Question about Whirlpool GMC305PD Electric Single Oven
Doors locked after self-cleaning
The Doors Locked light is on, and the oven door will not open even though it is many hours later and the self-cleaning cycle is done. Hate to call Sears. Any suggestions on how to get the oven door open?
We have a Whirlpool electric oven with Microwave above it.
    Sergeant:
    Champion:
  • 283 Answers
- Swithc off the oven
- Unplug the switch wire
- Switch it back
- Then try to open again its door.
Post for further information...please dont rate me if not stesfied for my suggestions..
Thank you....
Posted on Nov 17, 2008
    Genius:
  • 1,550 Answers
Have you tried unplugging the unit for 30 minutes from power chord and plugging back the power chord to unit .
This will reset the unit .
  • SAM ANDERSON Nov 17, 2008
    Your latch may be defective.
    Turn off the circuit breaker and open the panel to see whether the connections are proper .
    You can find any short circuit or any loose connection present there .
    Just provide the connection properly having a look at the service manual .
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Wait 20 seconds.
  • Wait 20 seconds.
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
We have a frigidaire fef354cjsa oven that has a self cleaning option. We started the self clean and it locked the door. 2 days later we cannot open the door still. The lock light is blinking. We have tried...
The best way to do is to pull the oven out if is built in and go through the top. If its free standing use a clothes hanger and make a hook and pull the latch to where youcan open the door. Your going to have to replace the lock motor assembly. Bit of advice though, slef clean is the worst invention ever and if you use it you will have more problems.
Nov 02, 2010 | Frigidaire Ovens
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
My stove won't unlock
there may be a problem with the door switch try pushing in the door a little bit.also hold the clear off key for 3 to 5 seconds this should allow you to open the door.
Jan 30, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore oven locked
Hello dktshopping,
I know you probable don't want to hear this but in you circumstance, I think you would be better off to contact a repair professional. Those oven door locks are meant to keep the door from opening during the oven's self-cleaning cycle. They are both mechanically and temperature controlled so that the door can not be opened when the oven is 950 degrees. It sounds to me as though something is not releasing to allowing the locking mechanisim to disengage from the door even though the lever is in the unlock position. The unit will probably have to be taken apaprt to remedy the problem. Good luck.
Nov 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Whirlpool GMC305PD Electric Single Oven Logo
60 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Richard Roth
Richard Roth
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
