwood KR 595 receiver out of standby mode? Help!
  • Ron Bower Jan 26, 2009
    I had a friend bring one of these units over to me and it did the same thing. I did a little searching and found a few people talking about the output transistors Q17-Q20 so i checked them and found 2 on one side shorted. So i clipped the leads and then it powered up but only one channel would work obviously. I then pulled them out and did some searching for replacements when doing this i found another post where a guy who had purchased a service manual mentioned he replaced the 2 output transistors and then they blew again. This got me wondering if i spend the money to replace these transistors if mine will have the same problem.
    SO with nothing to lose i tore the unit down and i got under the board, discharged the 2 power caps and decided to remove the 2 good transistors from the good working side and move them over to the other side. After i did this i put the whole unit back together and then plugged it in. After about a minute or 2 the good transistors blew.
    SO without a service manual i know there is a problem further before the output transistors. I think in the preamp stage causing the bad channel to overload and blow out.
    Sometimes audio amps can over drive speakers, short the voice coil in the speaker and this can cause the output transistors to blow. In this case just the transistors have problems. Normaly replacing them will fix it. My problem is somewhere before the output transistors. But now i know.
2 Suggested Answers
simonfasimon
SOURCE: Ppower on then standby problem Kenwood KR-V8060
How do I find damage to the Kenwood amplifier will not turn on the lights stanbynya
Posted on Sep 24, 2015
No power
One has to open her up and check for aged or swollen caps on the
power supply.
Sep 08, 2012 | Kenwood Audio Players & Recorders
We are trying to program the APEX TV code into the Dish network remote and none of the codes in their book is working.
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. In order to address your remote to your TV you are going to need the model number of your DISH remote. The model number will be located on the back of the remote at the top, usually a two to three digit number with a decimal point. I will list here for you the best codes for our more popular models of remotes as well as the instructions for addressing your remote to the TV. I hope you find this information useful and if you have any further questions or concerns feel free to email me directly at Cheri.Torres@Dishnetwork.com. Thanks.
Remote model # Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 745, 743, 744, 595, 757.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 595, 743, 745, 757.
4.0 and 4.4 IR/UHF remotes - codes 744, 595, 745, 757.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 744, 745, 595, 785, 743, 757.
20.0 IR and 21.0 IR/UHF remotes - codes 552, 594, 815, 595, 743, 757.
Instructions for addressing the remote to the TV
  1. Turn the Television On.
  2. Press and hold the TV Mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 26, 2011 | Apex Digital LD4088 LCD TV
I have no idea how to set the time for my clock on my kdc mp335 cd player
i was in a similar situation today luckily i was able to figure out the solution
follow this
1.switch to STANDBY MODE using the power button on the remote or using the SRC button on the player itself
2.Once you are in the standby mode , press the MENU button ( bass button ) on the left hand side top corner for 1 second
3.Use the right control Knob up and down to switch to CLK ADJ mode .
4.Once you are in CLK ADJ mode Hold the right control Knob for a second until the time starts flickering for change
5.Use the right control knob to change the settings , up and down changes the hour and , left and right changes the minutes
6.Press the MENU button ( bass button ) to save and exit
7.ALWAYS MAKE SURE YOU ARE IN STANDBY MODE
hope this helps :)
Aug 20, 2011 | Kenwood KDC-MP335 CD Player
I have an Apex model LD4088 and a dish remote and cannot find the right codes. Can you help
Hey there, Cheri Torres with DISH Network Customer Service.I came across your post recently and wanted to see if I could help. We have afew different codes for each of our different models of remotes you will beable to locate the model of your remote on the back of the remote at the topusually a two to three digit number with a decimal point. I will list here foryou the best codes for the more popular models of remotes as well as theinstructions for addressing your remote to your APEX TV. I hope you find thesecodes and instructions useful and if you have any further questions or concernsfeel free to email me at Cheri.Torres@Dishnetwork.com. Thanks and have a greatday!
The codes for each model of remotes
3.0, 3.1, 3.2 and 3.4 IR remotes - 745, 743, 595, 069 and 744
5.0, 5.2, 5.3 and 5.4 IR remotes - 595, 006, 019, 020, 757 and 744
20.0 IR remote - 594, 552, 815 and 017
4.0 and 4.4 IR/UHF remotes - 744, 595, 745,743 and 757
6.0, 6.2, 6.3 and 6.4 IR/UHF remotes - 744, 745, 595, 757, 743, 594 and 789
21.0 IR/UHF remote - 595, 594 and 743
Instructions for addressing remote to the TV
  2. Press and Hold the TV mode button until all other mode buttons light up red.
Feb 17, 2011 | DISH Network IR Remote Control
Dear sir,my surround amp rear speakers are not working.model is kr-v5580.other functions are OK..Pl's help
1st try a test tone to the rear speakers. If you can not get a test tone check the connections again.. once you get a test tone, use the "mode" button on your remote to cycle through the surround modes and make sure you are in a surround mode rather than a stereo mode.
Sep 29, 2010 | Kenwood KR-V5580
Standby mode
There are three modes — standby mode, radio mode or CD mode. To enter CD mode, press the power button and then the CD button. To enter radio mode, press the power button and then the radio button. To enter standby mode, press the power button.
If you're in standby mode and press the time set button, the clock digits will blink. If they don't blink, you aren't in standby mode.
Dec 28, 2008 | TruTech Clock Radio
How do I get to standby mode?
Can't Get Camera off Standby
may be the rec mode button is set at the anti grounding..usually at sony camera there are 3 switch mode the 5 sec mode, anti grounding and other and always use is the start and stop mode...this switch is located at the side of the camera...
Aug 26, 2007 | Sony Handycam DCR-TRV10 Mini DV Digital...
Standby mode, shuts off
After 10 years of use probably best to replace with a new unit. Most will be hard to find exactly wich little bit is broke.
May 23, 2017 | Kenwood KR-A5080 Receiver
Shooting in macro mode
The Macro Mode (flower icon button) operating range of the D-595 Zoom camera is 8 inches to 20-inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus when the optical zoom is at it’s greatest wide-angle. The Super-Macro Mode allows you to shoot with the camera as close as 1-inch from the subject. See page 41 of the Advanced Manual in PDF format which is on a separate CD.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
174 people viewed this question
 Grubhead
Grubhead
